    1-Wire
    9 Posts 6 Posters 10.0k Views 1 Watching
    • T Offline
      thefixer
      One more question as I am trying to understand requirements and the best and hopefully simplest way to add 1-wire devices to mango. Can I simply come out of a comm port and start adding 1-wire devices that are wired correctly and have mango poll these devices? When and how far is the comm port not enough to supply power to the devices? Does the bus need power from another source besides the comms port? Is it better to use a stand alone controller?? Basically I want to add around 10 temp sensors and 2 humidity sensors and have mango poll these devices, just curious what others have done...
        Mango provides very simple setup of 1-wire networks. Questions about powering the devices and such should be directed toward your hardware vendor.
        In our lab we set up a 1-wire hub that came with its own power supply, so there were never issues about whether serial port power is sufficient.
        • K Offline
          kapucino
          Anybody got information how mango supports 1 wire sensors:
          DS-2438Z from Dallas
          and Honeywell HIH-3610
          They are both in this sensors:
          http://www.ibuttonlink.com/ms-th.aspx
          http://www.ibuttonlink.com/ms-t.aspx
          connected to RS 232 via LinkTH http://www.ibuttonlink.com/linkth.aspx
          I did some testing on my notebook via PCMCIA RS 232 conector. Instalation was ok, sensor detection not so succesful. But test was very short.
          If anybody has positive experience wih mango and these sensors please let me know to further invest more time in setting the whole thing up.
          • K Offline
            Keith
            Hi
            I've just found your question. I've got about 30 temp sensors and some switches set up on a 1 wire network. I'm planning to control my complex heating system through it using Mango.
            Getting it to be reliable is a right pain. Its very sensitive length and hoe the sensors are added. This article is very helpful
            http://www.maxim-ic.com/appnotes.cfm/an_pk/148
            If you want to do some testing to check the system is working either use the dallas software or LOGTEMP by mr soft both free
            Here's my public view page http://www.bacwak.net:8080/public_view.htm?viewId=8
            Which is a bit scrrewed at the moment as i have been playing with dials and buttons on it
            Keith
            • E Offline
              EKo_taas
              Getting it to be reliable is a right pain. Its very sensitive length and hoe the sensors are added....
              Keith
              Your webpage looks interesting :-)
              I am looking to build similar (mainly) logger system with 1-wire sensors including:
              • around 5 dual counters (DS2423)
              • around 20 temp. sensors (DS18S20)
              • 8 DI / 8 DO
              • Oregon Scientific WMTS-200 weather station with extra wireless room sensors (was cheapest way as wires were not possible).
              I have heard that direct 1-wire takes lot of CPU-capasity to keep timelines required. Could this be part of your stabilization problem?
              To solve that, I have been looking got TEMP08 (also mentioned here in forum), but no reply on that one.
              Looks that Mango don't support TEMP08 yet?
                Doesn't the TEMP08 just forward the 1-wire protocol, or does it use something else? If the former, Mango should work with it.
                • E Offline
                  EKo_taas
                  I don't think so - its sending (depending on paramenters, among othher things) to COM all measuremt every 1min, so any COM-listener can capture steam
                  http://www.midondesign.com/TEMP08/P04Instructions.html
                  The TMP Output Display
                  &gt
                  SUN 16:52:46
                  Reading Sensors...
                  Humidity #01[DC0000002B274726]=58%
                  Voltage #00 = 00.01V
                  Voltage #01[520000002B25A826]=00.12V 05.05V
                  Voltage #02[020000002B2CB326]=03.98V 05.03V
                  Lightning #01[D4000000045C621D]=00020 24592
                  1WIO Status = On,On,On,On
                  Temp #01[4C00080031220C10]=70.80F
                  Temp #02[10000800312D2B10]=79.80F
                  Temp #03[520000002B25A826]=76.21F
                  Temp #04[020000002B2CB326]=72.77F
                  Temp #05[DC0000002B274726]=76.21F
                  &gt
                  Can it be integrated by using some simple ASCII transfer-file (mango would read/poll this file) or any better/easier ideas?
                    mhradom
                    @Keith said:
                    Hi
                    Keith
                    Keith,
                    What switches are you using and how do you have them connected? Powered, parasite, pullup resistors, etc? The reason I ask is that I have switch module D2P from EDS (DS2406 based). Mango sees the switch (but only one, it should see A and B since it is a double I/O) but it does not sense the switch staus (binary change). I am using this on serial input and parasite mode. Interestingly enough I have the same exact problem with LogTemp. However, Dallas/Maxim viewer sees status changes perfectly.
                    http://www.embeddeddatasystems.com/assets/images/supportFiles/manuals/D2PandD2PC.pdf
                    Anybody else, feel free to chime in.
                    BTW, love the Mango software so far.
                    Mike
