    Gauges Function AmCharts
    35 Posts 5 Posters 45.3k Views 5 Watching
      Thanks @MattFox !
        My pleasure @Jared-Wiltshire you guys are awesome. It's the least I could do.
        • L Offline
          leoboeng @MattFox
          @mattfox Ok, and inside the gaugeChart.js file is that code? Because inside the directory / opt / mango / overrides / web / I do not own anything so in case I would have to create and put the files inside as you went correct?
            Correct, you need to create the files and directories
            • L Offline
              leoboeng @MattFox
              @mattfox And what code goes in the gaugeChart.js file? Or does this file copy it from another place that is already ready?
                I posted it about 8/9 posts above ago. https://forum.infiniteautomation.com/topic/3467/gauges-function-amcharts/9#
                • L Offline
                  leoboeng @MattFox
                  @mattfox Thank you very much for your help and sorry for the inconvenience. But I'm still having problems, I did the same thing you said but it did not work. I created the directories and files with the codes and also added the userModule.js to the administration-> UI Settings
                  When I put the code, the gauge goes blank as if it had nothing. I used the same code that you posted here.
                    Can you please use the code tags and output the contents of each of your files?
                    secondly, assuming you're using google chrome, press F12 and take a screenshot of the console for me (use windows snipping tool).
                    We'll go about this one step at a time and you'll have a working multi-coloured gauge in no time!
                    • L Offline
                      leoboeng @MattFox
                      @mattfox in the directory:
                      /opt/mango/overrides/web/modules/mangoUI/web/userModule
                      I have the userModule.js file with the following code:
                      define(['angular', 'require','./directives/gaugeChart.js'], function(angular, require,gaugeChart) {
                      try
                      userModule.directive('gaugeChart', gaugeChart);
                       return userModule;
                      }catch(e){console.log(e);}
                      in the directory:
                      /opt/mango/overrides/web/modules/mangoUI/web/userModule/directives
                      I have the gaugeChart.js file with the following code:
                       * @author Jared Wiltshire
                      define(['amcharts/gauge', 'require', 'angular', './PointValueController'], function(AmCharts, require, angular, PointValueController) {
                      'use strict';
                       * @ngdoc directive
                       * @name ngMango.directive:maGaugeChart
                       * @restrict E
                       * @description
                       * `<ma-gauge-chart point="myPoint" style="width:100%; height:200px"></ma-gauge-chart>`
                       * - This directive will display a gauge that can be tied to a data point's live value.
                       * - You must use `<ma-get-point-value>` to provide a point value to `<ma-gauge-chart>`
                       * - Note, you will need to set a width and height on the element.
                       * - Options have been exposed via attributes, allowing you to set colors and ranges of multiple bands.
                       * - <a ui-sref="ui.examples.singleValueDisplays.gauges">View Demo</a>
                       * @param {object} point The point object with the live value provided by `<ma-get-point-value>`.
                       * @param {number=} value Allows you to set the gauge to a value that is not provided by the `point` attribute. Only use without the `point` attribute.
                       * @param {number=} start Sets the starting value for the gauge.
                       * @param {number=} end Sets the ending value for the gauge.
                       * @param {boolean=} auto-start Set to `true` to enable auto selecting a `start` value for the gauge based on minimum value
                       * from past week.
                       * @param {boolean=} auto-end Set to `true` to enable auto selecting an `end` value for the gauge based on maximum value
                       * from past week.
                       * @param {number=} band-1-end Sets the ending value for the first band.
                       * @param {string=} band-1-color Sets the color for the first band.
                       * @param {number=} band-2-end Sets the ending value for the second band.
                       * @param {string=} band-2-color Sets the color for the second band.
                       * @param {number=} band-3-end Sets the ending value for the third band.
                       * @param {string=} band-3-color Sets the color for the third band.
                       * @param {number=} radius Sets the radius of the axis circled around the gauge. (default: 95%)
                       * @param {number=} value-offset Sets the vertical offset of the value text. Negative moves the value up. (default: -20)
                       * @param {number=} value-font-size Sets the fontsize of the value text. (default: 12)
                       * @param {number=} axis-label-font-size Sets the fontsize of the labels around the axis.
                       * @param {number=} axis-thickness Sets the thickness of the axis circle. (default: 1)
                       * @param {number=} interval Sets the interval for each numbered tick on the gauge. (default: 6 evenly distributed numbered ticks)
                       * @param {number=} tick-interval Sets the interval for the minor ticks. Divide this number into the numbered tick interval to
                       *     get the number of minor ticks per numbered interval. (default: 5 evenly distributed minor ticks per numbered interval)
                       * @param {number=} arrow-inner-radius Radius of the ring the arrow is attached to. (default: 8)
                       * @param {number=} arrow-alpha Opacity of the arrow and the arrow ring. Ranges 0-1 as a decimal. (default: 1)
                       * @param {number=} axis-alpha Opacity of the circular axis. Ranges 0-1 as a decimal. (default: 0.5)
                       * @param {object=} options Extend [amCharts](https://www.amcharts.com/demos/angular-gauge/) configuration object for customizing design of the gauge.
                       * @usage
                      <md-input-container flex>
                          <label>Choose a point</label>
                          <ma-point-list limit="200" ng-model="myPoint"></ma-point-list>
                      </md-input-container>
                      <ma-get-point-value point="myPoint"></ma-get-point-value>
                      <p>Basic (defaults to 0-100)</p>
                      <p>Set axis interval and start and end value</p>
                      <ma-gauge-chart point="myPoint" interval="10" start="-20" end="120"
                      <p>Set color bands</p>
                      <ma-gauge-chart point="myPoint" start="-20" interval="20" band-1-end="20"
                      band-2-end="80" band-2-color="yellow" band-3-end="100" style="width:100%; height:200px">
                      </ma-gauge-chart>
                      function gaugeChart() {
                          return {
                              restrict: 'E',
                              template: '<div ng-class="classes" class="amchart"></div>' +
                              '<ma-point-statistics point="$ctrl.point" point-xid="{{$ctrl.pointXid}}"' +
                              ' from="from" to="to" statistics="$ctrl.pointStats" rendered="false"></ma-point-statistics>' +
                              '<ma-date-range-picker from="from" to="to" preset="LAST_1_MONTHS" update-interval="1 minutes"' +
                              ' style="display: none;"></ma-date-range-picker>',
                              scope: {},
                              controller: GaugeChartController,
                              controllerAs: '$ctrl',
                              bindToController: {
                                point: '<?',
                                pointXid: '@?',
                                start: '<?',
                                end: '<?',
                                autoStart: '<?',
                                autoEnd: '<?',
                                interval: '<?',
                                band1End: '<?',
                                band1Color: '@',
                                band2End: '<?',
                                band2Color: '@',
                                band3End: '<?',
                                band3Color: '@',
                                radius: '@',
                                valueOffset: '<?',
                                valueFontSize: '<?',
                                axisLabelFontSize: '<?',
                                axisThickness: '<?',
                                tickInterval: '<?',
                                arrowInnerRadius: '<?',
                                arrowAlpha: '<?',
                                axisAlpha: '<?',
                                options: '<?',
                                value: '<?',
                                renderValue: '&?'
                              designerInfo: {
                                  translation: 'ui.components.gaugeChart',
                                  icon: 'donut_large',
                                  category: 'pointValue',
                                      width: '200px',
                                      height: '200px'
                                  attributes: {
                                      point: {nameTr: 'ui.app.dataPoint', type: 'datapoint'},
                                      pointXid: {nameTr: 'ui.components.dataPointXid', type: 'datapoint-xid'},
                                      band1Color: {type: 'color'},
                                      band2Color: {type: 'color'},
                                      band3Color: {type: 'color'},
                                      autoStart: {type: 'boolean'},
                                      autoEnd: {type: 'boolean'}
                      GaugeChartController.$inject = PointValueController.$inject;
                      function GaugeChartController() {
                          PointValueController.apply(this, arguments);
                          this.chartOptions = defaultOptions();
                      GaugeChartController.prototype = Object.create(PointValueController.prototype);
                      GaugeChartController.prototype.constructor = GaugeChartController;
                      GaugeChartController.prototype.$onInit = function() {
                          this.updateChart();
                          this.chart = AmCharts.makeChart(this.$element.find('.amchart')[0], this.chartOptions);
                          this.updateChartValue();
                          if(this.autoStart || this.autoEnd) {
                              this.$scope.$watch('$ctrl.pointStats', function(newValue, oldValue) {
                                  if (newValue === undefined) return;
                                  if (this.autoStart) {
                                      this.start = Math.floor(newValue.minimum.value / 10) * 10;
                                  if (this.autoEnd) {
                                      this.end =  Math.ceil(newValue.maximum.value / 10) * 10;
                                  this.updateChart();
                              }.bind(this));
                      GaugeChartController.prototype.$onChanges = function(changes) {
                          PointValueController.prototype.$onChanges.apply(this, arguments);
                          var optionsChanged = false;
                          for (var key in changes) {
                              if (key !== 'point' && key !== 'pointXid' && key !== 'value' && !changes[key].isFirstChange()) {
                                  optionsChanged = true;
                                  break;
                          if (optionsChanged) {
                              this.updateChart();
                      GaugeChartController.prototype.valueChangeHandler = function() {
                          PointValueController.prototype.valueChangeHandler.apply(this, arguments);
                      GaugeChartController.prototype.updateChartValue = function() {
                          if (!this.chart) return;
                          var value = this.getValue();
                          var textValue = this.getTextValue();
                          this.chart.arrows[0].setValue(value || 0);
                          this.chart.axes[0].setBottomText(textValue);
                      //Matt Fox Change 18/5/18
                      GaugeChartController.prototype.checkGaugeBands = function(bands)
                      var hasColour,hasStart,hasEnd;
                      	for( var i=0;i<bands.length; i++)
                      		hasColour = (bands[ i ].hasOwnProperty('color') && /^#(?:[0-9a-fA-F]{3}){1,2}$/.test( bands[ i ] ) )? true : false;
                      		hasEnd = (bands[ i ].hasOwnProperty('endValue') && Number.isFinite( parseFloat( bands[ i ]['endValue']) ) )?true:false;
                      		hasStart = (bands[ i ].hasOwnProperty('startValue') && Number.isFinite( parseFloat( bands[ i ]['startValue']) ) )?true:false;
                      		if( ! (hasColour&&hasEnd&&hasStart) )
                      			console.log("Error: bands not configured correctly, cannot parse values");
                      			return [];
                      	return bands;
                      GaugeChartController.prototype.updateChart = function() {
                          var options = angular.merge(this.chartOptions, this.options);
                          var axis = options.axes[0];
                          var arrow = options.arrows[0];
                          //axis.bands = []; //<-- KEEPS RESETTING MY OPTIONS!!!!
                      	if( axis.bands!==undefined && axis.bands.length > 0 )
                      		axis.bands = this.checkGaugeBands(axis.bands);
                      	else
                      		axis.bands = [];
                          axis.startValue = asNumber(this.start);
                          axis.endValue = asNumber(this.end, 100);
                      	if(axis.bands.length==0)
                      		if (this.band1End != null) {
                      			var stop1 = asNumber(this.band1End);
                      			axis.bands.push({
                      				color: this.band1Color || '#84b761',
                      				startValue: axis.startValue,
                      				endValue: stop1
                      			if (!this.end)
                      				axis.endValue = stop1;
                      		if (this.band1End != null && this.band2End != null) {
                      			var stop2 = asNumber(this.band2End);
                      			axis.bands.push({
                      				color: this.band2Color || '#fdd400',
                      				startValue: axis.bands[0].endValue,
                      				endValue: stop2
                      			if (!this.end)
                      				axis.endValue = stop2;
                      		if (this.band1End != null && this.band2End != null && this.band3End != null) {
                      			var stop3 = asNumber(this.band3End);
                      			axis.bands.push({
                      				color: this.band3Color || '#cc4748',
                      				startValue: axis.bands[1].endValue,
                      				endValue: stop3
                      			if (!this.end)
                      				axis.endValue = stop3;
                          axis.valueInterval = asNumber(this.interval, (axis.endValue - axis.startValue) / 5);
                          axis.radius = this.radius || '100%';
                          axis.bottomTextYOffset =  asNumber(this.valueOffset, -20);
                          axis.bottomTextFontSize =  asNumber(this.valueFontSize, 12);
                          axis.axisThickness =  asNumber(this.axisThickness, 1);
                          axis.axisAlpha =  asNumber(this.axisAlpha, 0.5);
                          axis.tickAlpha =  asNumber(this.axisAlpha, 0.5);
                          if (this.axisLabelFontSize != null) {
                              axis.fontSize = asNumber(this.axisLabelFontSize);
                          if (this.tickInterval != null) {
                              axis.minorTickInterval = asNumber(this.tickInterval);
                          arrow.nailRadius = asNumber(this.arrowInnerRadius, 8);
                          arrow.innerRadius = arrow.nailRadius + 3;
                          arrow.alpha = asNumber(this.arrowAlpha, 1);
                          arrow.nailBorderAlpha = arrow.alpha;
                          if (this.chart) {
                              this.chart.validateNow();
                      function asNumber(value, defaultValue) {
                          if (typeof value === 'number' && isFinite(value)) {
                              return value;
                          } else if (typeof value === 'string') {
                              try {
                                  return parseFloat(value);
                              } catch (e) {}
                          return defaultValue || 0;
                      function defaultOptions() {
                          return {
                              type: 'gauge',
                              theme: 'light',
                              addClassNames: true,
                              axes: [{
                                  startValue: 0,
                                  endValue: 100,
                                  bands: [],
                                  bottomText: ''
                              arrows: [{
                                  nailAlpha: 0,
                                  borderAlpha: 0,
                                  nailBorderThickness: 6
                      return gaugeChart;
                      }); // define
                      I added userModule.js to the administration-> Settings UI page under the url user module as requested.
                      And on the page I put the following code:
                      <gauge-chart id="44cf2d0c-c777-41e0-b20d-ea11a3f9f0cb" style="position: absolute; width: 200px; height: 200px; left: 145px; top: 8px;" point-xid="DP_866585" start="180" end="260"
                        options="{
                      	axes: [ {
                          axisThickness: 1,
                          axisAlpha: 0.2,
                          tickAlpha: 0.2,
                          valueInterval: 5,
                          bands: [ {
                            color: '#cc4748',
                            endValue: 191,
                            startValue: 180
                            color: '#fdd400',
                            endValue: 202,
                            startValue: 191
                            color: '#84b761',
                            endValue: 232,
                            innerRadius: '95%',
                            startValue: 202
                            color: '#fdd400',
                            endValue: 232,
                            startValue: 234
                            color: '#cc4748',
                            endValue: 260,
                            startValue: 234
                          bottomText: '[[value]] km/h',
                          bottomTextYOffset: 0,
                          startValue:180,
                          endValue: 260
                      "></gauge-chart>
                      and continues with this error:
                        Well I can see one bug that a fellow coder pointed out.... As for the error, I'll see if I can arrange something with Jared's latest PointValueController service....
                        What version are you on? I'm not on the latest version right now which will make it hard to debug for,
                        • L Offline
                          leoboeng @MattFox
                          @mattfox said in Gauges Function AmCharts:
                          I'm in the latest version, I had to update because my navigation was not opening some things. Do you have a specific module for this?
                            Awesomeness. I'll get something derived from the latest gauge version and will upload for you to try tomorrow with a bit of luck. Watch this space!
                              Please try replacing the gaugeChart.js code with this:
                               * @copyright 2018 {@link http://infiniteautomation.com|Infinite Automation Systems, Inc.} All rights reserved.
                              define(['amcharts/gauge', 'require', 'angular'], function (AmCharts, require, angular) {
                              	'use strict';
                              	 * @ngdoc directive
                              	 * @restrict E
                              	 * @description
                              	 * @param {object=} point A data point object from a watch list, point query, point drop-down, `maPoint` service, or `<ma-get-point-value>` component.
                              	 * @param {string=} point-xid Instead of supplying a data point object, you can supply it's XID.
                              	 * Only use without the `point` or `point-xid` attribute.
                              	 * from past week.
                              	 * from past week.
                              	 * @usage
                              	</ma-gauge-chart>
                              	gaugeChart.$inject = ['maPointValueController'];
                              	function gaugeChart(PointValueController) {
                              		const asNumber = function asNumber(value, defaultValue) {
                              				return value;
                              				try {
                              				} catch (e) {}
                              		const defaultOptions = function defaultOptions() {
                              			return {
                              				type: 'gauge',
                              				theme: 'light',
                              				axes: [{
                              						startValue: 0,
                              						endValue: 100,
                              						bands: [],
                              						bottomText: ''
                              				arrows: [{
                              						nailAlpha: 0,
                              						borderAlpha: 0,
                              		class GaugeChartController extends PointValueController {
                              			constructor() {
                              				super(...arguments);
                              			$onInit() {
                              				this.updateChart();
                              				if (this.autoStart || this.autoEnd) {
                              					this.$scope.$watch('$ctrl.pointStats', (newValue, oldValue) => {
                              							return;
                              						if (this.autoEnd) {
                              						this.updateChart();
                              			$onChanges(changes) {
                              				super.$onChanges(...arguments);
                              				let optionsChanged = false;
                              				for (const key in changes) {
                              						break;
                              					this.updateChart();
                              			valueChangeHandler() {
                              				super.valueChangeHandler(...arguments);
                              			updateChartValue() {
                              				if (!this.chart)
                              					return;
                              				const value = this.getValue();
                              				const textValue = this.getTextValue();
                              			checkGaugeBands(bands) {
                              				var hasColour,
                              				hasStart,
                              				hasEnd;
                              				for (var i = 0; i < bands.length; i++) {
                              					hasColour = (bands*.hasOwnProperty('color') && /^#(?:[0-9a-fA-F]{3}){1,2}$/.test(bands*)) ? true : false;
                              					hasEnd = (bands*.hasOwnProperty('endValue') && Number.isFinite(parseFloat(bands*['endValue']))) ? true : false;
                              					hasStart = (bands*.hasOwnProperty('startValue') && Number.isFinite(parseFloat(bands*['startValue']))) ? true : false;
                              					if (!(hasColour && hasEnd && hasStart)) {
                              						return [];
                              				return bands;
                              			updateChart() {
                              				if (axis.bands !== undefined && axis.bands.length > 0) {
                              				} else {
                              					axis.bands = [];
                              				if (axis.bands.length == 0) {
                              						axis.bands.push({
                              							endValue: stop1
                              						if (!this.end)
                              						axis.bands.push({
                              							endValue: stop2
                              						if (!this.end)
                              						axis.bands.push({
                              							endValue: stop3
                              						if (!this.end)
                              				if (this.chart) {
                              		return {
                              			restrict: 'E',
                              			scope: {},
                              			bindToController: {
                              				point: '<?',
                              				pointXid: '@?',
                              				start: '<?',
                              				end: '<?',
                              				autoStart: '<?',
                              				autoEnd: '<?',
                              				interval: '<?',
                              				band1End: '<?',
                              				band1Color: '@',
                              				band2End: '<?',
                              				band2Color: '@',
                              				band3End: '<?',
                              				band3Color: '@',
                              				radius: '@',
                              				valueOffset: '<?',
                              				tickInterval: '<?',
                              				arrowAlpha: '<?',
                              				axisAlpha: '<?',
                              				options: '<?',
                              				value: '<?',
                              				renderValue: '&?'
                              			designerInfo: {
                              					width: '200px',
                              					height: '200px'
                              				attributes: {
                              					point: {
                              						type: 'datapoint'
                              					pointXid: {
                              					band1Color: {
                              						type: 'color'
                              					band2Color: {
                              						type: 'color'
                              					band3Color: {
                              						type: 'color'
                              					autoStart: {
                              						type: 'boolean'
                              					autoEnd: {
                              						type: 'boolean'
                              	return gaugeChart;
                              }); //define
                              Next please bring up the browser developer console and take a screenshot for me please, would be good to see if there are any other errors...
                              • L Offline
                                leoboeng @MattFox
                                @mattfox
                                  @leoboeng something is still trying to load a file called PointValueController (no .js on the end). @MattFox latest code that he posted shouldn't be trying to load this file and if it was the file should be named with a .js on the end.
                                    @Jared-Wiltshire thanks for your help, I used the $injected method as you demonstrated in one of my earlier posts. I'll look at the other files pasted above to make sure I haven't fubar'd anthing up! Appreciate the assist
                                    EDIT: actually - think it's caching! @leoboeng when you have the dev console open. please left click and hold the mouse buttong on the refresh page icon in chrome. it should come up with a dropdown that says "Clear cache and hard refresh" or something to that effect. That might be the ticket to get this off the ground!
                                    • L Offline
                                      leoboeng @MattFox
                                      @mattfox I did as you asked and now you're not carrying anything else. It is not coming out of this page.
                                      Message when I press show stack trace
                                      • L Offline
                                        leoboeng
                                        I reinitiated the system, my computer, I changed the browser, tried with another pc but continues with the same problem.
                                          @leoboeng This is an error in your user module file from the looks of it. @MattFox 's latest file he posted looks fine, it's not the cause of this.
                                          You should have two files, both in the public file store, one is your user module and also the file for your new gauge chart component/directive. You should not be overriding any files. Ensure your gauge chart component is given a different name to the built in one (maGaugeChart).
                                          You seem to be struggling with this a little. The ability to add user modules was added so that people who are competent in JavaScript / AngularJS could add and extend the dashboards. It's not something that I would expect everyone to be able to use. Perhaps instead we can look at adding a way to configure more bands on the gauge charts for the next UI module release.
                                            @leoboeng I've added the ability to configure any number of bands for the next release.
                                            Example
                                            <ma-gauge-chart point-xid="zero_to_hundred" bands="[{startValue: -10, endValue: 20, color:'blue'},{endValue: 40, color:'green'},{startValue: 65, endValue: 80, color:'orange'},{endValue: 150, color:'red'}]"></ma-gauge-chart>
                                            L 1 Reply Last reply Reply Quote 1
