    /v1/point-values PUT not updating in datasources other than virtual
    6 Posts 2 Posters 2.5k Views 2 Watching
      Morning All,
      I've got data coming into my API which I'm relaying into mango after parsing the data.
      Problem is the points are not updating. These points are in datafile datasources, are 'settable' and are still not updating in mango, despite the 201 Created status response.
      The system sending this data is dropping their FTP uploads in favour of HTTP posts.
      The other issue is despite adding a poll class as suggested by Phil I'm still not triggering these updates.
      Any advice would be hugely appreciated and I'd be rather grateful.
      Am still on 3.5.6 - this may have to change at some point but I'll likely need some advice on going about this and not destroying my production install..
      EDIT: Alternatively, how hard would it be to convert the Data File datasources into Virtual datasources? If I could manage that, it would save a lot of fluff.
        Hi Fox,
        Can you post your poll class? What is the logging type of your points?
        The PUT endpoint behaves like a set through Mango. If the user your PUT'ing the value through the API has permission to set the point, you should see that get to the poll class's method I said you had to implement:
        public boolean setPointValueImpl(DataPointRT dataPoint, PointValueTime valueTime,
                    SetPointSource source)
        You could do something in this method to prove to yourself it got there. If that returns true, then it will call setPointValue on the DataPointRT and that has some subtleties from logging type.
        You would have to do some work to ensure the id to xid set was the same (i.e. SELECT id, xid FROM dataPoints; and save that to make a bunch of update statements for the modified points. Here's an old python script that will convert all data source and data points in a JSON file to virtual sources and points (you may want to make them no change point locators): https://github.com/infiniteautomation/ma-devtools/blob/master/PythonUtilities/Simulation/virtualizeDataSources.py
        You would have to delete the old, import the new, and then run the SQL update statements to set the ID based on the XID such that old data wasn't lost. So, possible by maybe not trivial.
          Thanks for your help with this Phil!
          import com.infiniteautomation.datafilesource.rt.AbstractPollClass;
          import com.infiniteautomation.datafilesource.rt.PollClassInvoker;
          import com.serotonin.m2m2.rt.dataImage.DataPointRT;
          import com.serotonin.m2m2.rt.dataImage.PointValueTime;
          import com.serotonin.m2m2.rt.dataImage.SetPointSource;
          public abstract class PutPollClass extends AbstractPollClass {
          	/* @Override
          	public abstract void run(long time, PollClassInvoker invoker, String[] arguments); */
          	 @Override
          	public boolean setPointValueImpl(DataPointRT dataPoint, PointValueTime valueTime,SetPointSource source) {
          		return true;
          Is the poll class data code.
          I'm using the API with an admin bearer token for simplicity. Should I take the login API route instead?
          "loggingType":"ALL",
          So stupid question... By deleting means I'd still need to backup my data right? Or do you mean calling a DELETE FROM ... SQL query? Ah no wait I see now, you use the id to link point values to the datapoint, not the XID. Gotta admit I do like that. Will be good to get this sorted asap as data hasn't come in for two days now.
            The issue with the poll class it will not work as an abstract class, it must be able to be instantiated so that it may be run. I just tested and was able to set values to data file points when my poll class looked like this:
            public class PutPollClass extends AbstractPollClass {
            	 @Override
            	public void run(long time, PollClassInvoker invoker, String[] arguments) {}
            	 @Override
            		return true;
            Remember, you'll need to recompile the class, and then restart the data source for the modifications to be applied.
              MattFox @phildunlap
              @phildunlap said in /v1/point-values PUT not updating in datasources other than virtual:
              Ah that's where I was going wrong! I think I was having issues with it compiling which is why I threw that unnecessary abstract in front... Thanks Phil, definitely feeling like a prized pillock today!
              May tomorrow go better?
                No worries, the data file data source probably requires the most Java knowledge outside of writing scripts that invoke the code. Even then, the scripts get to benefit from JavaScripts willingness to store any ole' type into a variable, where everything needs to be properly typed and declared in the data file classes. Tricky when there are but few examples and it's closed source!
                I would guess there was an informative event raised about a failure to instantiate the poll class, but I couldn't say.
