    Curious error about systemInfo.txt file not found ?
    6 Posts 2 Posters 3.2k Views 2 Watching
      Phillip Weeks
      On our new ES we are getting this error. There does not appear to be a reason I can find.
      'MangoES System': File not found: /opt/info/systemInfo.txt (No such file or directory)
      yet the file is where it should be and has the following inside:with today's date.
      ##########CPU############
      CPU UserSpace Load: 0.2
      CPU Kernel Load: 0.6
      CPU Total Load: 0.8
      CPU0 Temp: 51.0
      CPU1 Temp: 54.0
      CPU2 Temp: 55.0
      CPU3 Temp: 54.0
      CPU4 Temp: 49.0
      ##########RAM############
      Physical Memory Total: 1991
      Physical Memory Used: 1372
      Physical Memory Free: 618
      Swap Memory Total: 0
      Swap Memory Used: 0
      Swap Memory Free: 0
      ########DISK##########
      Disk Name: /dev/mmcblk0p2
      Disk Total Size: 7149
      Disk Space Used: 1947
      Disk Space Left: 4820
      Disk Percent Used: 29%
      ########SYSTEMTIME############
      SystemTime: Thu Feb 15 20:23:02 MST 2018
        Hi Phillip,
        Only two things come to mind,
        1. Check that the file ownership / read permission is not the issue. (only likely if you get it every poll)
        2. It would be possible for things to be timed such that the ASCII reader tries to read the file at the same instant it is being recreated with new information, in which case there's an instant the file doesn't exist (would happen sporadically, and not be significant).
        So, do the points have new data?
          Phillip Weeks
          It doesn't happen on every poll . I did initially change the file permissions so it wasn't that causing it and the data is updating however the update seems sporadic as well.
            That's the logging type being point value changes I would think. The default poll period is 30 seconds and I believe the file is regenerated at the same interval. If you happened to have started Mango the system info ASCII file data source on a second evenly divisible by 30, I would expect that error to be more likely. But, it shouldn't cause any issue and isn't different than that ASCII data source missing a poll.
              Phillip Weeks
              OK thanks Phil, I might restart it and see if the error continues and I won't worry about it.
                Certainly!
                I meant if the data source started (not Mango) on an second divisible by 30. You can just restart the data source to restart its poll timer.
