    Linux Service in Debian 10
    7 Posts 2 Posters 4.2k Views 2 Watching
    • cwangvC Offline
      cwangv
      I have installed Mango Automation software v3.6.4 on a HP Stream 13 with Debian 10 (64 Bit version) and Open JDK 11.0.4.
      I can manually start Mango software from terminal without problem.
      I ran into trouble when i tried to setup Linux Service. I found a similar problem on the forum which has a status code of 126 but mine
      has got status code of 127.
      Below is what i have encountered:
      I followed the instructions on how to setup a Linux service and when i ran the status command, below is what i get from the terminal:
      Aug 05 21:50:50 debian-mango systemd[1]: Starting LSB: Start or stop the Mango Automation...
      Aug 05 21:50:50 debian-mango systemd[1]: mango.service: Control process exited, code=exited, status=127/n/a
      Aug 05 21:50:50 debian-mango systemd[1]: mango.service: Failed with result 'exit-code'.
      Aug 05 21:50:50 debian-mango systemd[1]: Failed to start LSB: Start or stop the Mango Automation.
      ● mango.service - LSB: Start or stop the Mango Automation
      Loaded: loaded (/etc/init.d/mango; generated)
      Active: failed (Result: exit-code) since Mon 2019-08-05 21:50:50 AEST; 6min ago
      Docs: man:systemd-sysv-generator(8)
      Process: 764 ExecStart=/etc/init.d/mango start (code=exited, status=127)
      screenshot:
      below is my mango service file content:
      (i played with the path for the commands but ended up with the same message)
      *#!/bin/sh
      # chkconfig: 235 99 10
      # description: Start or stop the Mango Automation
      ### BEGIN INIT INFO
      # Provides: mango
      # Required-Start: $network $syslog
      # Required-Stop: $network
      # Default-Start: 2 3 5
      # Default-Stop: 0 1 6
      # Description: Start or stop the Mango Automation
      ### END INIT INFO
      start="/vwang/mango/bin/ma.sh start"
      stop="/vwang/mango/bin/ma.sh stop"
      lockfile=/var/lock/subsys/mango
      name='Mango'
      case "$1" in
      'start')
      $start>/dev/null 2>&1 </dev/null
      RETVAL=$?
      if [ "$RETVAL" = "0" ]; then
      touch $lockfile>/dev/null 2>&1
      fi
      'stop')
      $stop
      RETVAL=$?
      rm -f $lockfile
      fi
      'status')
      status Mango
      'restart'|'reload'|'condrestart')
      $stop ; $start
      RETVAL=$?
      echo "Usage: sudo service{ start | stop | restart | reload | condrestart}"
      RETVAL=1
      esac
      exit $RETVAL*
      Please let me know if the service message is correct. If it is not, what do I need to change to make it work.
      Thanks in advance.
        Hi cwangv,
        Are you able to launch Mango from the command line?
        sudo /vwang/mango/bin/ma.sh start ?
        • cwangvC Offline
          cwangv @phildunlap
          @phildunlap
          No, Phil.
          But i can do
          sudo ./mango/bin/ma.sh start.
          I did try using the 'mango/' without '/vwang' in front of it in the mango service file. but same message.
            It sounds like maybe the path to Mango is wrong. Maybe the Mango directory is /home/vwang/mango/ ? Can you share the output of running pwd from wherever running sudo ./mango/bin/ma.sh start worked?
            • cwangvC Offline
              cwangv
              Hi, Phil
              Here is the output:
              vwang@debian-mango:~$ sudo ./mango/bin/ma.sh start
              [sudo] password for vwang:
              MA_HOME is /home/vwang/mango
              vwang@debian-mango:~$ ma-start: MA started with Process ID: 7580
              It started successfully.
              I actually went into the mango service file and added '/home/vwang' into the path. but same message.
              Should at least the service status indication part work even with wrong path for the .sh file?
              thanks.
              • cwangvC Offline
                cwangv @phildunlap
                @phildunlap
                Hi, Phil
                Success!
                In my last reply, I said i added 'home/vwang' in the path of the .sh files but it still didnt work.
                I did a restart after that, and it is working now.
                Here is the output just in case anyone wonders what the 'Ok' message looks like:
                message in text form:
                Active: active (running) since Mon 2019-08-05 23:47:15 AEST; 1min 28s ago
                Process: 797 ExecStart=/etc/init.d/mango start (code=exited, status=0/SUCCESS)
                Tasks: 40 (limit: 2166)
                Memory: 405.7M
                CGroup: /system.slice/mango.service
                ├─ 825 /bin/bash /home/vwang/mango/bin/ma-start.sh
                ├─ 866 java -server -cp /home/vwang/mango/overrides/classes:/home/vwang/mango/classes:/home/vwang/mango/overrides/properties:/home/vw
                └─1984 sleep 3
                Aug 05 23:47:15 debian-mango systemd[1]: Starting LSB: Start or stop the Mango Automation...
                Aug 05 23:47:15 debian-mango systemd[1]: Started LSB: Start or stop the Mango Automation.
                Thanks again for your prompt responses!
                  Glad you got it figured out!
