    Accessing previous values from data points to work out flow rate
    4 Posts 2 Posters 2.0k Views 2 Watching
    • danD Offline
      dan
      Hey Guys, I'm trying to work out if there is a way to access previous values in a data point's history from the scripting data sources so I can work out flow rate from water level data point in tanks.
      I'm thinking I should be able to look at the difference in the values and work out the flow rate in litres per hour or litres per minute, then just update a virtual data point to display it. It's probably so simple I can't see it for looking :O)
      I know PREVIOUSVALUE(datapoint) exists as I use it frequently, but is there one for say a minute ago?
      Or could I simply mirror a data point value but only update it once a minute, then just work out the flow rate by comparing the current value to the previous only.
      Dan
        use pt.pointValuesSince(timestamp)
        or:
         pointValueAfter(timestamp, cache)
        //function returns the nearest point value/time object after to timestamp, or null if there is not one.
        pointValueAt(timestamp, cache)
        //function returns the a point value/time object that was recorded exactly at the timestamp, or null if there is not one.
        • danD Offline
          dan
          Thanks mate, I'll give it a go.
            Anytime
