    Email Event Handler - support for multistate and binary values
    6 Posts 2 Posters 2.0k Views 2 Watching
    • E Offline
      Elena
      MangoGT 3.7.7
      How to make an Event Handler to email rendered multistate values and binary points please?
      At the moment multistate data point returns raw value and binary blocks emails from sending altogether (errors in .ma file).
      .ma file :
      ERROR 2021-05-04T09:27:34,289 (com.serotonin.m2m2.rt.event.handlers.EmailHandlerRT.sendEmail:468) - Error sending email
      java.lang.NullPointerException: null
      	at com.serotonin.m2m2.rt.event.handlers.EmailHandlerRT.sendEmail(EmailHandlerRT.java:292) ~[mango-3.7.7.jar:?]
      	at com.serotonin.m2m2.rt.event.handlers.EmailHandlerRT.sendEmail(EmailHandlerRT.java:208) ~[mango-3.7.7.jar:?]
      	at com.serotonin.m2m2.rt.event.handlers.EmailHandlerRT.scheduleTimeout(EmailHandlerRT.java:165) ~[mango-3.7.7.jar:?]
      	at com.serotonin.m2m2.rt.event.handlers.EmailHandlerRT.scheduleTimeout(EmailHandlerRT.java:79) ~[mango-3.7.7.jar:?]
      	at com.serotonin.m2m2.util.timeout.ModelTimeoutTask.run(ModelTimeoutTask.java:36) ~[mango-3.7.7.jar:?]
      	at com.serotonin.timer.Task.runTask(Task.java:179) ~[mango-3.7.7.jar:?]
      	at com.serotonin.timer.TaskWrapper.run(TaskWrapper.java:23) ~[mango-3.7.7.jar:?]
      	at com.serotonin.timer.OrderedThreadPoolExecutor$OrderedTaskCollection.run(OrderedThreadPoolExecutor.java:314) ~[mango-3.7.7.jar:?]
      	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128) ~[?:?]
      	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628) ~[?:?]
      	at java.lang.Thread.run(Thread.java:830) [?:?]
        In order to help you a little more here without confusing you in the process... Can you explain what you want to trigger the event and thus send the email?
        You can send an alert based upon value thresholds being crossed or no change in value or no updates for a period of time.
        If however you mean how you render the data, perhaps looking at writing a .ftl file will be a better port of call. Can show you how to assemble a model and map all affiliated values as desifed withba script...
        After that happy to walk you through the process.
        • E Offline
          Elena
          thanks Matt.
          more context...
          We've got event handlers, and they are working fine.
          But now we need to enhance the emails to show a bit more data at the time of the event, thus populate some data points values into the email e.g.
          State (multistate type data point with 15 rendered values e.g. 1=Ready, 2=Fault etc) or
          Alarm (binary type, 0=Inactive, 1=Active).
          I'm defining these data points in Event Handler Script:
          model.put("p1",p1.value)
          model.put("p2",p2.value)
          and adding code into Custom Email Template:
          <table>
          <tr>
          <th>State</th>
          <td>${p1}</td>
          </tr>
          <tr>
          <th>Alarm</th>
          <td>${p2}</td>
          </tr>
          </table>
          result as per initial post:
          when only multistate data point defined in the code above, I'm getting an email and it contains State value as '1', not as I would expect - 'Ready'
          and when binary data point is in the code - email is not getting send
            Look at this code for a script which fires an email using the email handler directly:
            https://forum.mango-os.com/topic/3147/email-last-day-s-events/2
            You should either use freemarker markup ie <#if value == 1>Alt</#if>
            or append to your freemarker object the renderedValue for each item as you iterate through them at the given time.
            However, looking at above, you're 'putting' p1.value, not p1.renderedValue
            EDIT: that might actually be .rendered not renderedValue!
            Try that first and if no luck then perhaps building on a script that gives a better defined message using pointLocator data inside the datapoint itself for multistate values.
            • E Offline
              Elena
              Both 'renderedValue' and 'rendered' return 'undefined' in email unfortunately.
              Would you be able to help with the script please?
                Here is something I have written for you to pull the rendered text values for binary and multistate points.
                Now you can use the created object to "map" your current values to their rendered text equivalents...
                If you don't understand how this works, feel free to yell out.
                var rql="or(";
                 var items=[]
                 //Get all points attached to the script context
                 for(var i in CONTEXT_POINTS)
                    items.push('eq(xid,'+this[ i].getDataPointWrapper().xid+')');
                 //Build RQL query
                 rql+=items.join(',') + ')';
                 //get configs of all of these points
                 var dataPoints=JSON.parse(JsonEmport.dataPointQuery(rql)).dataPoints;
                 var ptMap={};
                 //Iterate through to get the rendered values
                 for(var i=0;i<dataPoints.length;i++)
                    ptMap[ dataPoints[ i ].xid ] = {};
                    if(dataPoints[i ].textRenderer.type==="BINARY")
                        //Set Binary renderedValues
                        ptMap[ dataPoints[ i].xid ][0] = dataPoints[ i].textRenderer.zeroLabel;
                        ptMap[ dataPoints[i ].xid ][1] = dataPoints[i ].textRenderer.oneLabel;
                    else if(dataPoints[i ].textRenderer.type==="MULTISTATE")
                        //Or get the multistate values
                        for(var j=0;j<dataPoints[i ].textRenderer.multistateValues.length;j++)
                            ptMap[ dataPoints[i ].xid ][dataPoints[ i].textRenderer.multistateValues[j].key] = dataPoints[ i].textRenderer.multistateValues[j].text;
                 //Print here just to show format of mapping. Can comment out.
                 print(JSON.stringify(ptMap) ); //so ptMap[xid][ ptValue ] => renderedValue
