    BACnetTimeoutException: No response from instanceId and Unable to find router to network Unable to find router to network
    4 Posts 2 Posters 3.2k Views 2 Watching
      anandbiradar
      While discovering the BACnet device in my application I get the following errors when running the code below.
      • com.serotonin.bacnet4j.exception.BACnetException: Unable to find router to network 40208
      at com.serotonin.bacnet4j.transport.DefaultTransport$Outgoing.send(DefaultTransport.java:304)
      at com.serotonin.bacnet4j.transport.DefaultTransport.run(DefaultTransport.java:439)
      at java.lang.Thread.run(Thread.java:748)
      • com.serotonin.bacnet4j.exception.BACnetTimeoutException: No response from instanceId 888541
      at com.serotonin.bacnet4j.util.RemoteDeviceFinder$DeviceFutureImpl.get(RemoteDeviceFinder.java:176)
      at com.serotonin.bacnet4j.LocalDevice.getRemoteDeviceBlocking(LocalDevice.java:800)
      at com.serotonin.bacnet4j.LocalDevice.getRemoteDeviceBlocking(LocalDevice.java:744)
      at com.serotonin.bacnet4j.service.unconfirmed.IHaveRequest.lambda$handle$0(IHaveRequest.java:79)
      at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
      at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
      The code I wrote for this looks somewhat like program in attached.
      Could you please let me know what I'm doing wrong and how to avoid these exceptions?
      public static void main(String[] args) throws ServiceException {
              Integer deviceId = 1234;
              String port = 0xBAC0, localBindAddress = "192.168.0.145";
              IpNetworkBuilder builder = new IpNetworkBuilder();
              builder.port(Integer.decode(port));
              builder.localBindAddress(localBindAddress);
              IpNetwork network = builder.build();
              LocalDevice localDevice = new LocalDevice(deviceId, new DefaultTransport(network));
              try {
                  localDevice.initialize();
              } catch (Exception e) {
                  throw new ServiceException("Unable to initialize localDevice", e);
              localDevice.getEventHandler().addListener(new DeviceEventAdapter() {
                  @Override
                  public void iAmReceived(RemoteDevice remoteDevice) {
                      logger.debug("iAm Received from device: {}, NetworkNumber: {}",
                              remoteDevice.getInstanceNumber(),
                              remoteDevice.getAddress().getNetworkNumber()
                      Runnable task = () -> {
                          try {
                              DiscoveryUtils.getExtendedDeviceInformation(localDevice, remoteDevice);
                              SequenceOf<ObjectIdentifier> oids = RequestUtils.getObjectList(localDevice, remoteDevice);
                              for (ObjectIdentifier oid : oids) {
                                  String name = ((CharacterString) RequestUtils.getProperty(localDevice, remoteDevice, oid,
                                          PropertyIdentifier.objectName)).getValue();
                                  logger.info("Found object oid={}, name={} in device {}",
                                          oid,
                                          name,
                              while(true) {
                                      Encodable value = RequestUtils.getProperty(
                                              localDevice,
                                              remoteDevice,
                                              oid,
                                              PropertyIdentifier.presentValue
                                      logger.info("{}={}", oid, value);
                                  try {
                                      Thread.sleep(5_000L);
                                  } catch (InterruptedException e) {
                          } catch (BACnetException e) {
                              logger.error("Error getting values from remoteDevice", e);
                      new Thread(task).start();
              InetSocketAddress addr = InetAddrCache.get("192.168.1.99", IpNetwork.DEFAULT_PORT);
              int port = IpNetwork.DEFAULT_PORT;
              byte[] ipAddress1 = addr.getAddress().getAddress();
              byte[] ipMacAddress = new byte[ipAddress1.length + 2];
              System.arraycopy(ipAddress1, 0, ipMacAddress, 0, ipAddress1.length);
              ipMacAddress[ipAddress1.length] = (byte) (port >> 8);
              ipMacAddress[ipAddress1.length + 1] = (byte) port;
              OctetString macAddress123 = new OctetString(ipMacAddress);
              Address addr1 = new Address(macAddress123);
              localDevice.send(addr1, new WhoIsRequest());
        Hi anandbiradar,
        Have you attempted setting the local network number in the IpNetworkBuilder?
          anandbiradar @phildunlap
          @phildunlap How do i set local network number in IpNetworkBuilder?
            The "withLocalNetworkNumber" function, https://github.com/infiniteautomation/BACnet4J/blob/master/src/main/java/com/serotonin/bacnet4j/npdu/ip/IpNetworkBuilder.java
