Mango no longer starting: Error creating bean wit h name 'tokenAuthenticationService'
So. Here's a new one.
I was working on a Mango machine I installed a week ago, and on a reboot Mango started to give me this "springframework.beans.factory.BeanCreationException: Error creating bean with name 'tokenAuthenticationService'" error.
Originally, I thought maybe my Java was scrambled, so I re installed Java, and I'm running:
java version "1.8.0_211"
Java(TM) SE Runtime Environment (build 1.8.0_211-b12)
Java HotSpot(TM) Client VM (build 25.211-b12, mixed mode)Mango fully started fine, but then started tossing this error on it's own, apparently. I installed, it started, I removed some modules, registered GUID, and then reboot the machine. Now it's giving me this every time it starts up.
I don't want to dump my entire MA.log file, but, well, here's the end of it:
ERROR 2019-04-19T19:27:23,352 (com.serotonin.m2m2.Main.main:142) - Error during
initialization
org.springframework.beans.factory.BeanCreationException: Error creating bean wit
h name 'tokenAuthenticationService' defined in URL [jar:file:/opt/mango/lib/mang
o-3.5.6.jar!/com/infiniteautomation/mango/spring/components/TokenAuthenticationS
ervice.class]: Bean instantiation via constructor failed; nested exception is or
g.springframework.beans.BeanInstantiationException: Failed to instantiate [com.i
nfiniteautomation.mango.spring.components.TokenAuthenticationService]: Construct
or threw exception; nested exception is com.serotonin.ShouldNeverHappenException
: java.security.spec.InvalidKeySpecException: encoded key spec not recognized: f
ailed to construct sequence from byte[]: Extra data detected in stream
at org.springframework.beans.factory.support.ConstructorResolver.autowir
eConstructor(ConstructorResolver.java:283) ~[spring-beans-5.0.10.RELEASE.jar:5.0
.10.RELEASE]
at org.springframework.beans.factory.support.AbstractAutowireCapableBean
Factory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:1266) ~[spri
ng-beans-5.0.10.RELEASE.jar:5.0.10.RELEASE]
Factory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:1123) ~[sprin
Factory.doCreateBean(AbstractAutowireCapableBeanFactory.java:535) ~[spring-beans
Factory.createBean(AbstractAutowireCapableBeanFactory.java:495) ~[spring-beans-5
at org.springframework.beans.factory.support.AbstractBeanFactory.lambda$
doGetBean$0(AbstractBeanFactory.java:317) ~[spring-beans-5.0.10.RELEASE.jar:5.0.
10.RELEASE]
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistr
y.getSingleton(DefaultSingletonBeanRegistry.java:222) ~[spring-beans-5.0.10.RELE
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBe
an(AbstractBeanFactory.java:315) ~[spring-beans-5.0.10.RELEASE.jar:5.0.10.RELEAS
E]
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean
(AbstractBeanFactory.java:199) ~[spring-beans-5.0.10.RELEASE.jar:5.0.10.RELEASE]
at org.springframework.beans.factory.support.DefaultListableBeanFactory.
preInstantiateSingletons(DefaultListableBeanFactory.java:759) ~[spring-beans-5.0
at org.springframework.context.support.AbstractApplicationContext.finish
BeanFactoryInitialization(AbstractApplicationContext.java:867) ~[spring-context-
at org.springframework.context.support.AbstractApplicationContext.refres
h(AbstractApplicationContext.java:548) ~[spring-context-5.0.10.RELEASE.jar:5.0.1
0.RELEASE]
at com.serotonin.m2m2.Lifecycle.springRuntimeContextInitialize(Lifecycle
.java:407) ~[ma-priv-3.5.6.jar:?]
at com.serotonin.m2m2.Lifecycle.initialize(Lifecycle.java:311) ~[ma-priv
-3.5.6.jar:?]
at com.serotonin.m2m2.Main.main(Main.java:138) ~[ma-priv-3.5.6.jar:?]
Caused by: org.springframework.beans.BeanInstantiationException: Failed to insta
ntiate [com.infiniteautomation.mango.spring.components.TokenAuthenticationServic
e]: Constructor threw exception; nested exception is com.serotonin.ShouldNeverHa
ppenException: java.security.spec.InvalidKeySpecException: encoded key spec not
recognized: failed to construct sequence from byte[]: Extra data detected in str
eam
at org.springframework.beans.BeanUtils.instantiateClass(BeanUtils.java:1
82) ~[spring-beans-5.0.10.RELEASE.jar:5.0.10.RELEASE]
at org.springframework.beans.factory.support.SimpleInstantiationStrategy
.instantiate(SimpleInstantiationStrategy.java:117) ~[spring-beans-5.0.10.RELEASE
eConstructor(ConstructorResolver.java:276) ~[spring-beans-5.0.10.RELEASE.jar:5.0
.10.RELEASE]
... 14 more
Caused by: com.serotonin.ShouldNeverHappenException: java.security.spec.InvalidK
eySpecException: encoded key spec not recognized: failed to construct sequence f
at com.infiniteautomation.mango.jwt.JwtSignerVerifier.keysToKeyPair(JwtS
ignerVerifier.java:160) ~[mango-3.5.6.jar:?]
at com.infiniteautomation.mango.spring.components.TokenAuthenticationSer
vice.loadKeyPair(TokenAuthenticationService.java:64) ~[mango-3.5.6.jar:?]
at com.infiniteautomation.mango.jwt.JwtSignerVerifier.<init>(JwtSignerVe
rifier.java:55) ~[mango-3.5.6.jar:?]
vice.<init>(TokenAuthenticationService.java:42) ~[mango-3.5.6.jar:?]
~[?:1.8.0_211]
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstruct
orAccessorImpl.java:62) ~[?:1.8.0_211]
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingC
onstructorAccessorImpl.java:45) ~[?:1.8.0_211]
at java.lang.reflect.Constructor.newInstance(Constructor.java:423) ~[?:1
.8.0_211]
70) ~[spring-beans-5.0.10.RELEASE.jar:5.0.10.RELEASE]
.10.RELEASE]
... 14 more
Caused by: java.security.spec.InvalidKeySpecException: encoded key spec not reco
gnized: failed to construct sequence from byte[]: Extra data detected in stream
at org.bouncycastle.jcajce.provider.asymmetric.util.BaseKeyFactorySpi.en
gineGeneratePrivate(Unknown Source) ~[bcprov-jdk15on-1.60.jar:1.60.0]
at org.bouncycastle.jcajce.provider.asymmetric.ec.KeyFactorySpi.engineGe
at java.security.KeyFactory.generatePrivate(KeyFactory.java:366) ~[?:1.8
.0_211]
ignerVerifier.java:157) ~[mango-3.5.6.jar:?]
~[?:1.8.0_211]
.8.0_211]
.10.RELEASE]
... 14 more
INFO 2019-04-19T19:27:23,352 (com.serotonin.m2m2.Lifecycle.terminate:422) - Man
go Lifecycle terminating...
INFO 2019-04-19T19:27:23,816 (com.serotonin.m2m2.Lifecycle.terminate:571) - Man
go Lifecycle terminated. -
@turbo Just re-installed Mango again, and am going through uploading my config.. So far, no errors, and we seem to be OK.
This one just came out of the blue, though, so I dunno. I'll let the thread know what I figure out about this.
Ok.
Just did this again. I imported a config that I have running on another machine, and.. Crash, with the same error code.
I'm going to go ahead and try importing one device at a time.
All the data points added fine, with no error: This install does have the persistent publisher mapped, but not licensed (although it shoudl be-- I've emailed to get my license fxied abotu that).
The last error message visible is "Initializing H2 connection manager".
Just before it crashed this time, I was getting error 500's on opening point details when I tried to check the import.
Ok.
I've figured this bit out-- Apparently, if you try and import a configuration with the persistent publisher enabled, that seems to cause the errors I was seeing. So, if you get a problem with this, try importing your configs but without the persistent publisher.
Hi Turbo,
Thanks for reporting the resolution! Also in your email you said part of the issue was that the instance was licensed as free, so the persistent publisher was not licensed. Still, it should not prevent startup and such, so that you for bringing it to our attention and I'll see what we can make better from this angle on this issue.
Can you email in the JSON you were trying? Or, was it a database restore? I imported an enabled persistent publisher in 3.5.6 and saw.
I'm not sure what the Persistent TCP publisher has to do with the error you are seeing. It seems to me that one of the system settings
jwt.userAuth.publicKey
orjwt.userAuth.privateKey
were not imported correctly.
