    Release Notes for 3.5.0-beta.1
    Scheduled Pinned Locked Moved Announcements
    1 Posts 1 Posters 990 Views 1 Watching
      MangoBot
      core - Version 3.5.0
      • Adding lastName to User (Not required)
      • Adding data point tags to email template model
      • Adding email template help for email event handlers
      • Adding Apache commons-text 1.4 as dependency
      • Removing Apache commons-lang dependency in favor of commons-lang3
      • Adding ability to format values as hex using AnalogRenderer See renderer help.
      • Adding tags into RealTimeDataPointValue for use in high performance realtime data cache (REST controller access via /realtime endpoint)
      • Creating DAO for user defined filestores, access methods to file store definitions in DAO
      • Fixing data point delete confirmation in all data points table
      • Improve performance and memory footprint of User Event Cache which is used to speed up recent alarm access
      • Fix for class cast error due to annotated point value classes in cache
      • Change JavaScript wrappers to supply null if there is no value, instead of default values false, 0, “” and null on times is no value, like p.past(MINUTE).firstTime could now be null where previously 1
      • Give “add data source” and “add publisher” buttons a tabindex, click it on enter or spacebar when selected
      • Fix for ValueChangeCounter discrete statistic to not assume a value at exactly the period start as a change within the period
      • Fix for Mango JavaScript statistics to handle edge case where a value existing at the from time may have been missed
      • Use XIDs in publisher REST endpoints for points lists
      • Upgrade to Swagger 2 for REST api documentation, view page at /swaggerui.html
      • Fix additional context and unchange point value for inactive scripts on set point handlers
      • Add byXid method to DataPointQuery and DataSourceQuery in script environments
      • Making Log4J configuration fully asynchronous to improve performance
      • Adding system setting for HTTP session timeout, default 48 Hours
      • Adding module definition to let modules add ‘utilities’ to the Mango Javascript context
      • Remove static ‘instance’ member of Dao classes replace with lazy loading getInstance() class so Mango Javascript calls don’t change
      • Check before NPE in CSV message converters
      • Enable JSON import during script validation if set via JsonEmport.setImportDuringValidation(true); in the script
      • Adding RQL keywords csvContainsAll, csvContainsAny, permissionsContainsAll, permissionsContainsAny to query a permissions member, only available in v2 endpoints
      • Control if the point value cache is considered in JavaScript statistics functions, default to not using the cache
      • Fix print( contextPoint ) in script environments to print getStats as function name instead of stats
      • Allow using LOG statements in Event Handler script evaluation
      • Log Switch User events when a user switches to another and back
      • Adding initial support for Passay (www.passay.org) password validation to the backend for full release during the 3.5.x stream
      • Adding ability to set password expiration period, default is to be disabled
      • Implement setPointValue in HistoricalDataPoint, save value unconditionally
      • Bugfix for repeatedly saving the Point Hierarchy creating many data point listeners
      • Shorten description for Data Point event notify work items to reduce memory footprint in large systems.
      advancedComponents - Version 3.5.0
      • Upgraded to work with core version 3.5.x
      advancedScheduler - Version 3.5.0
      • Prevent concurrency bug for terminating a schedule exact at a transition time may not actually terminate the schedule
      asciiFile - Version 3.5.0
      BACnet - Version 3.5.0
      • Adding max master, max info frames and usage timeout settings to MS/TP Configuration to control master polling sequence
      • Adding support for 3rd party realtime mstp linux kernel module
      • Expanding published data type options on BACnet publisher for multistate usability and control if published points are settable
      brewersdashboard - Version 3.5.0
      cloudConnect -
      controlcore - Version 3.5.0
      dashboardDesigner - Version 3.5.0
      dataFile - Version 3.5.0
      • Improve poll class documentation
      • Change 40 character XID restriction to 100 character
      • Validate mapped point exists
      • Export data type as string rather than ID
      • Improve point locator help
      • Export mapped point as XID rather than ID
      dataImport - Version 3.5.0
      dataPointDetailsView - Version 3.5.0
      deviceConfig - Version 3.5.0
      dnp3 - Version 3.5.0
      egauge - Version 3.5.0
      envcands - Version 3.5.0
      excelReports - Version 3.5.0
      • Change resulting report filename scheme from runtime_templateName to reportName_runtime
      • Substring error message to first 512 characters for database column width
      • Bugfix for new UI to resolve error message about help translation being from dashboard designer
      • Modify statistics to use bookend query to handle edge case where there is a value exactly at report from time.
      • Add XLSM file extension into template selector in new UI
      • Validate template when POST’ed to /run endpoint with a time series to be applied
      • Bugfix in TimeSeriesModel translation
      galil - Version 3.5.0
      graphicalViews - Version 3.5.0
      • Bugfix for int conversion failure messages on browsers that allow component positions in sub-pixel precision
      Haystack - Version 3.5.0
      http - Version 3.5.0
      internal - Version 3.5.0
      • Changes to handle Monitor points with null values as this can now happen in Mango 3.5 to indicate a monitor has no information and is not actually 0
      • Escaping HTML in monitor IDs
      jmxds - Version 3.5.0
      jsonFileImport - Version 3.5.0
      log4jDS - Version 3.5.0
      • Fix to allow > 1 data source with the same name to run at the same time
      • IMPORTANT, the log message pattern now matches exactly what you see in the Logging Console UI of Mango so if you use pattern matching you will need to review your pattern
      • Improved regex test utility to show last real log message to test against
      • Add throttling ‘Message repeat interval’ setting to prevent handling identical messages occurring quickly together
      log4JReset - Version 3.5.0
      loggingConsole - Version 3.5.0
      maintenanceEvents - Version 3.5.0
      • Allowing multiple data points to link to an event
      • Allowing multiple data sources to link to an event
      • Adding timeout for Manual type events
      • Adding toggle permission to allow toggling the event if not admin
      • Adding REST endpoints and websockets to manage events
      • Adding monitor point to track count of created Maintenance event configurations
      • Adding custom query for events endpoint to return Maintenance events based on RQL query of Maintenance Event configurations
      • Adding maintenanceEventsUtility to javascript context to allow manipulation of Maintenance Events
      mangoApi - Version 3.5.0
      • Adding ExportCode and ExportCodes models for use in REST api to provide code/id/i18n key and translated description
      • Adding PATCH framework to simplify partial update logic for V2 models, used in new PATCH endpoints
      • Expose tags in realtime endpoint results
      • Adding lastName to user model
      • Fix bug where PUT endpoints were returning the old XID in the location header if the xid was changed (v2/data-points, v2/publishers, v1/data-sources)
      • Allowing null values to be returned in ValueMonitor model
      • Added endpoints for user filestore CRUD
      • Adding v2 point value statistics endpoint at /v2/point-values/statistics/{xids}
      • Use XIDs in publisher points lists
      • Add admin only endpoints in v2 demo rest controller to generate exceptions for testing
      • Restrict json-data POST endpoint to only let users with the global Create JSON Data permission to create new entries
      • Bugfix for /v2/script endpoints to properly return script log/print output
      • Fix bug so GET /v1/translations does not fail and returns all translations
      mangoESConfiguration - Version 3.5.0
      MangoIOTools - Version 3.5.0
      mangoNoSqlDatabase - Version 3.5.0
      • Put fast / slow reload link buttons on new system settings page
      • Improved cancel action responsiveness in merge / migrate / mergrate
      • Improved status request rate in merge / migrate / mergrate / restore
      • Moved corruption scan reports to rolling files, settings in ma.home/classes/log4j2.xml
      • Moved reversible conversion reports to rolling files, settings in ma.home/classes/log4j2.xml
      mangoUI - Version 3.5.0
      mbus - Version 3.5.0
      measurlogicDTSCell - Version 3.5.0
      meta - Version 3.5.0
      • Remove ma.log spam from disabled or missing points at error level with stack trace, now log message at debug level without stack trace
      • Script log rollover at 1MB keep maximum of 5 old files
      • Fix set() function in history generations to save all data passed to set()
      modbus - Version 3.5.0
      • Fix ‘encoding’ in API for serial data source to use RTU / ASCII instead of the translation key in getting the DS JSON
      mqttClientDataSource - Version 3.5.0
      onewire - Version 3.5.0
      opcda - Version 3.5.0
      openv4j - Version 3.5.0
      pachube - Version 3.5.0
      pakbus - Version 3.5.0
      persistent - Version 3.5.0
      • Fix publisher points table message column to displayed sync’ed from time, even on disabled publishers
      • Fix data point’s data type id on edit page to enable manually creating points
      • Flag all points as unreliable if there are no connections to the data source, reliable if a connection exists
      pid - Version 3.5.0
      pointLinks - Version 3.5.0
      pop3 - Version 3.5.0
      reports - Version 3.5.0
      scheduledEvents - Version 3.5.0
      scripting - Version 3.5.0
      • Allow scripting data sources not to have cron patterns, and be driven by events only
      serial - Version 3.5.0
      snmp - Version 3.5.0
      • Change integer type back to signed integers, gauge 32 should be used for unsigned integers
      sqlConsole - Version 3.5.0
      sqlds - Version 3.5.0
      ssh - Version 3.5.0
      • Data type validation on points, check commands are nonempty if settable or queryable
      • Change export to use data type name instead of id number, import support legacy
      • Improve point JSON export to exclude unused fields
      sstGlobalScripts - Version 3.5.0
      sstGraphics - Version 3.5.0
      sstTheme - Version 3.5.0
      TCPIP - Version 3.5.0
      • Improved exception handling for parse exceptions
      • Tune down logging exceptions for things beyond the data source’s control (i.e. connection refused) to debug level
      • Add point locator validation
      templateConfig - Version 3.5.0
      twilio - Version 3.5.0
      virtualDS - Version 3.5.0
      vmstat - Version 3.5.0
      watchlists - Version 3.5.0
      zwave - Version 3.5.0
