    Adding Alarm Level Types
    5 Posts 5 Posters 2.5k Views 5 Watching
    • F Offline
      fishfacs
      Is there a way to add custom Alarm Levels to use with my own events, rather than the stock "important", "safety", etc ones?
      • W Offline
        Wingnut2.0
        Hello fishfacs,
        I had a similar requirement in the past and Phillip provided the solution detailed here. Not sure if anything may have changed since then as its been a while. I hope this helps.
        https://forum.infiniteautomation.com/topic/3367/modify-alarm-level-names/2
          It is not possible to add/remove or change the colors of the alarm levels. However you can change their translations as @Wingnut2-0 pointed out.
          As he said that information is from a while ago. I would suggest the best way of doing it would be to create a new i18n_en.properties (assuming your language is set to English) file in ${MA_HOME}/overrides/properties/ with this content (modify as necessary)
          common.alarmLevel.none=None
          common.alarmLevel.none.rtn=None - returned to normal
          common.alarmLevel.info=Information
          common.alarmLevel.info.rtn=Information - returned to normal
          common.alarmLevel.important=Important
          common.alarmLevel.important.rtn=Important - returned to normal
          common.alarmLevel.warning=Warning
          common.alarmLevel.warning.rtn=Warning - returned to normal
          common.alarmLevel.urgent=Urgent
          common.alarmLevel.urgent.rtn=Urgent - returned to normal
          common.alarmLevel.critical=Critical
          common.alarmLevel.critical.rtn=Critical - returned to normal
          common.alarmLevel.lifeSafety=Safety
          common.alarmLevel.lifeSafety.rtn=Safety - returned to normal
          common.alarmLevel.unknown=unknown alarm level
          common.alarmLevel.doNotLog=Do not log
          common.alarmLevel.ignore=Ignore
          common.alarmLevel.greaterthan.none=>= None
          common.alarmLevel.greaterthan.info=>= Information
          common.alarmLevel.greaterthan.important=>= Important
          common.alarmLevel.greaterthan.warning=>= Warning
          common.alarmLevel.greaterthan.urgent=>= Urgent
          common.alarmLevel.greaterthan.critical=>= Critical
          common.alarmLevel.greaterthan.lifeSafety=>= Safety
          Doing it this way means that
          • The file is not overwritten when upgrading
          • Mango will still use updated translation files shipped with new versions of Mango (i.e. you aren't overriding the whole translation file, just the keys you need)
            Malaguena
            Hello!
            In this post, I see that we can change name of Alarm Level.
            Is that possible to add some more Alarm level in addition to 7 default levels ?
            Thanks!
              MattFox @Malaguena
              @jared-wiltshire said in Adding Alarm Level Types:
