    Mango System starts up and operates, but now when I log into the editor the mango system comes to a screeching halt? Any thoughts?
    33 Posts 3 Posters 34.8k Views 3 Watching
      srennhack
      More stack trace information; I cant log on to the editor pages to make any changes or edit what is there.
        Which Mango/bin/ext-available script did you move to Mango/bin/ext-enabled/ ? How much memory are you trying to allocate?
        If it worked a few weeks ago, has anything changed? If nothing changed, is your events table large? Can you try purging it?
          srennhack
          Memory-Large script was move to Mango/bin/ext-enabled/
          How do I purge the events table if I can't get into the editor?
            srennhack
            The last time I was able to get into the editor, I added several new data sources AB PLC ethernet IP links.
              srennhack
              That was probably 3-4 weeks ago.
                I was trying to suss out and ensure you've used the memory-large.bat, not the .sh
                You can purge the events by shutting Mango down, using Mango/bin/h2-web-console.bat (edit to have the -webAllowOthers if you're not working on the machine running this and you need to connect to the web console from another IP) and then running
                delete from userEvents;
                delete from events;
                You can find your login information for the web console in your env.properties file. You may also be able to access the interface if you start Mango in safe mode (by creating the file Mango/SAFE and then starting Mango), as some of your stack traces indicate your scripts may be one of the offenders as well. Then you could purge your events from the Purge Settings section of the system settings page.
                  srennhack
                  OK, shutting down mango, I am not working on the machine running mango right now, but it is right here next to me.
                  so do i need to go through changing the h2-web-console.bat on the mango computer?
                    Yes.
                      srennhack
                      OK I have done that, now how do I connect to the web console from this computer? Remember I'm not a programmer, and am trying to learn as I go here.
                        No worries.
                        @echo off
                        rem
                        rem | Copyright (C) 2006-2015 //infintie Automation. All rights reserved.
                        rem | @author Phillip Dunlap
                        rem
                        rem | Runs H2 Web Console. (Script Version 1.0.0 - To be run from MA_HOME\bin)
                        rem | Define the port to start H2 on...
                        set H2_PORT=8085
                        rem | Check if MA_HOME is properly defined
                        if "%MA_HOME%" == "" goto useCD
                        if exist "%MA_HOME%\bin\ma-start.bat" goto okHome
                        echo The MA_HOME environment variable is not defined correctly: %MA_HOME%. Trying the current directory instead...
                        rem | Check if the current directory is ok to use
                        :useCD
                        set BIN_DIR=%CD%
                        pushd ..
                        set MA_HOME=%CD%
                        popd
                        rem | Don't know where home is.
                        echo Cannot determine the MA home directory
                        goto end
                        rem | Found a good home. Carry on...
                        :okHome
                        echo Using %MA_HOME% as MA_HOME
                        set EXECJAVA=java
                        if "%JAVA_HOME%" == "" goto gotJava
                        set EXECJAVA=%JAVA_HOME%\bin\java
                        :gotJava
                        echo Using Java at %EXECJAVA%
                        rem | Put the whole lib folder on CP because we cannot do h2*.jar...
                        rem | Add -webAllowOthers if you will be using the web console from an origin other than localhost
                        "%EXECJAVA%" -cp "%MA_HOME%\lib\*" org.h2.tools.Server -web -webPort "%H2_PORT%" -baseDir "%MA_HOME%\"
                        :end
                        So -webAllowOthers has been added somewhere on the "%EXECJAVA% line, probably best as ... -web -webAllowOthers -webPort ...
                        Now run the h2-web-console.bat script, and navigate to http://[the computer ip]:8085
                        You can see the port is defined in the script as H2_PORT
                          srennhack
                          ok in the H2 port.
                            srennhack
                            I have been out of the office for several weeks, and am just getting back to this. I am still unable to get into the developer without the mango system freezing up. Here is a screen shot of when I tried to go into the reports at 12:08 today. The hard drive seems to be searching constantly never stops.![alt text](0_1515779257538_Capture.PNG image url)
                              Hi srennhack,
                              Of the steps I have offered, which have you done? Did you purge your events tables?
                              Do you still have out of memory errors in your Mango/logs/ma.log file?
                                srennhack
                                The only step not tried is starting Mango in the safe mode. I did not see out of memory errors today.
                                  Ah. I asked because there events didn't load in your header in the screenshot, which would lead me to believe you still have a very large events table (or you recently purged and have no events in the events table). The exception from the Meta point is unrelated to the performance issue beyond its being an event. How large is your events table currently?
                                  You can try purging your audit table too, running DELETE FROM audit; either in the H2 web console or in the SQL console page.
                                  There can be a caching issue on the excel reports page sometimes where the first time you load the page it doesn't pull up the list of templates. If you refresh this almost always brings up the list.
                                  If the hard drive is going crazy, is it with reads or writes? If you have tons of meta points running often doing .past(MINUTE, 5) type operations, that would be a heavy read load. There are solutions to convert that over to using the cache. If you have lots of point values waiting to be written (check this on your /internal/status.shtm page), you can adjust the NoSQL settings to delay more for small batches and increase the small batch size.
                                    Also, you can get the actual text of the stack traces you wish to post from the Mango/logs/ma.log or Mango/bin/logs/ma.log file. it's a lot better than screenshots of command prompts.
                                      srennhack @phildunlap
                                      @phildunlap
                                      I guess I am just confused that the Mango data collection and screens that were created prior to Nov. of last year all work perfectly fine upon a restart of the system. And it is only when I try to go into the developer that everything stops working? I did create some reports back in Oct of last year that read string files from the AB PLC, and they are checking those points every 30 seconds. and the report is setup for a past 24hr period. and that all worked fine also up until the point that the Java system was upgraded, which appears to be the point where the problems accessing the Mango development screens started to occur. What can I give/send you that might help in resolving this? I don't feel that I am explaining things correctly, and not being a computer programmer, I am mostly lost with what you are telling me. as I don't know how to or where to access some of the files and setups you have described. I apologize for my lack of knowledge in this area.
                                        No worries. It is a lot easier to provide support if you are able to get text from your ma.log file. What are you unaware of how to access? You are navigating around the Mango/ directory in a Windows explorer, correct? Your ma.log file is the place to start. Any path I provide that begins with Mango/ is in your Mango's root directory, which it'll say it's using as MA_HOME during startup.
                                        I don't know what you mean "the developer" as a location. It's best to take your nouns from the program, as then we're on the same page.
                                        I would guess the upgrade to Java was incidental. If you were using a JDK, and are still, that's probably not the problem.
                                          @phildunlap
                                          Log file attached
                                          [0_1516188987376_ma.log.5.5](Uploading 100%)
                                          At about 8:04 yesterday i tried to log into the mango system to try and edit, but at that point everything stopped, and I had to restart the system.
                                            The log didn't upload. You need to wait for it to turn into a link in the preview section. I have the greatest luck with the "upload file" button above the composition window.
