Unable to add bacnet points in demo
Can anyone tell me how to enable 3 bacnet points in demo mode? Before the 3. Upgrade it was simple or I could purchase the bacnet module 4 $50.
What is your specific issue. You can add BACnet points just as before via the Data Sources Page. The You can't purchase the BACnet module separately in Mango 3 but the demo is now limited to 300 data points.
As always, thank you for the fast response Joel. When I go to the add data sources page, the mango you are reports a server error and a licensing issue. I created an additional account with a new email address and installed a a clean copy of the software. Still reports server error when I try to add data sources
Edit=
I do see modbus is available to add data points but bacnet is not in the drop-down menu. Perhaps I have not added the modules correctly? -
In addition I sent you question about volume licensing for software only to your email address
Can you provide the error from the log file and a screen shot of the error you see.
That would be strange that BACnet would not in the list. You can look at Administration > Modules to see if it's installed and use the "Check for upgrades" button to find and install it if you need to.
