    Import javascript library
    sciptingjavascript
    98 Posts 3 Posters 205.6k Views 2 Watching
      arvand.owji @phildunlap
      Are you saying when you had the page open in a browser?
      I am certain the HTTP retriever is basically treating it as text content for regex parsing, yes. It doesn't treat it as a webpage and execute its content.
      running the script through another browser is not an option. Any other ways you can think of? Thanks.
        arvand.owji @arvand.owji
        @phildunlap how about running the url through something like phantomjs from command prompt?
          I don't have experience with phantomjs but it looks like it might work. It will at least execute the JavaScript. It should be the same idea as using node, right?
          A 2 Replies Last reply Reply Quote 0
            Well,i just tried phantom and it wont work as it does not have arm distribution. I will tried node.js see what happens.
              @phildunlap now with Node.js i need to convert my html file that references java script inside to full javascript!
                @phildunlap do we have any sample javascripts that cna be used in node.js that use mangoapi? like retrieving values by XID and setting values? Thanks.
                  Yeah you might be able to get what you're looking for from the tests we've implemented in node: https://github.com/infiniteautomation/node-mango-client
                    @phildunlap Thanks. I get this error when i try to run the example:
                    $node example.js
                    (node:24509) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 1): Error: connect ECONNREFUSED 127.0.0.1:8443
                      You would have to point it at your running Mango instance and port. It's from this section of example.js:
                      const client = new MangoClient({
                          protocol: 'https',
                          host: 'localhost',
                          port: 8443,
                          rejectUnauthorized: false
                            protocol: 'https',
                            host: 'localhost',
                            port: 8443,
                        Its running locally on the same box. shouldnt localhost be enough? Thanks
                          No. It is using the HTTP API which is over TCP/IP and all TCP/IP connections require an address and a port. Edit: yes localhost is the host if its the same machine (usually, localhost means 127.0.0.1 usually)
                            ok, so im on the same machine and tried the local ip of the machine and still the samething.
                            Unhandled promise rejection (rejection id: 1): Error: connect ECONNREFUSED 192.168.1.125:8443
                            ami i missing something?
                              Mango is not running on port 8443?
                                mmm, where can i check it?
                                  It's the web.port property in your Mango/overrides/properties/env.properties file or Mango/classes/env.properties files as "web.port". Judging from your earlier port of the HTTP Retriever data source, it's 85, but i have no way of knowing. It's 8080 by default.
                                    ok, web.port=8080 but i still get the same error as before.
                                    $node example.js
                                    (node:7075) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 1): Error: connect ECONNREFUSED 192.168.1.125:8080
                                      Mango is probably not running. Connection refused means the port isn't open.
                                        I know it does as i can login into the web admin panel.
                                          Is https://192.168.1.125:8080 typed into your address bar?
                                          Edit: In the end HTTP localhost 80 prevailed
                                            ok, i managed to get it working on port 80 and also changing https to http.
                                            Now i see only getValue function in datapoints.js. Is there any sort of setValue function available? Thanks.
