    Creating a Schedule Object in BACnet4j
    6 Posts 2 Posters 6.8k Views 1 Watching
      joolz
      I am trying to create a schedule object in BACnet4j using the following (simplified for clarity):
      import com.serotonin.bacnet4j.LocalDevice;
      import com.serotonin.bacnet4j.exception.BACnetServiceException;
      import com.serotonin.bacnet4j.npdu.ip.IpNetwork;
      import com.serotonin.bacnet4j.obj.BACnetObject;
      import com.serotonin.bacnet4j.transport.Transport;
      import com.serotonin.bacnet4j.type.enumerated.ObjectType;
      import com.serotonin.bacnet4j.type.enumerated.PropertyIdentifier;
      import com.serotonin.bacnet4j.type.primitive.Enumerated;
      import com.serotonin.bacnet4j.type.primitive.ObjectIdentifier;
      public class ScheduleTest
      	public static void main(String[] args)
      		try
      			LocalDevice localDevice = new LocalDevice(21, new Transport(new IpNetwork("255.255.255.0")));
      			BACnetObject schedule = new BACnetObject(localDevice, new ObjectIdentifier(ObjectType.schedule, 0));
      			schedule.setProperty(PropertyIdentifier.scheduleDefault, new Enumerated(0));
      		catch (BACnetServiceException e)
      			e.printStackTrace();
      ```However, when I run it, I get this:
      com.serotonin.bacnet4j.exception.BACnetServiceException: class=Property, code=Invalid data type, message=expected class com.serotonin.bacnet4j.type.AmbiguousValue, received=class com.serotonin.bacnet4j.type.primitive.Enumerated
      at com.serotonin.bacnet4j.obj.ObjectProperties.validateValue(ObjectProperties.java:154)
      at com.serotonin.bacnet4j.obj.BACnetObject.setProperty(BACnetObject.java:192)
      at ScheduleTest.main(ScheduleTest.java:21)
      • W Offline
        wang
        Hello community,
        I am also having some troubles with the Bacnet schedule, or there might be something I do not understand.
        Can someone provide a brief example of a working Bacnet schedule object, because I did not find any?
        Thanks in advance.
        • W Offline
          wang
          Up.
          Has no one succeeded to implement this object ?
            joolz
            I have, but BACnet4j doesn't make it straight forward.
            First you need to subclass BACnetObject and make a Schedule object class.
            In that schedule object class, have a local variable for schedule default property.
            In the constructor, set the present value and schedule default properties with this value:
            new AmbiguousValue(new ByteQueue(new byte[]{0}))
            Then override the get() and set() methods, so that if the schedule default property is being set/retrieved, you get it from your local variable instead of the property map.
            • W Offline
              wang
              Sorry to answer so lately, I finally found back my login and password for this site.
              Tank you Joolz, your comment helped me buld a schedule object. I'll try to paste a very basic example when I'll figure out how to put my code into code tag.
