    First initializing a chart using ma-point-values xid built using other datapoint values
    4 Posts 2 Posters 2.3k Views 2 Watching
    • E Offline
      etantonio
      I've a chart where I want to show the power of an inverter, this is a template page named "home.html" I want to use it for several different inverter, so I calculate the datapoint xid using other two datapoints "plantNameAcronym" and "trackerRowColumn":
      <div flex layout="column" layout-gt-sm="row" layout-align="space-between" ng-init="live=1; energy=0">
        <md-card flex="100" flex-gt-sm="50">
          <md-card-title>
            <md-button ng-class="{'selected': live === 1, 'not-selected':live!==0}" ng-mousedown="live=1; from=theTimeNow">LIVE</md-button>
            <mdp-date-picker mdp-placeholder="Day" ng-click="live=0" mdp-open-on-click="" mdp-format="ll" ng-model="from"></mdp-date-picker>
          </md-card-title>
          <md-card-content class="graph-content">
            <div ng-if="live ==0">
              <ma-point-values point-xid="{{plantNameAcronym.value}}_TRK-{{trackerRowColumn.value}}_FML01-power-smart" point="powerPast" values="powerPastValues"
                    from="from | moment:'startOf':'day' | moment:'add':3:'hours'"
                    to="from | moment:'endOf':'day'" rollup="LAST" rollup-interval="1 minutes">
               </ma-point-values>
               <ma-serial-chart style="height: 250px; width: 98%" series-1-values="powerPastValues" series-1-color="#F88F24" series-1-point="powerPast" series-1-type="line"
                  legend="false" default-balloon-text="Power: [[value]] kW" balloon="true" export="true"  stack-type="regular"
                  options="{export: {'dateFormat': 'DD/MM/YYYY H:mm ', 'fileName': 'Power'},
                  titles:[{text:'Power chart',color:'#165A87'}],
                  valueAxes:[{title:'[kW]', gridColor:'#444343', axisColor:'#444343',titleColor:'#165A87'}],
                  categoryAxis:{gridColor:'#444343', axisColor:'#444343', startEffect:'elastic'}
              </ma-serial-chart>
            <div ng-if="live ==1">
              <ma-point-values point-xid="{{plantNameAcronym.value}}_TRK-{{trackerRowColumn.value}}_FML01-power-smart" point="powerLive" values="powerLiveValues"
                from="theTimeNow | moment:'startOf':'day' | moment:'add':3:'hours'"
                to="theTimeNow" rollup="LAST" rollup-interval="1 minutes">
              </ma-point-values>
              <ma-serial-chart style="height: 250px; width: 98%" series-1-values="powerLiveValues" series-1-color="#F88F24" series-1-point="powerLive" series-1-type="line"
              </ma-serial-chart>
          </md-card-content>
        </md-card>
      instead in another file customized for each inverter (6.4 in this case) I've something like this:
      <ma-get-point-value point-xid="TER_TRK-6.4_ConfigRPI-tracker-rowColumn" point="trackerRowColumn"></ma-get-point-value>
      <ma-get-point-value point-xid="TER_TRK-6.4_ConfigRPI-plantNameAcronym" point="plantNameAcronym"></ma-get-point-value>
      <div ng-include="'templates/home.html'"></div>
      My problem is that on first loading (live=1) the graph is not showed
      but clicking on "Day" an then again on "Live" the graph is showed correctly
      is seems to be an initialization problem but I can't realize where's the problem, using directly point-xid="TER_TRK-6.4_FML01-power-smart" works without problems:
      <ma-point-values point-xid="TER_TRK-6.4_FML01-power-smart" point="powerLive" values="powerLiveValues"
              </ma-point-values>
      Any idea about how to solve the problem?
      Antonio
      • E Offline
        etantonio
        It seems that the first time the page is executed the
        becomes:
        but ma-point-values is evaluated just when I switch from a graph type to the other.
        I've tried to use ng-init in an outer div to evaluate the point xid before but the result is always a blank graph.
          Try using an ng-if, that way it won't load until you have the values in the browser to insert into the chart.
          I do that due to the fact there is always some delay with HTTP requests if you're using everything from the dashboard side without any javascript code.
          • E Offline
            etantonio
            It's not working for me, I'll solve this repeating the page for any "trackerRowColumn" in the plant instead of creating a template to use for all the plant, thanks anyway.
            Antonio
