    Using <ma-state-params
    15 Posts 4 Posters 9.3k Views 4 Watching
      Phillip Weeks
      @craigweb said in Using <ma-state-params:
      <ma-watch-list-parameters id="ac84b0bc-6c9a-4963--3ae644855233" ng-model="designer.parameters" watch-list="designer.watchList" ng-change="updateParams = designer.parameters" ></ma-watch-list-parameters>
      Thank you Thank you I followed your suggestion and got it working correctly now.
        Christophe
        Hello.
        I would like to realize the same thing but it does not work. I have to make a mistake but I do not know
        Page 1 with button
        <md-button id="3cb4a0ad-324b-429e-80d0-6421b1eeeeea" style="position: absolute; left: -8px; top: -6px;" ui-state="'ui.test-recup'" ui-state-params="{dn: RDCR1}"></md-button>
        Page 2 with a dynamic watchlist
        <ma-watch-list-get ng-model="designer.watchList" parameters="designer.parameters" on-points-change="designer.points = $points" id="20969fc2-a491-4616-9130-35a2555b37c2" watch-list-xid="WL_e4a7a8d5-fa26-481d-8cad-adc4b2b4108a" auto-state-params="true"></ma-watch-list-get>
        <ma-watch-list-parameters id="fb3697ef-1e89-4461-aaf3-5681d1bc3087" ng-model="designer.parameters" watch-list="designer.watchList" ng-change="updateParams = designer.parameters" ></ma-watch-list-parameters>
        <ma-gauge-chart id="b43733ee-c528-48a6-99cd-9745036dddb5" style="position: absolute; width: 200px; height: 200px; left: 481px; top: 191px;" point="designer.points | filter:{name:'CoolingValve'}:true | maFirst"></ma-gauge-chart>
        The link does not work
        And on page 2, if I add the parameter in the browser URL it does not work
        Thank you
          Hi Christophe
          To troubleshoot your button open your browser's console and look for errors when you click on the button.
          For your page 2 make sure you registered the page to take parameters as in the picture below:
            Christophe @CraigWeb
            HI @craigweb
            Thanks for your help
            The link of the function button I made a mistake in the link
            The problem would not come from the fact that the expected parameter is Point Hierarchy
            Thank you
              @Christophe It wont work with the "Point hierarchy" parameter type. I suggest using a tag instead. Also I think the parameter names are case sensitive, so DN != dn
                Christophe @Jared Wiltshire
                @jared-wiltshire said in Using <ma-state-params:
                Thanks for your return
                For the tag instead, how to set it up because I don't understand
                Thank you
                  @Christophe Use the "Bulk data point editor" under the administration menu. Select hierarchy folders using the left panel then apply a tag to them using the right panel.
                  • Click this icon 0_1555689095312_1837d971-3c6e-454d-a6fe-6c53678a5c5b-image.png
                  • Enter a tag name
                  • Type the tag value in the column header
                  • Select all the data points in the table by clicking the top checkbox
                  • Click "Start bulk edit"
                  Note this process will change a little in the upcoming 3.6 release.
                    This post is deleted!
                      Christophe
                      @Jared-Wiltshire
                      Hello
                      I try the solution of "Bulk data point editor"
                      but I can not make it work.
                      So I change the "watch list" using the name of the device.
                      It works
                      or maybe my mistake with "Bulk data point editor"
                      Thank you for your help
                        I have no idea what you have tried, you have given me almost no information to go off. Did you try the steps I gave you? At what point did you go wrong? Have you checked that you applied the tags correctly?
                          Christophe
                          Hello
                          Sorry for my lack of explanation
                          • In "Bulk data point edit" creation of the parameter "Regul" with as parameter Regul1 and Regul2 0_1556092361919_Capture1.PNG
                          • In "Edit Menu" on page 2 add in the url "? Regul"
                          • In page 1 buttons creation with parmatre Regul1
                          <md-button id="3cb4a0ad-324b-429e-80d0-6421b1eeeeea" style="position: absolute; left: 32px; top: 20px; width: 97px; height: 42px; text-align: center;" ui-state="'ui.testRecup'" ui-state-params="{Regul:'Regul1'}">Regulateur 1</md-button>
                          • In page 2
                          <ma-watch-list-get ng-model="designer.watchList" parameters="designer.parameters" on-points-change="designer.points = $points" id="20969fc2-a491-4616-9130-35a2555b37c2" watch-list-xid="WL_Test" auto-state-params="true"></ma-watch-list-get>
                          <ma-watch-list-parameters id="17e52579-3f62-4a94-8397-586316fda6d0" ng-model="designer.parameters" watch-list="designer.watchList" style="position: absolute; width: 100%; left: 0px; top: 0px;"></ma-watch-list-parameters>
                          <!--Display Gauge-->
                          <ma-gauge-chart id="b43733ee-c528-48a6-99cd-9745036dddb5" style="position: absolute; width: 200px; height: 200px; left: 291px; top: 131px;" point="designer.points | filter:{name:'CoolingValve'}:true | maFirst"></ma-gauge-chart>
                          Thank
                            HI @Christophe
                            Your watchlist also needs to use the tags in its query:
                            Becarefull, parameters are case sensitive.
                              Christophe
                              @Jared-Wiltshire
                              @CraigWeb
                              Thank you for your help it works perfectly
