    Mango Speed up on Raspberry
    5 Posts 3 Posters 2.4k Views 3 Watching
    • E Offline
      etantonio
      i wnat to speed up Mango as much as possible on Raspberry and I want to know whick keys I can use.
      For example, I'm not interested to the GUI so I choosed
      concerning the thread I've the following default configuration
      but I've no idea if it is better to change something on it.
      this is thye htop response on normal operation.
      And also, I read somewhere that it is not a good idea to have a database (mysql) over an SD card due to limited number or read/write, is it something you tested?
      Antonio
        Ralf
        Hi Antonio,
        not with a mysql-db but with the Mango noSQL-db without any problem the last two years 24/7 running. Point counts > 3 million in the db.
        But I think the mango system is not the power sd user, it is the OS and so it will be better to put OS system and kodilogs in the ramdisc.
        Also you can turn off swapping to the sd-card. And: buy a quality sd-card.
          Thanks for the testament @Ralf!
          Hi Antonio,
          1. The UI Performance setting only applies to the old UI. The new UI has less backend work in generating the pages.
          2. The thread count settings should be okay. The high priority pool should resize itself appropriately with the default settings and having three threads in the smaller task pools is not going to hurt anything. I'd say keep the default unless you bump into a reason to change.
          3. I would agree with Ralf that you'll probably have better luck using the NoSQL module in the long term. Configuration would still have to be in MySQL or H2, and SD cards certainly can fail (and other catastrophes can befall computer systems, too), but that should be an incentive to off offsite backups and not a barrier to using them.
          • E Offline
            etantonio
            OK, thanks,
            I'll try to backup on a remote server but I don't think I can do this here:
            Maybe I've to create a chron script that daily rsync backup directory on a remote server.
            I'll try also to switch off swap.
            Thanks, Antonio
              Yes, that's a good way to do it.
