    HTTP Retriever - Value RegEx works whit accent
    8 Posts 3 Posters 2.1k Views 3 Watching
    • F Offline
      Francisco Salinas
      Hi. I am trying to get points from a web page using HTTP Retriever. Everything works fine until in the RegEx Value I place a word with access. for example:
      <tr><td><span>(Cerro Patacón)</span></td><td><span>(.*?)</span></td></tr>
      I get "Validation Error - No value match made for point Cerro Patacón.
      How can I solved it?
      Thanks you in advance..
        The following characters have special meaning, and should be preceded by a \ (backslash) to represent a literal character:
        So your
        Should be
        <tr><td><span>\(Cerro Patacón\)</span></td><td><span>(.*?)</span></td></tr>
        • F Offline
          Francisco Salinas
          Sorry my error the original regex value is
          <tr><td><span>Cerro Patacón</span></td><td><span>(.*?)</span></td></tr>
          I try you suggestion
          <tr><td><span>\Cerro Patacón\</span></td><td><span>(.*?)</span></td></tr>
          but I get this error:
          Illegal/unsupported escape sequence near index 15 <tr><td><span>\Cerro Patacón</span></td><td><span>(.*?)</span></td></tr> ^
            @francisco-salinas said in HTTP Retriever - Value RegEx works whit accent:
            <tr><td><span>Cerro Patacón</span></td><td><span>(.?)</span></td></tr>
            If that's the case:
            <tr><td><span>Cerro Patacón<\/span><\/td><td><span>(.?)<\/span><\/td><\/tr>
            • F Offline
              Francisco Salinas
              I get this error:
              Validation error - No value match made for point Cerro Patacón
                MattFox @Francisco Salinas
                @francisco-salinas
                If you have a copy of the source you're trying to parse from, use regexr.com and work from that to create your RegExp string.
                The Cerro Patacón should be part of the text, not a variable. I think there's a lot of detail missing here that you've not made clear.
                  Hi Francisco, welcome to the forum!
                  Regex can certainly match the accent. You can see that here, where I was using the browser developer tools:
                  So I have to agree with Fox that part of the question is hidden in not having the source text that's being matched. . should match everything but newlines. If there are newlines, you could try picking a character that doesn't appear and using a ([^~]*) or a ((?:.|\r|\n)*)
                  • F Offline
                    Francisco Salinas
                    Hi phil. Thanks you. I used your recommendation and found that the regex value was waiting instead of Cerro Patacón, Cerro Patacún.
                    I changed that in the regex value and voila. is working.
                    ú ú
                    ó ó
                    í Ã
                    é é
                    á á
