    apiv3
    11 Posts 3 Posters 11.4k Views 3 Watching
    • Jdiaz-coJ Offline
      Jdiaz-co
      Good morning,
      I would need to know if there is a substitute for the "PUT /point-values" function that allows changing multiple datapoints at once in apiV1 by passing an array as a parameter in apiV3.
        @Jdiaz-co I'm a little confused by your phrasing. Maybe use some URLs as examples. But are you asking if there exists a REST v3 endpoint to PUT multiple point's values or if one exists for v1?
        There are POST methods for v3. I can't say for v1 as I don't have the code checked out.
        POST rest/v3/point-values using a JSON model as the body (this is not recommended and deprecated)
        POST rest/v3/point-value-modification/import using a JSON model as the body. (See swagger UI for this)
        • Jdiaz-coJ Offline
          Jdiaz-co
          Sorry for my English. I'm currently using apiV1, but I'm considering migrating everything to apiV3, which uses Mango v5.0.2. In apiV1, there is a "PUT" function called "/point-values" that allows you to send multiple Datapoints at once. However, I see that this "PUT" in apiV3 either doesn't exist or has changed.
            terrypacker @Jdiaz-co
            @Jdiaz-co I just checked and there is still and endpoint available via PUT. If you configure a data point to be 'settable' in the Mango UI and then open Chrome Dev tools while on the Data Point Details page you can set the value and see the PUT request. I can't upload images to the forum due to some problem. But here is the general output from the developer tools view:
            Request URL:  https://localhost:8443/rest/latest/point-values/DP_0f3b0e5d-b9ca-4f2f-916b-f2ddcadbba8a?unitConversion=true
            Request Method: PUT
            Status Code: 201
            Payload:
              "value":50,
              "dataType":"NUMERIC",
              "annotation":"Set from web by user: admin"
            • Jdiaz-coJ Offline
              Jdiaz-co
              Indeed, that endpoint works correctly; however, I can only send a single Datapoint in the request. My question is whether there is any endpoint where I can send multiple at once, as was possible in apiV1. I see, since I have tried that same endpoint and haven't been able to achieve it.
                @Jdiaz-co that endpoint only accepts a single point value (as you have discovered). Referring back to my first post I think you are looking for this new v3 endpoint:
                I don't think this is exposed in the UI so you will need to use Swagger. However the POST body will need to look like this:
                    "xid": "MY_POINT_1_XID",
                    "value":  1.0,
                    "timestamp": "ISO Formatted Date String",
                    "annotation": "can be null or any string"
                The idea being that you supply the xid for the point you want to set the value for.
                • Jdiaz-coJ Offline
                  Jdiaz-co
                  @terrypacker said in apiv3:
                  I've tried the POST "rest/v3/point-value-modification/import" you mentioned from Swagger, and it doesn't work for me when trying to input multiple Datapoints at once. Is there any other way?
                    MattFox @Jdiaz-co
                    @Jdiaz-co
                    I think it is missing
                    "dataType":"NUMERIC"|"ALPHANUMERIC"|"BINARY"
                    You'll need that for each value entry.
                    Pretty sure that's why it's throwing its toys...
                    • Jdiaz-coJ Offline
                      Jdiaz-co
                      Hello, in Swagger it works, that is, it gives me a 200 status code, but in Mango the value doesn't change.
                      I'm using this JSON to test it.:
                      "xid": "MY_DP",
                      "timestamp": 184965161,
                      "value": 4
                      "xid": "MY_DP",
                      "value": 2
                      The response is this, however, as I mentioned, the value doesn't change in Mango.
                      "xid": "DP_RV-BAR-1CA_bar_cmd",
                      "totalQueued": 1,
                      "totalSkipped": 0,
                      "result": {
                      "messages": [],
                      "valid": true,
                      "hasMessages": false
                      "xid": "DP_RV-BAR-1CA_status",
                      "totalQueued": 1,
                      "totalSkipped": 0,
                      "result": {
                      "messages": [],
                      "valid": true,
                      Thank you for assisting me.
                        MattFox @Jdiaz-co
                        @Jdiaz-co your timestamp needs to be an ISO formatted date-time string, not a unix timestamp!
                        • Jdiaz-coJ Offline
                          Jdiaz-co
                          @MattFox thanks for your help, ISO formatted It has worked correctly with the ISO timestamp format.
