    Not able to create local device using port 47809
    9 Posts 2 Posters 4.5k Views 3 Watching
    • V Offline
      Vihangi
      With BACnet4J library, I am trying to create a new object of the local device using port 47809 and initialize it.
      Code snippet::
      static LocalDevice initializeLocalDevice() {
      LocalDevice device = null;
      try {
      device = new LocalDevice(localDeviceId, new DefaultTransport(new IpNetworkBuilder().withPort(47809).build()));
      device.initialize();
      } catch (Exception e) {
      System.err.println("Error in initializeLocalDevice: " + e);
      e.printStackTrace();
      return device;
      But, got below error while executing the above code.
      Error:
      Error in initializeLocalDevice: java.lang.IllegalArgumentException: Either withBroadcast or withSubnet must be called.
      at com.serotonin.bacnet4j.npdu.ip.IpNetworkBuilder.build(IpNetworkBuilder.java:129)
      Please provide any solution for the same.
      Vihangi
        Hi Vihangi, welcome to the forum.
        The answer is right there in the exception. If you're going to be developing with BACnet4J you will need to be able to read in the code why the exception has occurred if its message is not clear to you: https://github.com/infiniteautomation/BACnet4J/blob/master/src/main/java/com/serotonin/bacnet4j/npdu/ip/IpNetworkBuilder.java#L128
        • V Offline
          Vihangi
          Hi Phildunlap, Thanks for the reply.
          My error is resolved by doing below changes:
          new DefaultTransport(new IpNetworkBuilder().withPort(47809).withBroadcast(broadcastAdd, 24).build()
          Can we implement BACnet router to do communication between two devices with the different ports?
          For example:
          One device with port 47808 and another one with 47809
          Is it possible to do this with BACnet4J library?
            Per the BACnet specification all devices on a network must be on the same port. So, to bridge networks you need a BBMD, which could be a BACnet router. The IpNetwork class does have support for behaving as a BBMD, but as Mango does not expose this functionality I have little experience with it. You can see there is an enableBBMD method, though: https://github.com/infiniteautomation/BACnet4J/blob/master/src/main/java/com/serotonin/bacnet4j/npdu/ip/IpNetwork.java#L991
            • V Offline
              Vihangi
              Thanks, Phildunlap !!
              • V Offline
                Vihangi
                Hi Phildunlap,
                I am getting below error while reading log record of TrendLog Object.
                Error:
                Error: ErrorAPDU(errorClass=property, errorCode=read-access-denied,errorClass=property, errorCode=read-access-denied)
                Other Property Values are as below:
                Property:: acked-transitions Value :: EventTransitionBits [to-offnormal=true, to-fault=true, to-normal=true]
                Property:: align-intervals Value :: true
                Property:: buffer-size Value :: 50
                Property:: client-cov-increment Value :: ClientCov [entry=2.0]
                Property:: cov-resubscription-interval Value :: 200
                Property:: description Value :: EventEnrollment Object
                Property:: event-enable Value :: EventTransitionBits [to-offnormal=false, to-fault=true, to-normal=false]
                Property:: event-state Value :: normal
                Property:: event-time-stamps Value :: [TimeStamp [choice=DateTime [date=Date [year=255, month=UNSPECIFIED, day=255, dayOfWeek=UNSPECIFIED], time=255:255:255.255]], TimeStamp [choice=DateTime [date=Date [year=255, month=UNSPECIFIED, day=255, dayOfWeek=UNSPECIFIED], time=255:255:255.255]], TimeStamp [choice=DateTime [date=Date [year=255, month=UNSPECIFIED, day=255, dayOfWeek=UNSPECIFIED], time=255:255:255.255]]]
                Property:: interval-offset Value :: 100
                Property:: last-notify-record Value :: 1064
                Property:: log-device-object-property Value :: DeviceObjectPropertyReference [objectIdentifier=analog-output 12, propertyIdentifier=present-value, propertyArrayIndex=null, deviceIdentifier=device 105]
                Property:: enable Value :: true
                Property:: log-interval Value :: 100
                Property:: logging-type Value :: polled
                Property:: notification-class Value :: 19
                Property:: notification-threshold Value :: 100
                Property:: notify-type Value :: event
                Property:: object-identifier Value :: trend-log 26
                Property:: object-name Value :: EventEnrollment-Object
                Property:: object-type Value :: trend-log
                Property:: profile-name Value :: Default
                Property:: record-count Value :: 50
                Property:: records-since-notification Value :: 26
                Property:: start-time Value :: DateTime [date=Date [year=119, month=SEPTEMBER, day=27, dayOfWeek=FRIDAY], time=4:0:0.0]
                Property:: stop-time Value :: DateTime [date=Date [year=119, month=OCTOBER, day=4, dayOfWeek=FRIDAY], time=6:30:0.0]
                Property:: stop-when-full Value :: false
                Property:: total-record-count Value :: 1094
                Please help me with this.
                As I want to poll and read trend logs.
                  Did you attempt to figure this out before you asked? Are you attempting to read the log buffer property? https://github.com/infiniteautomation/BACnet4J/blob/master/src/main/java/com/serotonin/bacnet4j/obj/TrendLogObject.java#L233
                  https://github.com/infiniteautomation/BACnet4J/blob/master/src/main/java/com/serotonin/bacnet4j/obj/logBuffer/LogBuffer.java#L8
                  • V Offline
                    Vihangi
                    Yes, I have tried to trigger it and it will work. But, with " logging-type Value = polled", it was not able to get a trend log.
                    With polling, it will generate below error:
                    ErrorAPDU(errorClass=property, errorCode=invalid-data-type,errorClass=property, errorCode=invalid-data-type) Error: ErrorAPDU(errorClass=property, errorCode=invalid-data-type,errorClass=property, errorCode=invalid-data-type), originalInvokeId=18
                    Read the output of log buffer property:
                    Is there any configuration issue?
                    • V Offline
                      Vihangi
                      Still not able to read Log buffer values.
                      Got same Error:
