    HttpBuilder.request()
    3 Posts 2 Posters 2.2k Views 2 Watching
    • D Offline
      Desmond
      Hi all,
      This is my first attempt to make a REST call to retrieve a point values array via Mango scripting source.
      Via Swagger:
      url:
      http://localhost:8080/rest/v2/point-values/multiple-arrays/latest/DP_422050,CDP_614346?limit=3&useCache=NONE
      result:
        "DP_422050": [
            "timestamp": 1567738483443,
            "value": 175.51602162739323
            "timestamp": 1567738423443,
            "value": 175.16915149128016
            "timestamp": 1567738363443,
            "value": 174.31921651479684
        "DP_614346": [
            "value": 211795
            "value": 211790
            "value": 211785
      Via Mango scripting data source:
      print(HttpBuilder.request({
          path: "http://localhost:8080/rest/v2/point-values/multiple-arrays/latest/DP_422050,DP_614346",
          method: "GET",
          headers : {
           "Cookie": "XSRF-TOKEN=6ac16488-db6d-4e64-8353-2faea1433e0f",
           "X-XSRF-TOKEN": "6ac16488-db6d-4e64-8353-2faea1433e0f",
           "Content-Type":"application/json;charset=UTF-8",
           "Host": "localhost:8080",
           "Accept": "application/json, text/plain"
          parameters: {
          "limit" : 3,
          "useCache" : "None",
          //content: "GETs don't have content!",
          err: function(status, headers, content) { //errorCallback for linguistic completion
              throw "Request got bad response: " + status;
          resp: function(status, headers, content) { //responseCallback
              //try to retrieve the HttpBuilder object but no success
              //var result = JSON.parse(headers);
              //print(result);
              print(content);
              return true; //will print in wrapping print()
          excp: function(exception) { //exceptionCallback
              throw exception.getMessage();
      result:
      null
      I also tried to retrieve the headers for a check test but no success. After some thought, I realize this might due to the "GETs don't have content". If this is the situation, how then can I access the point values array from return HttpBuilder object?
      Likelihood I am unable to grasp the concept of HttpBuilder correctly and hopefully someone can help me out on the silly mistake I may have overlooked.
      Thanks and Best Regards
        Hi Desmond,
        It seems the first issue is a class cast exception for the excp function. You can remove this function and the err function will be used instead with status code -1. Thanks for bringing this to our attention! https://github.com/infiniteautomation/ma-core-public/issues/1489
        After that, I also had to modify the "useCache": "None" to be "useCache": "NONE" (other options are CACHE_ONLY and BOTH )and I used an authorization token in my testing. This worked for me:
        var token = "token value from users page"
            path: "http://localhost:8080/rest/v2/point-values/multiple-arrays/latest/DP_755013cd-03e3-4e9b-aad1-7a4575e58ebd",
            method: "GET",
            headers : {
             "Authorization":"Bearer "+token,
            parameters: {
            "limit" : 3,
            "useCache" : "NONE"
                throw "Request got bad response: " + status + " " +content;
                //print(result);
                print(content);
        • D Offline
          Desmond @phildunlap
          @phildunlap
          Thank you for your prompt reply. It works like a breeze.
          In my opinion, this is a powerful tool that open up the doors to communicate with internet of things / web content. In addition it provide flexibility to integrate your creativity into application.
          "Logic will get you from A to B. Imagination will take you everywhere".
