    Rotating Fan
    11 Posts 3 Posters 5.6k Views 3 Watching
      James
      Hello, I'm very new to HTML/CSS/AngularJS. I would like to ask if there is any method to link fan speed to the rotation of image.
        Hi James
        There definitely is a way. If you look at this forum post here : https://forum.infiniteautomation.com/topic/4070/rotate-svg
        Specifically these lines in the code
             <!--Image Ventilateur + Rotation en fonction de valeur vitesse  -->
            <ma-svg class="ventilo" id="a3352242-ae43-409c-9d8d-8ff863353339" ng-include="'/modules/mangoUI/web/img/Perso/Ventilateur.svg'" style="position: absolute; width: 230px; height: 230px; left: 95px; top: 50px;">
                 <div ma-selector="#Pales" ng-class="{'ma-spin-counterclockwise': false, 'ma-spin-clockwise': true}" ng-style="{'animation-duration': 50 / (Vitesse.value - Vitesse.value % 10) + 0 + 's'}"></div>
            </ma-svg>
        The 'speed' of the spin will be the animation-duration as you can see a data points value is being used to calculate the speed of the spin.
          James
          It doesn't work for me for some reasons. here is my code.
          <ma-svg class="ventilo" id="a3352242-ae43-409c-9d8d-8ff863353339" ng-include="'/rest/v2/file-stores/default/drawing.svg'" style="position: absolute; width: 230px; height: 230px; left: 325px; top: 149px;" ng-style="{'animation-duration': 50 / (rotate.value - rotate.value % 10) + 0 + 's'}">
                   <div ma-selector="#Pales" ng-class="{'ma-spin-counterclockwise': false, 'ma-spin-clockwise': true}" ng-style="{'animation-duration': 50 / (rotate.value - rotate.value % 10) + 0 + 's'}"></div>
              </ma-svg>
          Also how to create a class named "ventilo".
            Hi James
            I would suggest brushing up on your HTML and CSS first before trying to do this. Unfortunately, you can't copy that code verbatim.
            You can add your own CSS classes in a <style></style> tag.
            Here are some videos on how to use the ``<ma-svg>``` component.
            I have modified the basic SVG example in the MA examples for you so you can copy it and experiment.
            <ma-get-point-value point-xid="SVG-Demo-Status" point="indicatorStatus"></ma-get-point-value>
            <div layout layout-align="start center">
                <h3 flex>
                    Indicator Status: {{indicatorStatus.renderedValue}}
                </h3>
                <md-checkbox ng-model="page.spin" ng-init="page={}">
                    Reverse the Spin!
                </md-checkbox>
            <ma-svg ng-include="'/modules/mangoUI/web/img/status-panel.svg'">
                <div ma-selector="#indicator" ng-style="{'fill': indicatorStatus.value === 1 ? 'salmon' : indicatorStatus.value === 2 ? 'turquoise' : 'none'}"></div>
                <div ma-selector="#spinner" ng-class="{'ma-spin-clockwise': true}" ng-style="{'animation-duration': 10 + 's', 'transform-origin': '150px 300px'}"></div>
            </ma-svg>
            You can change the animation-duration to a higher value and you will see that it slows down.
            You can then replace the number with a variable and do some maths to change the speed.
            Ignore the transform-origin for now, what it is doing is making sure the actual element that is spinning is spinning on its own axis.
              @James post a link / send me a link to the SVG you are using and I'll help you out.
                James
                Hello, finally I got it worked but any method to make it rotate from its center
                Thank you in advance```
                //your code here
                 <!--- VFD Rotation--->
                    <ma-svg ng-include="'/rest/v2/file-stores/default/case.svg'" style="width: 1000px; height: 800px; position: relative; position: absolute; left: 500px; top: 143px;">
                        <div ma-selector="#image1269" ng-class="{'ma-spin-clockwise': true}" ng-style="{'animation-duration' : 50/(vfd.value - vfd.value%10)+0 +'s','origin': '0px 0px'}"></div>
                    </ma-svg>
                    <ma-point-value id="9cf0c356-f48e-4670-99fc-d78ae9c436bf" enable-popup="hide" style="position: absolute; left: 560px; top: 136px;" point-xid="DP_18b9824d-32a1-4cf2-91a2-7154d30971c6" label="VFD Speed"></ma-point-value>
                    <img id="e18ed833-b486-4919-b33a-9b5a0c86a6ef" style="position: absolute; left: 146px; top: 265px;">
                  Jared Wiltshire @James
                  @james said in Rotating Fan:
                  See Craig's response above, you need a transform-origin.
                  Please post your SVG as requested if you need help with this.
                    @James Thanks for sending the SVG. You need a transform origin like this - style="transform-origin: 190.5216px 113.70395px", that is the x attribute + half the width, and the y attribute + half the height.
                    Full example using your image -
                    <div class="ma-designer-root" id="a0146b73-5624-4797-8227-a61cdbfe640f" style="width: 1366px; height: 768px; position: relative;">
                        <ma-svg id="949e7957-38dc-43b9-932c-97eadd759da3" style="position: absolute; left: 0px; top: 0px;" ng-include="'/rest/v2/file-stores/public/case.svg'">
                            <div ma-selector="#fan" ng-class="{'ma-spin-clockwise': vfd.value > 0}" style="transform-origin: 190.5216px 113.70395px" ng-style="{'animation-duration': 50 / (vfd.value - vfd.value % 10) + 's'}"></div>
                        </ma-svg>
                        <md-slider id="1d33a668-f519-4292-9c17-fe3a8aba4644" style="position: absolute; left: 560px; top: 50px;" ng-model="vfd.value" ng-init="vfd.value = 50"></md-slider>
                        <div id="0400c32f-f356-4099-9bf3-d0c735df0b4f" style="position: absolute; left: 603px; top: 98px;" ng-bind="vfd.value | number:1"></div>
                      James
                      @Jared-Wiltshire Thank you for your help. I still got issues. Fan wont be spinning with
                      and it is not spinning at reading value once I put transform-origin in it.
                      how to pass value into svg?
                      here is my code.
                      <div class="ma-designer-root" id="dfe09a12-af99-46a4-8389-c35987e89466" style="width: 1000.95px; height: 796.938px; position: relative;">
                          <!--- Get Point Value-->
                          <!--- Get VFD--->
                          <ma-get-point-value id="18581801-eeaf-4f9d-bc58-ac2a7879cd3a" style="position: absolute; left: 0px; top: 0px;" point-xid="DP_18b9824d-32a1-4cf2-91a2-7154d30971c6" points="vfd"></ma-get-point-value>
                      <ma-svg ng-include="'/rest/v2/file-stores/default/case.svg'" style="width: 1114.022px; height: 399.399px; position: relative; position: absolute; left: 0px; top: 0px; ">
                                 <div ma-selector="#ahufan" ng-class="{'ma-spin-clockwise': true}" style="transform-origin: 193.24985px 113.670235px" ng-style="{'animation-duration': 50/(vfd.value - vfd.value % 10) + 's'}"></div>
                          </ma-svg>
                        • ma-selector="#ahufan" - this is a different ID to the one that was in the SVG that you sent me
                        • points="vfd" this is wrong, it should be point="vfd"
                          James
                          @Jared-Wiltshire Thank you for you supporting. It works perfectly.
                          Here is my script: :D
                          <!---------Rotation----------->
                              <ma-svg ng-include="'/rest/v2/file-stores/default/case.svg'" style="width: 1114.022px; height: 399.399px; position: relative; position: absolute; left: 150px; top: 180px; ">
                                     <div ma-selector="#ahufan" ng-class="{'ma-spin-clockwise': vfd.value>0}" style="transform-origin: 193.32843px 114.53712px" ng-style="{'animation-duration': 50/(vfd.value - vfd.value % 10) + 's'}"></div>
                              </ma-svg>
