    Latest version (3.5.5) appears to fail rendering data
    19 Posts 5 Posters 10.3k Views 5 Watching
      Jared Wiltshire @MattFox
      @mattfox said in Latest version (3.5.5) appears to fail rendering data:
      CORS needs to be enabled to allow proxy based control.
      I don't think this is correct, if it is I think it might be a bug. Can you explain more about your configuration and why you think you need CORS?
        Nothing Worked without it - 3.4.1 wouldn't work with SSL until I turned the cors on. Since it works I'm not tinkering with it:
        My config:
        #Cross Origin Request Handling
        rest.cors.enabled=true
        rest.cors.allowedOrigins=*
        rest.cors.allowedMethods=PUT,POST,GET,OPTIONS,DELETE
        rest.cors.allowedHeaders=content-type,x-requested-with,authorization
        rest.cors.exposedHeaders=
        rest.cors.allowCredentials=true
        rest.cors.maxAge=3600
        Not interested in any more bugs. This didn't work with 3.5.4. Wasn't happy with telling customers that the SSL was broken and they had to knock off the https in order to log in.
        apache2 proxy settings:
        DocumentRoot /opt/mango/overrides/web/modules/mangoUI/web
        SSLProxyEngine On
          ProxyRequests Off
          ProxyPreserveHost On
        # for a http server
        Protocols h2c http/1.1
        ProxyPass /.well-known !
        RewriteEngine on
         RewriteCond %{HTTP:Connection} Upgrade [NC]
         RewriteCond %{HTTP:Upgrade} websocket [NC]
         RewriteRule /(.*) ws://127.0.0.1:8080/$1 [P,L]
        	<Location />
                    ProxyPass http://127.0.0.1:8080/
                    ProxyPassReverse /
                </Location>
        AldoRamosA 1 Reply Last reply Reply Quote 0
        • AldoRamosA Offline
          AldoRamos
          I apologize for not mentioning the proxy. I didn't even think of it, since it had been working previously (and in development I often switch back and forth between proxy and VPN).
          I believe I upgraded from 3.4.1 (no longer have logs to confirm exactly). But I explicitly tested that page before & after to confirm this change in behavior.
          The ma.log shows nothing relevant (no entries except for JSON File Import Job.)
          @MattFox adding CORS configuration made no difference (except locking me out until I opened it up globally).
          Adding the following configuration to the VirtualHost configuration fixes it:
              RewriteEngine On
              RewriteRule /(.*) ws://internal.mangoserver.com:8080/$1 [P,L]
          I apologize for the confusion, but due to some similar issues with another Mango server, I explicitly tested it with this configuration before and after upgrading, which is why I listed the symptoms (and my diagnosis) as I did.
          Bottom line, it's working. Why? uhh.... It's working! ;-)
            AldoRamos @MattFox
            @mattfox Yes, the proxy configuration is exactly what I needed. The CORS configuration didn't seem to help.
              Well at least that's sorted i'm happy. Forgive the irritated post Jared, it's been a difficult few weeks surrounding Mango data handling related issues.
              Edit: The above virtual host config I have there works with l;etsEncrypt so you can just set and forget. Just make sure you add the
              in the SSL version of your config if you have forced redirect to SSL in order for letsencrypt to update
                AldoRamos
                I take it back, @MattFox ; apparently the CORS configuration IS necessary. Suddenly found it failing again, and sure enough enabling CORS did the trick.
                I really do go through these tests in a methodical manner, but somehow I'm losing the sequence today.
                Thanks to all who helped me get through this.
                  I might try and setup a Apache reverse proxy and figure out what is going on here. I still don't think that CORS should be necessary, I believe you that it fixes the problem however I don't think its the correct solution. In fact allowing any origin with allow credentials poses a security risk so I'd like to get it sorted out for you guys.
                    Have you been setting the HTTP origin header in your proxy?
                    We have sites running behind an Apache proxy, and the live-chart on 3.5.5 doesn't seem to have an issue. CORS is not enabled. Here is an example of the Apache config with a wildcard SSL certificate being used,
                    ServerName servername.host.extension
                    ProxyPass / http://172.16.3.4/
                    ProxyPassReverse / http://172.16.3.4/
                    RewriteEngine On
                    RewriteCond %{HTTP:Upgrade} =websocket
                    RewriteRule /(.*) ws://172.16.3.4/$1 [P,L]
                    RewriteCond %{HTTP:Upgrade} !=websocket
                    RewriteRule /(.*) http://172.16.3.4/$1 [P,L]
                    ProxyPreserveHost off
                    RequestHeader set Origin "http://servername.host.extension"
                    Header edit Location ^http://servername.host.extension https://servername.host.extension
                    SSLProxyEngine On
                    SSLEngine on
                    SSLCertificateFile /path/to/host.extension.crt
                    SSLCertificateKeyFile /path/to/host.extension.key
                    SSLCertificateChainFile /path/to/host.extension.ca-bundle
                    ProxyRequests on
                      What version of apache is that? I don't think my version allows some of those settings
                        2.4.x
                        What settings would it not allow?
                          RequestHeader
                            Loading mod_headers in your apache config? https://httpd.apache.org/docs/current/mod/mod_headers.html
                            Or maybe you just need to symlink it into mods-enabled and reload ?
                              That will likely be it, thanks Phil!
