    How to automatically start Mango in a systemd based Linux OS
    5 Posts 4 Posters 4.9k Views 5 Watching
      aoliver
      Some Linux distributions as CentOS or RedHat are migrating from systemV init type to the newest systemd.
      If this is your case, you will need to do as follow to make Mango runs with every system startup:
      Create a mango.service file:
      touch /etc/systemd/system/mango.service
      chmod 664 /etc/systemd/system/mango.service
      Edit the new file so it contains the following:
      [Unit]
      Description=Mango Daemon Service
      After=network.target
      After=network-online.target
      [Service]
      Type=forking
      ExecStart=/opt/mango/bin/ma.sh start
      ExecStop=/opt/mango/bin/ma.sh stop
      ExecReload=/opt/mango/bin/ma.sh restart
      PIDFile=/opt/mango/bin/ma.pid
      [Install]
      WantedBy=multi-user.target
      NOTE: You will need to point the mango directory path to whatever your MA_HOME is.
      Reload systemd configuration files:
      systemctl daemon-reload
      Add mango to systemd, so it runs on every system startup:
      systemctl enable mango.service
      That's it. Now you can manage the Mango service with the following shell commands:
      systemctl [start|stop|reload|status] mango
      Good luck!
      Editted by Phil: original PIDFile entry --> PIDFile=/opt/ambilogger/bin/ma.pid, edited from ambiguity in: https://forum.infiniteautomation.com/topic/3179/centos-7-systemd-startup-failing
      danD 1 Reply Last reply Reply Quote 1
        I'll add an Upstart script for Ubuntu, I have been using this with Ubuntu 14.04. This one lets you run mango as a non-root user. Restart doesn't work too well as ma-stop.sh doesn't stop Mango immediately.
        From Ubuntu 15.04 onwards systemd is used instead of Upstart so dont use this script.
        # mango - Mango Automation
        # Mango Automation is a Java web app for monitoring and logging data sources
        description     "Mango Automation"
        start on (local-filesystems and net-device-up IFACE=eth0)
        stop on runlevel [!2345]
        #respawn
        #respawn limit 10 5
        umask 002
        setuid mango
        setgid mango
        env MA_HOME=/opt/mango
        export MA_HOME
        console log
        script
                . "$MA_HOME"/bin/ma-init.sh
                export JPDA EXECJAVA JAVAOPTS SYSOUT SYSERR
                exec "$MA_HOME"/bin/ma-start.sh
        end script
        pre-stop script
                "$MA_HOME"/bin/ma-stop.sh
        end script
          Phillip Weeks @Jared Wiltshire
          @Jared-Wiltshire
          Hi Jared I am wondering if you would generate a systemd script for our Ubuntu 16.04 LTS and show it here as the one provided above complains of an error when I tried this script in our system?
          I Appreciate any help on this.
          • danD Offline
            dan @aoliver
            @aoliver This worked for me on a RPi3 thanks!
            • danD Offline
              dan
              @aoliver said in How to automatically start Mango in a systemd based Linux OS:
              although, this PIDFile=/opt/ambilogger/bin/ma.pid should be /opt/mango/bin ;-)
