Not seeing chart data
This may seem trivial. But I can't see any chart data on my Angular screens. Is this a permissions issue or did I screw up the code?
@copyright 2016 {@link http://proxyem.com|PROXYEM LLC.} All rights reserved.
@author Christopher Atkins
--><!DOCTYPE html>
<html lang="en"><!-- USER INPUT SECTION -->
<!--vvvvvvvvvvvvvvvvvvvvvv--><!-- Instructions:
1)-->
<!-- BUILDING NAME and assign it to an output variable "bldgName" --> <div ng-app="" ng-init=" meter1Name= '032 POWER East'; meter2Name= ''; meter3Name= ''; meter4Name= ''; meter5Name= ''; tempPoint= 'DP_749465'; homeBtnRef='dashboard.section1.page1'; powerBtnRef='dashboard.section1.page1p'; heatingBtnRef='dashboard.section1.page1h'; coolingBtnRef='dashboard.section1.page1c'; waterBtnRef='dashboard.section1.page1w'; CHANGE= 'CHANGE ONLY IF NECESSARY vv'; utilName='Power'; gaugeName='Live Power Factor'; realTimeName= 'Live Amps'; header1= 'Energy Use'; header2= 'Monthly Energy Use'; header3= 'Power Quality'; header4= 'Weather'; header5= 'BTU Energy'; label1= 'kW'; label2= 'kWh'; label3= 'Amps'; label4= 'Volts LL'; label5= 'Volts LN'; label6= 'PF'; label7= 'kVar'; label8= ''; label9= ''; label10= ''; label11= ''; label12= ''; switchlabel= 'Weather'; disclaimer1= 'Values represent present day'; disclaimer2= 'Values represent month to date'; disclaimer3= 'Low value represents month to date'; angularcspcss='/resources/angular-csp.css'; angularmaterialcss='../../../../vendor/angular-material/angular-material.css'; materialiconscss='../../../../vendor/material-design-icons/iconfont/material-icons.css'; mdpickerscss='../../../../vendor/mdPickers/mdPickers.css'; vitalitycss='/modules/dashboards/web/demo/styles/vitality.css' "><!--^^^^^^^^^^^^^^^^^^^^^^^^-->
<!-- USER INPUT SECTION --><!-- NO TOUCHY NO TOUCHY NO TOUCHY NO TOUCHY NO TOUCHY -->
<!--vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv-->
<!--vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv--><!-- SERVER SIDE QUERIES SECTION -->
<!--vvvvvvvvvvvvvvvvvvvvvv--><!--vvvv WEATHER SWITCH vvvv--> <div ng-init="myVars={}"></div> <div ng-if="showFourth"> <ma-get-point-value point-xid={{tempPoint}} point="myVars.temp"></ma-get-point-value> <ma-point-values point="myVars.temp" values="myVars.tempValues" from="from" to="to" rollup="AVERAGE" rollup-interval="15 minutes" limit="1000"></ma-point-values> </div> <!-- reset the variables to undefined when the switch is turned off --> <div ng-if="!showFourth"> <ma-calc input="undefined" output="myVars.temp"></ma-calc> <ma-calc input="undefined" output="myVars.tempValues"></ma-calc> </div> <!--^^^^ WEATHER SWITCH ^^^^--> <!-- Server side query for points with given device name, and server side sort --> <ma-point-query query="{deviceName:deviceName}" sort="'name'" points="points"></ma-point-query> <ma-get-point-value points="points" from="from" to="to" rollup="AVERAGE" rollup-interval="15 minutes"></ma-get-point-value> <!-- Client side filter by name --> <ma-calc input="points | filter:{name:'KWH'} | first" output="energy"></ma-calc> <ma-calc input="points | filter:{name:'Amps A'} | first" output="currentA"></ma-calc> <ma-calc input="points | filter:{name:'Amps B'} | first" output="currentB"></ma-calc> <ma-calc input="points | filter:{name:'Amps C'} | first" output="currentC"></ma-calc> <ma-calc input="points | filter:{name:'Volts AL'} | first" output="voltageAB"></ma-calc> <ma-calc input="points | filter:{name:'Volts BL'} | first" output="voltageBC"></ma-calc> <ma-calc input="points | filter:{name:'Volts CL'} | first" output="voltageAC"></ma-calc> <ma-calc input="points | filter:{name:'Volts AN'} | first" output="voltageAN"></ma-calc> <ma-calc input="points | filter:{name:'Volts BN'} | first" output="voltageBN"></ma-calc> <ma-calc input="points | filter:{name:'Volts CN'} | first" output="voltageCN"></ma-calc> <ma-calc input="points | filter:{name:'KW'} | first" output="kW"></ma-calc> <ma-calc input="points | filter:{name:'KVAR'} | first" output="kVar"></ma-calc> <ma-calc input="points | filter:{name:'PF'} | first" output="powerFactor"></ma-calc> <!-- <ma-point-values point="temp" values="tempValues" from="from" to="to" rollup="AVERAGE" rollup-interval="15 minutes" limit="1000"></ma-point-values --> <ma-point-values point="kW" values="kWValues" from="from" to="to" rollup="AVERAGE" rollup-interval="15 minutes" limit="1000"></ma-point-values> <ma-point-values point="energy" values="energyValues" from="from" to="to" rollup="AVERAGE" rollup-interval="15 minutes" limit="1000"></ma-point-values> <ma-point-values point="currentA" values="currentAValues" from="from" to="to" rollup="AVERAGE" rollup-interval="15 minutes" limit="1000"></ma-point-values> <ma-point-values point="currentB" values="currentBValues" from="from" to="to" rollup="AVERAGE" rollup-interval="15 minutes" limit="1000"></ma-point-values> <ma-point-values point="currentC" values="currentCValues" from="from" to="to" rollup="AVERAGE" rollup-interval="15 minutes" limit="1000"></ma-point-values> <ma-point-values point="voltageAB" values="voltageABValues" from="from" to="to" rollup="AVERAGE" rollup-interval="15 minutes" limit="1000"></ma-point-values> <ma-point-values point="voltageBC" values="voltageBCValues" from="from" to="to" rollup="AVERAGE" rollup-interval="15 minutes" limit="1000"></ma-point-values> <ma-point-values point="voltageAC" values="voltageACValues" from="from" to="to" rollup="AVERAGE" rollup-interval="15 minutes" limit="1000"></ma-point-values> <ma-point-values point="voltageAN" values="voltageANValues" from="from" to="to" rollup="AVERAGE" rollup-interval="15 minutes" limit="1000"></ma-point-values> <ma-point-values point="voltageBN" values="voltageBNValues" from="from" to="to" rollup="AVERAGE" rollup-interval="15 minutes" limit="1000"></ma-point-values> <ma-point-values point="voltageCN" values="voltageCNValues" from="from" to="to" rollup="AVERAGE" rollup-interval="15 minutes" limit="1000"></ma-point-values> <ma-point-values point="powerFactor" values="powerFactorValues" from="from" to="to" rollup="AVERAGE" rollup-interval="15 minutes" limit="1000"></ma-point-values> <ma-point-values point="kVar" values="kVarValues" from="from" to="to" rollup="AVERAGE" rollup-interval="15 minutes" limit="1000"></ma-point-values> </div><!--^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^-->
<!-- SERVER SIDE SERVER QUERIES SECTION --><!-- HTML -->
<!--vvvvvvvvvvvvvvvvvvvvvvvvvvvvvv--><head>
<meta charset="utf-8">
<meta name="viewport" content="width=device-width, initial-scale=1"><link rel="stylesheet" ng-href="/resources/angular-csp.css"></link> <link rel="stylesheet" ng-href="../../../../vendor/angular-material/angular-material.css"> <link rel="stylesheet" ng-href="../../../../vendor/material-design-icons/iconfont/material-icons.css"> <link rel="stylesheet" ng-href="../../../../vendor/mdPickers/mdPickers.css"> <link rel ="stylesheet" ng-href="/modules/dashboards/web/demo/styles/vitality.css"></head>
<body>
<md-card-actions layout="row" layout-align="end center"> <a ui-sref="dashboard.section1.page1"><md-button class="vitality-button">Home</md-button></a> <a ui-sref="dashboard.section1.page1p"><md-button class="vitality-button">Power</md-button></a> <a ui-sref="dashboard.section1.page1h"><md-button class= "vitality-button">Heating</md-button></a> <a ui-sref="dashboard.section1.page1c"><md-button class= "vitality-button">Cooling</md-button></a> <a ui-sref="dashboard.section1.page1w"><md-button class= "vitality-button">Water</md-button></a> </md-card-actions><!-- <div layout="column" layout-fill flex> -->
<div layout="row" layout-gt-xs="row"><div flex="20" layout="column"> <md-card flex ="100" layout="column" class= "cardcolor"> <md-card-content> <h2 class="box-title" style="font-family: serif; color:#ffffff;">{{gaugeName}}</h2> <!-- <ma-get-point-value point-xid="DP_744536" point="myPoint" latest="1"></ma-get-point-value> --> <div flex=""> <ma-gauge-chart point=powerFactor style="width:100%; height:300px; font-family: serif" start="0" band-1-end="50" band-1-color="red" band-2-end="90" band-2-color="yellow" band-3-end="100" band-3-color="green" font-size="15px" ></ma-gauge-chart class="amcharts-axis-band-band1" class="amcharts-axis-band-band2" class="amcharts-axis-band-band3" > </div> </md-card-content> </md-card> <md-card flex="100" layout="column" class= "cardcolor"> <md-card-content> <h2 class="box-title" style="font-family: serif; color:#ffffff;">{{realTimeName}}</h2> <ma-point-values point="currentA" values="point5Values" latest="1"></ma-point-values> <ma-point-values point="currentB" values="point6Values" latest="1"></ma-point-values> <ma-point-values point="currentC" values="point7Values" latest="1"></ma-point-values> <div flex="100" layout="row"> <ma-serial-chart default-balloon-text="[[title]]: [[value]]" md-theme="dark" style="height: 300px; width: 100%; font-family: serif;" series-5-values="point5Values" series-5-point="currentA" series-5-color="blue" series-6-values="point6Values" series-6-point="currentB" series-6-color="orange" series-7-values="point7Values" series-7-point="currentC" series-7-color="green" default-type="column" legend="true" overflow= "visible" font-size="8px" options="{ 'fontSize': 12, valueAxes: [{'id': 'ValueAxis-1','color': '#FFFFFF', 'axisColor': '#FFFFFF'}], categoryAxis:{'axisColor':'#FFFFFF', 'labelsEnabled': false}, legend:{'autoMargins': false, 'valueAlign':'center','align':'center', 'labelWidth':0, 'useGraphSettings': false, 'spacing':0, 'forceWidth': true, 'color': '#FFFFFF'}}" class="amcharts-graph-column.amcharts-graph-series-5" class="amcharts-graph-column.amcharts-graph-series-6" class="amcharts-graph-column.amcharts-graph-series-7"></ma-serial-chart> </div> </md-card-content> </md-card> </div> <md-card flex ="80" flex layout="column" class= "cardcolor"> <md-card-content md-theme="dark"> <!-- <h2 class="box-title" style=" font-family: serif; color:#ffffff;">Meter</h2> --> <div flex="100" layout="row" > <md-input-container flex="33" layout-align="start start" style="color:#ffffff;"> <md-select ng-model="deviceName" ng-init="deviceName='032 POWER East'" style="font-size: 20px; font-family: serif;"> <md-option ng-value="'032 POWER East'" style="font-size: 20px; font-family: serif; ">Main Power</md-option> </md-select> </md-input-container> <md-switch flex="66" layout-align="end start" ng-model="showFourth" style=" font-family: serif; color:#ffffff;" >{{switchlabel}}</md-switch> </div> <div ng-show="graphselector == 'kW'" style="color:#FFFFFF"> <ma-serial-chart-2 default-balloon-text="[[title]]: [[value]]" style="height: 500px; width: 100%;" series-1-point="kW" series-1-values="kWValues" series-1-color="blue" series-1-type= "smoothedLine" series-4-values="myVars.tempValues" series-4-color="red" series-4-type= "line" series-4-axis="right" default-type="line" balloon="true" export="true" zoom="true" options="{ export: {'position': 'bottom-right'}, valueAxes: [{'id': 'ValueAxis-1','color': '#FFFFFF', 'axisColor': '#FFFFFF'}], categoryAxis:{'axisColor':'#FFFFFF', 'color': '#FFFFFF'}}" class="amcharts-graph-series-1" ></ma-serial-chart-2> </div> <div ng-show="graphselector == 'kWh'" class= "amcharts-export-menu-bottom-left"> <ma-serial-chart-2 default-balloon-text="[[title]]: [[value]]" style="height: 500px; width: 100%;" series-2-point="energy" series-2-values="energyValues" series-2-color="blue" series-2-type= "smoothedLine" series-4-point="myVars.temp" series-4-values="myVars.tempValues" series-4-color="red" series-4-type= "line" series-4-axis="right" default-type="smoothedLine" export="true" balloon="true" options="{ export: {'position': 'bottom-right'}, valueAxes: [{'id': 'ValueAxis-1','color': '#FFFFFF', 'axisColor': '#FFFFFF'}], categoryAxis:{'axisColor':'#FFFFFF', 'color': '#FFFFFF'}}" class="amcharts-graph-series-2"></ma-serial-chart-2> </div> <div ng-show="graphselector == 'Amps'" > <ma-serial-chart-2 default-balloon-text="[[title]]: [[value]]" style="height: 500px; width: 100%;" series-8-point="currentA" series-8-values="currentAValues" series-8-color="blue" series-8-type= "smoothedLine" series-9-point="currentB" series-9-values="currentBValues" series-9-color="orange" series-9-type= "smoothedLine" series-10-point="currentC" series-10-values="currentCValues" series-10-color="green" series-10-type= "smoothedLine" series-4-point="myVars.temp" series-4-values="myVars.tempValues" series-4-color="red" series-4-type= "line" series-4-axis="right" default-type="smoothedLine" export="true" balloon="true" options="{ export: {'position': 'bottom-right'}, valueAxes: [{'id': 'ValueAxis-1','color': '#FFFFFF', 'axisColor': '#FFFFFF'}], categoryAxis:{'axisColor':'#FFFFFF', 'color': '#FFFFFF'}}" class="amcharts-graph-series-8" class="amcharts-graph-series-9" class="amcharts-graph-series-10"></ma-serial-chart-2> </div> <div ng-show="graphselector == 'VoltsL'" > <ma-serial-chart-2 default-balloon-text="[[title]]: [[value]]" style="height: 500px; width: 100%;" series-11-point="voltageAB" series-11-values="voltageABValues" series-11-color="blue" series-11-type= "smoothedLine" series-12-point="voltageBC" series-12-values="voltageBCValues" series-12-color="orange" series-12-type= "smoothedLine" series-13-point="voltageAC" series-13-values="voltageACValues" series-13-color="green" series-13-type= "smoothedLine" series-4-point="myVars.temp" series-4-values="myVars.tempValues" series-4-color="red" series-4-type= "line" series-4-axis="right" export="true" balloon="true" options="{ export: {'position': 'bottom-right'}, valueAxes: [{'id': 'ValueAxis-1','color': '#FFFFFF', 'axisColor': '#FFFFFF'}], categoryAxis:{'axisColor':'#FFFFFF', 'color': '#FFFFFF'}}" class="amcharts-graph-series-11" class="amcharts-graph-series-12" class="amcharts-graph-series-13"></ma-serial-chart-2> </div> <div ng-show="graphselector == 'VoltsN'"> <ma-serial-chart-2 default-balloon-text="[[title]]: [[value]]" style="height: 500px; width: 100%;" series-14-point="voltageAN" series-14-values="voltageANValues" series-14-color="blue" series-14-type= "smoothedLine" series-15-point="voltageBN" series-15-values="voltageBNValues" series-15-color="orange" series-15-type= "smoothedLine" series-16-point="voltageCN" series-16-values="voltageCNValues" series-16-color="green" series-16-type= "smoothedLine" series-4-point="myVars.temp" series-4-values="myVars.tempValues" series-4-color="red" series-4-type= "line" series-4-axis="right" export="true" balloon="true" options="{ export: {'position': 'bottom-right'}, valueAxes: [{'id': 'ValueAxis-1','color': '#FFFFFF', 'axisColor': '#FFFFFF'}], categoryAxis:{'axisColor':'#FFFFFF', 'color': '#FFFFFF'}}" class="amcharts-graph-series-14" class="amcharts-graph-series-15" class="amcharts-graph-series-16"></ma-serial-chart-2> </div> <div ng-show="graphselector == 'PF'"> <ma-serial-chart-2 default-balloon-text="[[title]]: [[value]]" style="height: 500px; width: 100%;" series-17-point="powerFactor" series-17-values="powerFactorValues" series-17-color="blue" series-17-type= "smoothedLine" series-4-point="myVars.temp" series-4-values="myVars.tempValues" series-4-color="red" series-4-type= "line" series-4-axis="right" export="true" balloon="true" options="{ export: {'position': 'bottom-right'}, valueAxes: [{'id': 'ValueAxis-1','color': '#FFFFFF', 'axisColor': '#FFFFFF'}], categoryAxis:{'axisColor':'#FFFFFF', 'color': '#FFFFFF'}}" class="amcharts-graph-series-17" ></ma-serial-chart-2> </div> <div ng-show="graphselector == 'kVar'"> <ma-serial-chart-2 default-balloon-text="[[title]]: [[value]]" style="height: 500px; width: 100%;" series-18-point="kVar" series-18-values="kVarValues" series-18-color="blue" series-18-type= "smoothedLine" series-4-point="myVars.temp" series-4-values="myVars.tempValues" series-4-color="red" series-4-type= "line" series-4-axis="right" export="true" balloon="true" options="{ export: {'position': 'bottom-right'}, valueAxes: [{'id': 'ValueAxis-1','color': '#FFFFFF', 'axisColor': '#FFFFFF'}], categoryAxis:{'axisColor':'#FFFFFF', 'color': '#FFFFFF'}}" class="amcharts-graph-series-18" ></ma-serial-chart-2> </div> <div flex layout="row" layout-xs="column" class="no-errors-spacer" md-theme="dark"> <div layout="row" > <mdp-date-picker mdp-placeholder="From" mdp-open-on-click="" mdp-format="ll" ng-model="from"></mdp-date-picker> <mdp-date-picker mdp-placeholder="To" mdp-open-on-click="" mdp-format="ll" ng-model="to" ></mdp-date-picker> </div> <md-input-container flex="20" > <label>Preset</label> <ma-date-range-picker md-theme="dark" from="from" to="to" preset="LAST_1_DAYS" update-interval="1 minutes" style=" font-family: serif; color:#ffffff;"></ma-date-range-picker> </md-input-container> </div> <div flex-layout="row" layout-xs="column" class="no-errors-spacer" > <md-radio-group ng-model="graphselector" ng-model-options="{getterSetter:true}" ng-init="graphselector='kW'" layout="row" > <md-radio-button value="kW" class="md-primary" style="font-family: serif; color:#ffffff;">{{label1}}</md-radio-button> <md-radio-button value="kWh" style=" font-family: serif; color:#ffffff;">{{label2}}</md-radio-button> <md-radio-button value="Amps" style="font-family: serif; color:#ffffff;">{{label3}}</md-radio-button> <md-radio-button value="VoltsL" style="font-family: serif; color:#ffffff;">{{label4}}</md-radio-button> <md-radio-button value="VoltsN" style="font-family: serif; color:#ffffff;">{{label5}}</md-radio-button> <md-radio-button value="PF" style="font-family: serif; color:#ffffff;">{{label6}}</md-radio-button> <md-radio-button value="kVar" style="font-family: serif; color:#ffffff;">{{label7}}</md-radio-button> <!-- <md-radio-button ng-repeat="i in range(1,5)" value="{{i}}" ng-style="myPoint.valueRenderer(i)">{{myPoint.valueRenderer(i).text}}</md-radio-button> --> </md-radio-group> </div><!-- <div ng-repeat="pt in points" layout="row" style="font-family: serif; color:#ffffff;">
<label layout="row" >{{pt.name}}: </label> {{pt.renderedValue}}
</div> -->
</md-card-content>
</md-card>
<!-- </div> -->
</body></html>
The way to code is rendered in the post makes it very hard to find a specific problem. Maybe try using the forums upload function and upload the .html / .js files?
