    Sending JSON objects via MQTT
    jsonmqtt
    12 Posts 3 Posters 10.3k Views 4 Watching
      Hi Silvia,
      Huh, that's confusing. I notice that in the first error provided the key M001 doesn't exist, for some reason it is "meterOne" then in the second it makes sense it didn't think {"timestamp":1499679891268,"reading":2000} was a string. It seems like the whole value path may be different by the page spacing (looks like your second path is longer), but we can't see the value path in the second image.
      The first error image probably just means key not found in the object, but the error messaging does look like it has room for improvement.
      Perhaps Jared or Will can advise you on how to do that dashboarding. It's going to have to involve parsing the string value into an object... some JSON.parse() type thing.
        @silvia said in Sending JSON objects via MQTT:
        If the JSON value path is set to '$.M001', this is the error received:
        ERROR 2017-07-10T10:43:04,379 (com.infiniteautomation.m2m2.mqtt.client.MqttClien
        tDataSourceRT.messageArrived:415) - Error during read topic: "test/array2" datap
        oint: "RPi - M001_RPi" payload: "{"M001":{"timestamp":1499679891268,"reading":20
        00},"M002":{"timestamp":1499679891268,"reading":3000}}" exception: "com.serotoni
        n.json.type.JsonObject cannot be cast to com.serotonin.json.type.JsonString"
        This would be because the data type is set to Alphanumeric while the JSON path you specified is for an object. If you set the datatype to plain it doesn't try and parse the JSON so it works.
        As Phillip said, check your usage of meterOne vs M001
        Re. parsing out the individual components of the JSON object on the dashboards, I'd recommend not doing this, you wont be able to use the datapoints effectively on any of the Mango pages.
          silvia @Jared Wiltshire
          @phildunlap and @Jared-Wiltshire, thank you both for your replies.
          The issue with M001 vs meterOne isn't there anymore, at some point I decided to change the identifier to see if that was the problem, and I screenshoted some old error. Apologies for that. As you can see, when everything is named M001, the same error appears:
          ERROR 2017-07-17T09:18:36,296 (com.infiniteautomation.m2m2.mqtt.client.MqttClien
          oint: "RPi - M001_RPi" payload: "{"M001":{"timestamp":1500279612733,"reading":20
          00},"M002":{"timestamp":1500279612733,"reading":3000}}" exception: "ERROR"
          @Jared-Wiltshire said in Sending JSON objects via MQTT:
          Any alternatives to this? Is there any other format / data type that would allow me to send similar data (a meter identifier, a reading and a timestamp) x 4?
          Thanks and regards.
            @silvia what exactly are you trying to achieve? If the goal is to simply read the two values into Mango then create two data points, both with Data type set to Numeric. The Topic type should be JSON and the JSON value path should be $.M001.reading for one, and $.M002.reading for the other. If this doesn't work then there may be a bug in the MQTT datasource.
              silvia
              Hi @Jared-Wiltshire,
              Yes, my objective is to read them and then compare the M001.reading with the previous one, see which is the increment (if any), plot it, etc.
              I've configured new datapoints as instructed (same for M002):
              ...and these are the errors thrown:
              ERROR 2017-07-18T09:19:19,813 (com.infiniteautomation.m2m2.mqtt.client.MqttClien
              tDataSourceRT.getJsonValue:375) - ERROR
              oint: "RPi - RPi_M001_reading_new" payload: "{"M001":{"timestamp":1500366055687,
              "reading":2000},"M002":{"timestamp":1500366055687,"reading":3000}}" exception: "
              ERROR"
              ERROR 2017-07-18T09:19:19,954 (com.infiniteautomation.m2m2.mqtt.client.MqttClien
              oint: "RPi - RPi_M002_reading_new" payload: "{"M001":{"timestamp":1500366055687,
              ERROR"
              I'm afraid that there's a bug in the MQTT datasource.
              Would any of you guys be able to have a look into it?
                silvia
                Hi @Jared-Wiltshire , @phildunlap
                Have any of you had a chance of looking into this bug?
                Cheers :)
                  Jared Wiltshire @silvia
                  @silvia Sorry there hasn't been any follow up. We have been sending a few emails backwards and forwards about this. I'll see where we got to and reply back today.
                    I have sent you an email Silvia!
                      silvia
                      Thanks @phildunlap , I'll try what you've sent me asap and post the results back here :)
                        @silvia We have made a v3.1.2 release of the MQTT data source which should rectify the issues you were experiencing.
                        There we some bugs around referencing values inside JSON objects so we decided to switch the notation over to the JSON pointer spec. Your existing points with $. type notation will be automatically converted and hopefully should just work.
                        I've added a help document to the data point edit page for MQTT too (click the blue help icon).
