    Best way to structure for multiple instances of device
    20 Posts 3 Posters 9.6k Views 3 Watching
      I would recommend using points on the Scripting data sources you're using, possibly. They're pretty much the same as no-change virtual points that are already in the script's context. But, again, I do not feel I understand the objectives well enough to make clear advisements.
        pyeager
        Phil:
        Thanks for taking the time to discuss my challenge.
        Our initial implementation will probably include a dozen machines under control of Mango. A full implementation will include somewhere in the range of 100 machines.
        The Modbus I/P data sources are sufficient for controlling the machine, however there are modes, settings, and state variables per machine that must live somewhere. There are also process variables that are shared by groups of machines. A virtual data source per machine seems to be the logical place to put those as I understand the available options. Point links and scripts tie the virtual data source to physical machine (via the Modbus I/P data source) and shared process variables.
        Please let me know if I am missing something.
        I have been working on a script to iterate over a set of data sources, which I hope is the beginning of a scripted data source to implement control logic and sequencing. While I have been able to use DataSourceQuery to obtain a list of data sources, I am having trouble accessing the associated list of data points.
        This code finds the desired set of data sources:
        var sources = DataSourceQuery.query('like(name,polecat*VIRT)&limit(10)');
        for(var i=0; i<sources.size(); i++ ) {
            source = sources.get(i);
            print( source.name );
        However, I have been unable to modify it to access the data points, which documentation indicates should be available through source.points.
        What am I missing?
        Edit: In the documentation at [https://help.infiniteautomation.com/about-mango-java-script], I find this:
        *Data Source Queries
        Data sources can be queried in much the same way. There is one method, DataSourceQuery.query(stringRql); A returned object will contain:
        name - String
        xid - String
        enabled - boolean
        type - String
        points - List<DataPointWrapper>*
        I find that I can reference name, xid, and enabled in my script, but type and points are undefined.
          pyeager
          After further investigation, I find that type doesn't exist, but typeName does. Perhaps a documentation bug?
          While dumping one of the objects returned from DataSourceQuery, I find that points actually does exist, but when I try to reference it, I get "undefined".
            Note: I'm using 3.5.6 until we're ready to upgrade..
            Your query will likely work better if you iterate rather than using get:
            //I'm not confident with the like(name,polecat*VIRT), but hey if it works then good
            for(var i=0; i<sources.length; i++ ) {
                source = sources[ i ];
                print( source);
            You should be able to print(source) and see all the associated datapoints in that datasource, regardless if the datasource is enabled or not. P.s I also found it to be typeName for the type of datasource. Most likely not been updated.
            My advice here that I can give you would be to look at tagging all of the datapoints instead and then using an RQL query to pull them in. Not only will it enable you to better index your point information but will also give you plenty of control over what points you want to pull.
            P 2 Replies Last reply Reply Quote 0
              Thanks for bringing that to our attention! It looks like everything should be working, but there is no getter in the DataSourceWrapper for the points, so its scope is private! It appears to have been this way since it was originally added, but I have fixed it for next release.
              For now, I think the easiest way to work around that would be a function in a global script to do the necessary reflecting to get out the points list. Like...
              function reflectPointsList(dataSourceWrapper) {
                  var pointsListField = dataSourceWrapper.getClass().getDeclaredField("points");
                  pointsListField.setAccessible(true);
                  return pointsListField.get(dataSourceWrapper);
              var dsw = DataSourceQuery.byXid("DS_XID");
              var points = reflectPointsList(dsw);
              print(points)
                @pyeager said in Best way to structure for multiple instances of device:
                Yes, thanks for bringing this to our attention, as well!
                  pyeager
                  Thanks, Phil! That should get things moving.
                  One more thing for your attention....
                  Here is some example code from [https://help.infiniteautomation.com/about-mango-java-script]
                  var points = DataPointQuery.query('like(name, *boiler*)&limit(10)');
                  var average = 0.0;
                  LOG.info('Found ' + points.size() + ' points to compute average.');
                  for(var i=0; i<points.size(); i++){
                      if(points.get(i).runtime !== null){
                        LOG.info('Adding ' + points.get(i).runtime.value + ' to the average.');
                        average = average + points.get(i).runtime.value;
                  return average/points.size();
                  It might be considered a "nitpick", but if any of the data points are disabled, the computation will be incorrect.
                  Why? Because the last line divides by the number of points, not the number of enabled points.
                    pyeager @MattFox
                    @mattfox thanks for the suggestion regarding iteration. It looks much cleaner your way. I just followed the method used in the Mango documentation. Haven't done much javascript for quite a while!
                      Great!
                      Yeah, that may be nitpicky ;). You could so easily count the number of enabled points when you're checking the runtime not being null...
                        Happy to help, my javascript ain't too bad IMO. I've got nothing on Jared or Phil mind you but always here if needed.
                          pyeager @MattFox
                          @mattfox said in Best way to structure for multiple instances of device:
                          Thanks for the suggestion, Matt!
                          However, I have a question.
                          If querying the data source gets me all the points I need, where is the advantage?
                            MattFox @pyeager
                            @pyeager
                            In this case you may have additional info regarding location or logger brand etc etc.
                            Which if in the case of all being in the data sources then that's fine.
                            My other reasoning is prior to tags being introduced, I used to do the same thing and link by name or data sources etc Which is fine for single site installs. But what if you find you suddenly need only some particular devices, or a sensor or something is installed which feeds back in different units or magnitude? Or even you're using a mango unit on multiple locations and need different level access? User permissions can get you so far but you cannot always rely the name of the device being consistently named.
                            My other point is being able to also create generic dashboards that pull data by query rather than individually mapping them. You may be able to individually name them differently, but what if you have the same issues as above? This is where tags are handy.
                            This is my 10 cents. (2 cents plus inflation and tax etc etc..) And in my case I have dozens of sites and users to take into account with their own locations (some shared) and not necessarily using the same hardware we have.
                              pyeager @MattFox
                              @mattfox @phildunlap
                              Where is DataSourceQuery documented? I haven't yet found full documentation for that or much else. I've been figuring things out from the examples.
                                Get yourself into the mangoUI and go to Administration -> Watchlist builder then select query as the watchlist type. It will allow you to put together a query and teach you what parameters are available. That was my go to for the first month or so when I started learning RQL.
                                EDIT: As for the datasource query info, I've not got much. It honestly looks like you use it just to pull datasource property information in order to pull points by it's XID / id.
                                  pyeager
                                  @phildunlap
                                  works perfectly.
                                  Do I understand correctly that it is a workaround until the next release?
                                    Correct, although it should continue to work even in subsequent releases. But, once 3.6.2 is released the concerns raised in this thread will have been fixed,
                                    1. points list not available via .points
                                    2. JavaScript help says type not typeName while .typeName is correct
                                      pyeager
                                      This post is deleted!
