    NullPointer exception but info not available
    9 Posts 3 Posters 3.7k Views 3 Watching
    • E Offline
      etantonio
      Hy,
      i migrated an H2 database to mysql,
      there's this error about every 10 seconds:
      ERROR 2018-11-12 14:49:38,838 (com.serotonin.m2m2.web.mvc.rest.v1.publisher.pointValue.PointValueWebSocketPublisher.pointUpdated:179) -
      java.lang.NullPointerException
      How I can understand where's the problem?
      Antonio
        Hi Antonio,
        There's probably a stack trace under that logging statement, which would help with trying to understand. I can see that it would be there. https://github.com/infiniteautomation/ma-modules-public/blob/2.8.x/Mango API/src/com/serotonin/m2m2/web/mvc/rest/v1/publisher/pointValue/PointValueWebSocketPublisher.java#L179
        • E Offline
          etantonio
          Hy,
          thanks for your reply,
          I think that e.getMessage() in
          catch (Exception e) {
          			LOG.error(e.getMessage(),e);
          gives only the short description of the exception, not the full stack trace
          in fact in the log I've only a long sequence of :
          ERROR 2018-11-13 14:37:17,874 (com.serotonin.m2m2.web.mvc.rest.v1.publisher.pointValue.PointValueWebSocketPublisher.pointUpdated:179) -
          ERROR 2018-11-13 14:37:27,887 (com.serotonin.m2m2.web.mvc.rest.v1.publisher.pointValue.PointValueWebSocketPublisher.pointUpdated:179) -
          ERROR 2018-11-13 14:37:37,871 (com.serotonin.m2m2.web.mvc.rest.v1.publisher.pointValue.PointValueWebSocketPublisher.pointUpdated:179) -
          ERROR 2018-11-13 14:37:47,886 (com.serotonin.m2m2.web.mvc.rest.v1.publisher.pointValue.PointValueWebSocketPublisher.pointUpdated:179) -
          it seems I've no way to understand which point is envolved.
          In which case the class PointValueWebSocketPublisher.java
          is invoked?
          It is not clear to me if all source code of Mango automation are available on git or just something and if there's a chance for me to debug the code directly on my machine using an eclipse JEE Ide?
          Antonio
            Jared Wiltshire @etantonio
            @etantonio said in NullPointer exception but info not available:
            99% of the core is available on Github and nothing stops you debugging this if you would like to. There is a small component of the code which is private but the jars are available in our Maven repository and will be automatically downloaded by Eclipse.
            That said, I'd recommend upgrading to the latest version of Mango as there has been numerous bugs fixed around WebSockets.
              The second argument is the exception, which logs the stack trace.
              Both the 2.8 core and the 2.8 ma-modules-public repos (which contains the Mango API module) are public. Yes you could clone them, launch Mango with the debugger enabled, and attach to it and debug (see the scripts in Mango/bin/ext-available for enabling the debugger).
              The issue you're asking about was solved at some point in the years of updates since the 2.8 core.
              You could also try launching at the command line in case some error information is escaping to stderr.
              • E Offline
                etantonio
                You are right, "e" gives the full stack trace, it is in sterr and is the following, but it seems there's no info about the point having problem, maybe just in debug I could find it.
                Any suggestion is appreciated
                ERROR 2018-11-14 09:02:10,758 (com.serotonin.m2m2.web.mvc.rest.v1.publisher.pointValue.PointValueWebSocketPublisher.pointUpdated:179) -
                        at com.serotonin.m2m2.rt.dataImage.AnnotatedPointValueTime.getAnnotation(AnnotatedPointValueTime.java:39)
                        at com.serotonin.m2m2.web.mvc.rest.v1.model.pointValue.PointValueTimeModel.<init>(PointValueTimeModel.java:67)
                        at com.serotonin.m2m2.web.mvc.rest.v1.publisher.pointValue.PointValueWebSocketPublisher.pointUpdated(PointValueWebSocketPublisher.java:172)
                        at com.serotonin.m2m2.rt.dataImage.DataPointRT$EventNotifyWorkItem.execute(DataPointRT.java:632)
                        at com.serotonin.m2m2.rt.maint.BackgroundProcessing$1.run(BackgroundProcessing.java:73)
                  I suspect you can find the cause and solution in this git issue: https://github.com/infiniteautomation/ma-core-public/issues/1098
                  You might be able to unzip a current mango-3.5.6.jar and take the AnnotatedPointValueTime class and override it.
                  • E Offline
                    etantonio
                    @phildunlap said in NullPointer exception but info not available:
                    it seems now it is ok,
                    it is necessary to add also the new interface IAnnotated.class.
                    Antonio
                      Once you're modifying the code or overriding things you're accepting responsibility for making decisions about what's necessary.
