    Calculating Averages across sensors
    Development general discussion
    2
    7
    5.0k
    • K
      Keith
      Is ther a way of taking the output from a group of sensors and performing calculations to produce a virtual type sensor output ?
      Keith
      • M
        That's what the Meta data source is for.
        • K
          Keith
          Ah Ha !!! Went there and had a look, I suspect thats beyond my level,
          Is this what i should get ?
          var currentPoint; var pointListColumnFunctions = new Array(); var pointListOptions; function init() { var pointListColumnHeaders = new Array(); pointListColumnHeaders[pointListColumnHeaders.length] = "Name"; pointListColumnFunctions[pointListColumnFunctions.length] = function(p) { return ""+ p.name +""; }; pointListColumnHeaders[pointListColumnHeaders.length] = "Data type"; pointListColumnFunctions[pointListColumnFunctions.length] = function(p) { return p.dataTypeDescription; }; pointListColumnHeaders[pointListColumnHeaders.length] = "Status"; pointListColumnFunctions[pointListColumnFunctions.length] = function(p) { var id = "toggleImg"+ p.id; var onclick = "togglePoint("+ p.id +")"; if (p.enabled) return writeImage(id, null, "brick_go", "Enabled - click to disable", onclick); return writeImage(id, null, "brick_stop", "Disabled - click to enable", onclick); }; if (typeof appendPointListColumnFunctions == 'function') appendPointListColumnFunctions(pointListColumnHeaders, pointListColumnFunctions); pointListColumnHeaders[pointListColumnHeaders.length] = ""; pointListColumnFunctions[pointListColumnFunctions.length] = function(p) { return writeImage("editImg"+ p.id, null, "icon_comp_edit", "Edit point", "editPoint("+ p.id +")"); }; var headers = $("pointListHeaders"); var td; for (var i=0; i
          Keith
          • M
            Umm, no. And we can't recreate the problem. It's a longshot, but can you try pressing Ctrl+F5 on the page and see if it clears up?
            • K
              Keith
              Hmmm no it didn't make any difference. I suspect the install is at fault its not the only time I have seen the issue. Should reports have anything in it ? when I load the page it just says waiting for localhost, otherwise its blank
              Keith
              • K
                Keith
                Just to close this, it was a Java_home issue, once i sorted the install out everything worked fine
                Keith
