md-button text invisible
Hi, I am having problems with an md-button which shows only a white background but not the text inside of it when using it in an info window that shows up when a marker in google maps is clicked.
When used outside the info window the button works ok.
What am I doing wrong?
You are not doing anything wrong, there seems to be a bug in the ng-map library which we use. It's behaving really oddly.
The
<ma-button>component behaves fine, try using that instead -<ma-button label="test"></ma-button> -
@jared-wiltshire said in md-button text invisible:
Thanks for your suggestion, but still having some issues:
With the <md-button> the other buttons' outline at least showed and were clickable in the info-window. Now with the <ma-button> only one button (the first one) shows up (had to use the raised="true" for the text to be visible anyway) but it seems to ignore the rest of the lines of code in the div, as it does not show the other buttons/content (I thought it might be an issue with the size of the info-window but overriding the autosizing is not working either).
@nature-go said in md-button text invisible:
Try adding this to your div to change the AngularJS Material color scheme to white background -
md-colors="::{background: 'background-A100'}"@nature-go said in md-button text invisible:
Your markup is invalid, you haven't closed your
<ma-button>elements correctly. You need a>after the label attribute.
