    <ma-pie-chart example does not work?
    9 Posts 3 Posters 2.8k Views 3 Watching
      Phillip Weeks
      This example copied straight from the pie chart example in the API docs does not render anything in the play area.
      <ma-pie-chart style="height: 300px; width: 600px" values="[{ "value": 30, "text": "hot", "color": "#ff9300" }, { "value": 70, "text": "cold", "color": "#942192" } ]"
      options="{depth3D:15,angle:30}"></ma-pie-chart>
        Hi Phillip,
        Huh, that's not what it looks like inside my API Docs tab for ma-pie-chart from Mango 3. I see this:
        <ma-pie-chart style="height: 300px; width: 600px" values="[ { value: 30, text: 'hot', color: '#ff9300' }, { value: 70, text: 'cold', color: '#942192' } ]"
        The error in the one you posted is probably the double quote around the values object while double quoting all the keys / values inside it too. I see
          Phillip Weeks
          Thanks Phil, it was a cache issue causing the pie-chart not to render.
          My goal is to input 2 stats objects values as inputs for the value field of the values array list. I do not understand how to pass the parameter correctly..
          <ma-point-statistics point="points[0]" from="from" to="to" statistics="statsObj1"></ma-point-statistics>
          <ma-point-statistics point="points[1]" from="from" to="to" statistics="statsObj2"></ma-point-statistics>
          <ma-pie-chart style="height: 300px; width: 600px" values="[ { value: statsObj1.sum.value, text: 'hot', color: '#ff9300' }, { value: statsObj2.sum.value, text: 'cold', color: '#942192' } ]"
          I believe this breaks because statsObj2.sum.value is returning a string that has the unit descriptor. ie. "251.00 LP5M" and value expects a number which I do not know how to convert to 251 inside the directive as in {{statsObj2.sum.value | limitTo:5}}
          can I use <ma-calc here somehow?
            Assuming you are running Mango v3, you can add rendered="false" to <ma-point-statistics> to get the stats as a number rather than a string.
            Sorry some of our documentation is not quite up to date, we are working on that for the UI 3.0.2 release.
              Phillip Weeks
              Well that would be another good reason to move to mango 3
              We are v2.8 and this is my wip dashboard .. can't I simply convert the string to a number somehow and enter that value?
              0_1494947320817_upload-b070560f-ecd1-4d52-bc4c-f4508a514440
                I suspect this thread may have a workaround for you: https://forum.infiniteautomation.com/topic/2700/problem-with-statistics/9
                It uses the slice() function on the value.
                  Phillip Weeks
                  OK look like what I need. the number with suffix is "250.50 LP5M"
                  OMG this actually worked thank Gawd.. And thank-you for your help guys. :)
                  <ma-pie-chart style="height: 300px; width: 40%" values="[ { value: statsObj1.sum.value.slice(0,-5), text: 'hot', color: 'orange' }, { value: statsObj2.sum.value.slice(0,-5), text: 'cold', color: 'blue' } ]"
                  	options="{depth3D:15,angle:30}"></ma-pie-chart> <br>
                    Try
                    <ma-pie-chart style="height: 300px; width: 40%" values="[ { value: statsObj0.sum.value.split(' ')[0], text: 'hot', color: 'orange' }, { value: statsObj1.sum.value.split(' ')[0], text: 'cold', color: 'blue' } ]" options="{depth3D:15,angle:30}"></ma-pie-chart>
                    Meaning no parseFloat(), no number(), no {{ }}, and I don't think you can assign to a variable name like 'statsObj[0]' since that has the meaning item "0" in the statsObj obj (which is probably a list index). Although from your earlier post it looks like the points are the ones in a list? So that's an issue, the name for the statsObj is different in the ma-point-statistics tags earlier in the thread.
                      Phillip Weeks
                      Yes that was it... :) Works with both methods. I like split better. Yes that was just me trying the statsObj array output as well as individual point method to see if there was a difference in how it worked. Thanks again Guys.
