    Styling a Custom Component in userModule
    17 Posts 4 Posters 10.8k Views 4 Watching
      Cool thanks Pyeager, I'll get something knocked together now. Secondly, you're best to use a separate template url per component. I'd strongly suggest creating a /rest/v2/file-stores/public/stickGun.html html file, so you know what the contents are without having to open it up.
      That also appears to be on disk at /opt/mango/filestore/public
      Sorry I meant outside of mango in the overrides or something. Just in case upgrades or something causes an errant spanner to be thrown... ;) - It also allows you to add source control so you can store your files in a git or svn based solution, very handy for versioning, and who to blame when something breaks (haha)
        Here's something to get you started, I'm not sure what the purpose of the ng-click is for your image, if you are able to explain i'll likely be able to assist with that part.
        I am not sure what name and face are for either.
        Basically with the component, you're bringing all of the dynamic variables to the surface as bindings for the component. From here you do all of your calcs and fancy doodads inside the component's controller.
        Your html:
        <section>
        <style>
        .idle { background-color: rgba( 255, 255, 255, 0.5); }
        .heat { background-color: rgba( 255, 255, 0, 0.5 ); }
        .air { background-color: rgba( 3, 186, 252, 0.5 ); }
        .heatair { background-image: url("/rest/v2/file-stores/default/HeatAir.png"); }
        .a0 { background-image: url("/rest/v2/file-stores/default/A0.png"); }
        .s1 { background-image: url("/rest/v2/file-stores/default/Stage1.png"); }
        .s2 { background-image: url("/rest/v2/file-stores/default/Stage2.png"); }
        .s3 { background-image: url("/rest/v2/file-stores/default/Stage3.png"); }
        .manual { background-color: rgba( 0, 0, 0, 0.5); }
        </style>
        <ma-get-point-value point="sequence1" point-xid="{{$ctrl.pointXid}}"></ma-get-point-value>
        <!-- ng-click="designer.parameters = {dn: 'sg-lsb-01v'}" What is this for?? -->
        <img id="{{$ctrl.pointXid}}_img" style="width: 30px; height: 28px;" src="/rest/v2/file-stores/default/HKDStickL.png" ng-click="designer.parameters = {dn: 'sg-lsb-01v'}" ng-class="{0:'idle', 1:'heat', 2:'air', 3:'heatair', 4:'a0', 5:'s1', 6:'s2', 7:'s3', 8:'manual'} [sequence1.value]">
        </section>
        Your component
        userModule.component('stickGun', {
            bindings: {
                name: '>?',  //1-way binding optional
                face: '>?',
        		pointXid:'>' //required
            templateUrl: '/rest/v2/file-stores/public/stickGun.html',
            styleUrls: ['/rest/v2/file-stores/public/userModule.css'], //not hugely needed, especically if you use the user styles file to store all your css in. Unless you plan to take this component to other places...
        	controller:function(){
        		var ctrl = this;
        		this.$onChanges = function(e)
        			//binding checks are done in here. this is for an example of what I stated prior if you are using optional bindings
        			if(e.pointXid && e.pointXid.currentValue!=undefined)
        				ctrl.pointXid = e.pointXid.currentValue;
        P 1 Reply Last reply Reply Quote 1
          pyeager @MattFox
          @mattfox Thanks!
          It's quitting time. so I'll play with it tomorrow.
          When the image is clicked, ng-click set which device's details are shown on a card.
            @pyeager This is what I would do, based off your code. Note that styleUrls seems to be Angular 2+ syntax, not AngularJS (1.x). Put your CSS in the user styles style sheet (under UI settings).
            User module -
            'use strict';
            // doesn't do anything, but here for completeness
            class StickGunController {
                bindings: {
                    name: '@?', // dont know what these are for, but sure
                    face: '@?',
                    point: '<?'
                controller: StickGunController
            return userModule;
            }); // define
            Template file (/rest/v2/file-stores/public/stickGun.html) -
            <ma-get-point-value point="$ctrl.point"></ma-get-point-value>
            <img src="/rest/v2/file-stores/default/HKDStickL.png" ng-class="{0:'idle', 1:'heat', 2:'air', 3:'heatair', 4:'a0', 5:'s1', 6:'s2', 7:'s3', 8:'manual'}[$ctrl.point.value]">
            CSS file -
            stick-gun {
                display: block;
            stick-gun > img {
                width: 100%;
                height: 100%;
            stick-gun > img.idle { background-color: rgba( 255, 255, 255, 0.5); }
            stick-gun > img.heat { background-color: rgba( 255, 255, 0, 0.5 ); }
            stick-gun > img.air { background-color: rgba( 3, 186, 252, 0.5 ); }
            stick-gun > img.heatair { background-image: url("/rest/v2/file-stores/default/HeatAir.png"); }
            stick-gun > img.a0 { background-image: url("/rest/v2/file-stores/default/A0.png"); }
            stick-gun > img.s1 { background-image: url("/rest/v2/file-stores/default/Stage1.png"); }
            stick-gun > img.s2 { background-image: url("/rest/v2/file-stores/default/Stage2.png"); }
            stick-gun > img.s3 { background-image: url("/rest/v2/file-stores/default/Stage3.png"); }
            stick-gun > img.manual { background-color: rgba( 0, 0, 0, 0.5); }
              Oh, and to use, you just add this to your page -
              <stick-gun point="myPoint"></stick-gun>
                Thanks Jared, appreciate the support!
                  pyeager
                  Thank you both for your help.
                  I might need just a little more.
                  Specifying a data point by xid, as both of your examples do, is a bit less than optimal for a couple of reasons.
                  For one thing, there are multiple data points with which the component needs to interact.
                  Also, specifying one or more data points by xid is less than user friendly. My preferred approach is to just name the component instance in such a way that queries can be constructed from the instance name, removing the need to specify an xid for each data point.
                  ...and additionally...
                  This may be asking a lot, but ideally adding this component to a dashboard would also create a few data sources, likely from a template. That would make the drag and drop addition of the component and definition of element-specific details pretty much all that is necessary to add a machine to the system.
                  Jared WiltshireJ MattFoxM 2 Replies Last reply Reply Quote 0
                    Jared Wiltshire @pyeager
                    @pyeager said in Styling a Custom Component in userModule:
                    My example does not specify a data point by XID, it passes a single data point through.
                    In this case you could pass a whole array of data points through (from a query or Watchlist) and filter the points out inside the component.
                    I agree you should not directly bind components to a specify XID. This is why our dashboard designer supports selecting a watchlist then binding components to data points using their name.
                    If you want to use a name attribute for your components this would work in a similar fashion. Like I said above, pass the whole points array through to the component and then find the point you want inside the component using the name attribute.
                    e.g. controller for your component
                      $onChanges(changes) {
                        if (changes.points && Array.isArray(this.points)) {
                          this.point = this.points.find(pt => pt.name === this.name);
                    Certainly possible, I don't have time to get right into this right now but you could use the maDataSource service to check for the existence of the DS and create it if one matching the name attribute doesn't exist.
                      pyeager @Jared Wiltshire
                      @jared-wiltshire said in Styling a Custom Component in userModule:
                      How does one pass the whole points array to the component?
                        By defining "points" as an input of the component, as I did in this post: https://forum.infiniteautomation.com/topic/3503/how-to-chart-with-data-points-in-the-x-axis-instead-of-time/6
                          Are you asking how to define the binding in the component or how to pass the points to the attribute when you are using it?
                          To define the binding, you literally just have to change point to points in the example I posted above. I gave you a controller that will locate the point from the array using the name attribute.
                          If you meant the latter, I suggest you peruse the examples that are built into Mango (enable the examples menu item using the menu editor if you have not already).
                            MattFox @pyeager
                            You never stated this initially
                            If this is remotely similar to making a new point using the maPoint service perhaps I can be of assistance here
