    Problem with Pie Chart
    17 Posts 4 Posters 11.2k Views 4 Watching
      So you're telling me the data comes in as comma separated values???
      Could you please output the individual points data line by line so I can see how it sits within your markup?
      • L Offline
        leoboeng @MattFox
        @mattfox said in Problem with Pie Chart:
        I have no more in front of the server for this, and even apologize for my English, I'm from Brazil and here the separation is made by commas (,), in the case of you points (.).
        The values ​​come in the following format, for example:
        Electric_current_Phase_A:
        5.0490
        5.9382
        4.0983
        In my formatting by Mango, it shows as follows:
        5.04 A
        5.93 A
        4.09 A
        That is why I say that the need for units is important to me, in the case of exemple the Amper (A), and this is what has been complicating my Pie Chart.
          So first off, the units come in looking like 5,0490 5,9382 4,0983 the comma for each measurement's decimal place and a space to separate each house. And this is for each datapoint
          Secondly, you only want the units to be 3 significant figures long, without rounding.
          Thirdly, you want to be able to use the Unit on the pie chart.
          I'm I hitting the nail on the head?
          if so, this is how I'd do it and just add the unit to the text.
          A_AtivoDiario_P.renderedValue.split(' ')[0]), text: 'Fase A (A)'
          if it's because it's a string you may have to use parseFloat( A_AtivoDiario_P.renderedValue.split(' ')[0]) )
          With some of this stuff here I sometimes think you over complicate things too much. If what is currently available in mango allows multiple axes gauge charts, that can do the same thing and you can label it as required...
          https://www.amcharts.com/kbase/animating-angular-gauge-bands/
          L 2 Replies Last reply Reply Quote 0
          • L Offline
            leoboeng @MattFox
            So first off, the units come in looking like 5,0490 5.9382 4,0983 the comma for each measurement's decimal place and a space to separate each house.
            Yes that's right.
            The formatting with 3 significant units but I already got it.
            In the pie chart without the Units of Measurements it is possible to make a "point.renderedValue", but when units are added the pie chart does not work.
            So I used the "Slice", as I was shown, it worked about 2-3 days and today started to present that problem.
            • L Offline
              leoboeng @MattFox
              But doing so I would have to take the unit out of the point configuration, correct?
                Don't see how its different from using splice, it's still visible in the text label
                • L Offline
                  leoboeng
                  I tried the following ways and even then continued showing a pie chart in "white"
                  <ma-get-point-value point-xid="DP_530359" point="P_Ativa_A"></ma-get-point-value>
                  <ma-pie-chart id="63759ca9-e465-45e3-80b8-89cda82627fe" style="height: 303px; width: 612px; position: absolute; left: 0px; top: 30px;" values="[{ value: parseFloat( P_Ativa_A.renderedValue.split(' ')[0]), text: 'Fase B', color: 'black' },]" options="{depth3D:15,angle:30}"></ma-pie-chart>
                  <ma-pie-chart id="63759ca9-e465-45e3-80b8-89cda82627fe" style="height: 303px; width: 612px; position: absolute; left: 0px; top: 30px;" values="[{ value: P_Ativa_A.renderedValue.split(' ')[0], text: 'Fase A (A)', color: 'black' },]" options="{depth3D:15,angle:30}"></ma-pie-chart>
                  All two codes showed the graphic in "white":
                  My points are configured as follows:
                  It pulls the data as follows:
                    If your .value has to many decimals use toFixed() to reduce it.
                    values="[ { value: myPoint.value.toFixed(2), text: 'Consumo na Ponta (kW)', color: 'red' }
                    Trying to get the unit on the value seems to be giving more problems than it is worth. Is it not enough to put the unit in the text?
                    • L Offline
                      leoboeng @CraigWeb
                      @craigweb said in Problem with Pie Chart:
                      Yes, but the problem I was facing is that even the decimal place I was able to put rendered, ie the value of the point came with 4 decimal places and just wanted to show 2, but your formula that passed me has already served and worked.
                      It would be nice to have the unit follow up but I'll text it.
                      Ah, thanks for the help.
                        Try this for your text
                        text: 'Phase A ' + myPoint.unit,
                          MattFox @CraigWeb
                          @craigweb that's what I've been trying to get him to do all along. I was going to suggest using toFixed or even parseFloat but he wanted significant figures without rounding.
