    Excel Reports not grouped by datetime
    13 Posts 2 Posters 6.8k Views 2 Watching
      Hi etantonio,
      So, you have multiple data sources with the same polling interval but because the may have started at different instants, the rows in your Excel reports are very close in timestamp but there are many blank cells. Do I understand correctly? Can you post a screenshot of your configuration of the report? Have you tried using a rollup over a 1 minute period, getting the first, start, or last value as the rollup type?
      • E Offline
        etantonio
        • E Offline
          etantonio
          also using 1 minute rollup there are always more rows for the same datetime
          • E Offline
            etantonio
            now it seems ok using
            rollup first 1 minute
            but often I need to start and stop mango after adding new points to the template, otherwise the report is not created
              Can you say more about that? What do you mean the report is not created? It is running forever, or it has an error, or what?
              • E Offline
                etantonio
                the report is running forever, and it seems there aren't errors in the log.
                After Mango start and stop the report is finished
                • E Offline
                  etantonio
                  it seems could be enough also a refresh of the page
                  • E Offline
                    etantonio
                    there's a way to avoid these empty rows?
                    actually these are my settings:
                      It is likely that the point did not have a value recorded in the 1 minute window of the rollup for whatever reason (maybe it didn't poll, maybe it is log on change) and the "First" is defined as the first value within the period, while the "Start" is defined as the value of the point at the start of the period. So, change your rollup to "Start" and those rows will likely contain the values above them repeated in those cells. https://help.infiniteautomation.com/mango-rollups-and-statistics/
                      • E Offline
                        etantonio
                        Start is not available on Mango 2.8,
                        it is possible to obtain the same result in another way?
                        • E Offline
                          etantonio
                          any other idea about how to avoid the first empty row in the report?
                            You could change the logging type of the points to either an interval or interval change type (I am guessing they are currently log on change?).
