    H2 to mySQL Error
    4 Posts 2 Posters 1.9k Views 2 Watching
      chrapchp
      I thought this should be a straightforward process. I installed Mango 3.77 on a headless ubuntu server 20.04 and mysql 8+. Moved the mango files and config to new env and worked fine under H2. Then configured env.properties to include mySQL and convert.
      I get this error. Duplicate column? Any ideas?
      INFO 2021-03-01T09:21:02,784 (com.serotonin.m2m2.Lifecycle.loadLic:670) - License file not found
      INFO 2021-03-01T09:21:02,870 (com.serotonin.m2m2.db.BasePooledProxy.initializeImpl:36) - Initializing pooled connection
      manager
      WARN 2021-03-01T09:21:05,381 (com.serotonin.m2m2.db.upgrade.DBUpgrade.checkUpgrade:98) - Upgrading 'core' from 1 to 2
      INFO 2021-03-01T09:21:05,383 (com.serotonin.m2m2.db.upgrade.DBUpgrade.createUpdateLogOutputStream:169) - Writing upgrad
      e log to /opt/mango/logs/com.serotonin.m2m2.db.upgrade.Upgrade1.log
      FATAL 2021-03-01T09:21:05,578 (com.serotonin.m2m2.db.AbstractDatabaseProxy.initialize:185) - Exception initializing data
      base proxy: org.springframework.jdbc.BadSqlGrammarException: StatementCallback; bad SQL grammar [alter table publishers
      add column rtdata longblob; ]; nested exception is com.mysql.jdbc.exceptions.jdbc4.MySQLSyntaxErrorException: Duplicate
      column name 'rtdata'
      com.serotonin.ShouldNeverHappenException: org.springframework.jdbc.BadSqlGrammarException: StatementCallback; bad SQL gr
      ammar [alter table publishers add column rtdata longblob; ]; nested exception is com.mysql.jdbc.exceptions.jdbc4.MySQLSy
      ntaxErrorException: Duplicate column name 'rtdata'
      at com.serotonin.m2m2.db.upgrade.DBUpgrade.checkUpgrade(DBUpgrade.java:104) ~[mango-3.7.7.jar:?]
      at com.serotonin.m2m2.db.upgrade.DBUpgrade.checkUpgrade(DBUpgrade.java:36) ~[mango-3.7.7.jar:?]
      at com.serotonin.m2m2.db.AbstractDatabaseProxy.initialize(AbstractDatabaseProxy.java:171) ~[mango-3.7.7.jar:?]
      at com.serotonin.m2m2.Lifecycle.databaseInitialize(Lifecycle.java:732) ~[ma-priv-3.7.7.jar:?]
      at com.serotonin.m2m2.Lifecycle.initialize(Lifecycle.java:285) ~[ma-priv-3.7.7.jar:?]
      at com.serotonin.m2m2.Main.main(Main.java:159) ~[ma-priv-3.7.7.jar:?]
      Caused by: org.springframework.jdbc.BadSqlGrammarException: StatementCallback; bad SQL grammar [alter table publishers a
      dd column rtdata longblob; ]; nested exception is com.mysql.jdbc.exceptions.jdbc4.MySQLSyntaxErrorException: Duplicate c
      olumn name 'rtdata'
      at org.springframework.jdbc.support.SQLExceptionSubclassTranslator.doTranslate(SQLExceptionSubclassTranslator.ja
      va:93) ~[spring-jdbc-5.1.7.RELEASE.jar:5.1.7.RELEASE]
        Stick to 5.7.x
        Mysql 8 has made a boatload of changes that a lot of systems haven't got full compatibility of.
          chrapchp
          The reason I jump on mySQL 8 is because someone said it worked. I'll try an older version.
          https://forum.mango-os.com/topic/4686/mysql-version/6?_=1614639710932
            Fair enough, but looking at your error looks like you are trying to overwrite existing columns.
