    How to divide or multiply a SNMP Value
    13 Posts 2 Posters 6.4k Views 2 Watching
      Jorge Gonzalez
      some controllers send values that are wrong, because the value came without decimal point, just we have two options:
      Divide for 10 or multiplicate for 0,1
      Please i need the script expresión to get the real value
        Hi Jorge,
        Is that point on the SNMP data source as a numeric data point? If so, there is a multiplier on the point's edit page:
        If this is a meta point as relates to your other thread, you should be able to just add a multiplier into the script your wish to have this apply to, as with the multiply-by-20 you requested in the other thread.
          Jorge Gonzalez
          Phii, I check it, but is Multistate
          In the other thread, tha value is alphanumeric.
          please Your support
          Thanks in advance
            Change the data type to Numeric, then.
              Jorge Gonzalez
                The data type is the type in Mango. The Write Type could still be set to gauge and still permit you to set it (and it would transform it back with the multiplier and augend on the way out). So, it being Numeric will only affect things in Mango.
                  Jorge Gonzalez
                  Phil, I change the type to numeric, i lost the values...0_1544565722588_SNMP Gauge to numeric.png
                    Something else is going on there. You would have been clearly warned that you would lose the point value history of the multistate point when you changed it to numeric. Perhaps that could be improved.
                    But it sounds like those points are not polling. Do you have any events relating to this?
                      Jorge Gonzalez
                      Hello, Phil. I check it and the integers work as numeric but gauge didnt work as numeric
                      Coudl I make a meta data source and add a script that divide in 10 or multiply for 0.1???
                        Hmm. And no events about why it's not working?
                        Yes you can definitely make a meta point and transform the value that way.
                          Jorge Gonzalez
                          see it please, now i change again from numeric type to multistate type. now is working0_1544645824168_Alphanumeric Value_last.png
                          Please could You tellme how to make a script.
                            Please check for a related event on the events page.
                            Doesn't seem like the actual polling for data would be different for the different data types, The only part that is very concerned with the data type of the point is the variableToValue and valueToVariable functions but both of those should be able to handle a Gauge and Numeric. I shared with you the variableToValue function before: https://forum.infiniteautomation.com/topic/3887/snmp-host-testing
                            Create a meta data source. Create a meta data point. Add the point you wish to divide by 10 into context,
                            return p.value / 10; //where p is the variable name of the context point
                              Jorge Gonzalez
                              Thanks so much, with Your script, now it is working... it is the most important thing, because the customer is testing this Scada platform.
                              Soon We will start checking what happen with this controller and them kind of SNMP Data.
                              Again, thanks for Your support
