    How to delay graph redraws
    9 Posts 3 Posters 5.3k Views 4 Watching
      JHuckins
      I have a graph in a dashboard that is connected to 'from' and 'to' dates.
      I have a listener that watches for the 'from' date to change, and changes the 'to' date to be 24 hours after the new 'from'date.
      My problem: When I change the 'from' date, the graph redraws twice: once with the original 'to' date and again with the new 'to' date. This looks very unprofessional.
      Example:
      • original 'from' date is 9/26/2016 midnight, original 'to' date is 9/27/2016 midnight.
      • date picker attached to 'from' date changes 'from' date to 9/22/2016 midnight.
      • 'from' date listener in js code changes 'to' date to 9/23/2016 midnight.
      • graph redraws from 9/22/2016 midnight (new 'from' date) to 9/27/2016 midnight (old 'to' date).
      • graph then redraws again from 9/22/2016 midnight to 9/23/2016 midnight (new 'to' date).
      If I could just tell the graph to not redraw "right away", I would be good. How do I do that?
      • Will GellerW Offline
        Will Geller
        Would you mind posting your code so we can help you? JS and HTML please.
          JHuckins
          <!-- this is the date picker for the 'from' date -->
          <mdp-date-picker class="custom-date" mdp-open-on-click="" mdp-format="ll" ng-model="from"></mdp-date-picker>
          <!-- these are the points -->
          <ma-point-values point="Dpoint1" values="D1Static" from="from" to="to" rollup="AVERAGE" rollup-interval="1 minutes"></ma-point-values>
          <ma-point-values point="Dpoint2" values="D2Static" from="from" to="to" rollup="AVERAGE" rollup-interval="1 minutes"></ma-point-values>
          <ma-point-values point="Dpoint3" values="D3Static" from="from" to="to" rollup="AVERAGE" rollup-interval="1 minutes"></ma-point-values>
          <ma-point-values point="Dpoint4" values="D4Static" from="from" to="to" rollup="AVERAGE" rollup-interval="1 minutes"></ma-point-values>
          <ma-point-values point="Dpoint5" values="D5Static" from="from" to="to" rollup="AVERAGE" rollup-interval="1 minutes"></ma-point-values>
          <!-- this is the chart -->
          <ma-serial-chart
          series-1-values="D1Static" series-1-point="Dpoint1" series-1-color='#ffaa00'
          series-2-values="D2Static" series-2-point="Dpoint2" series-2-color='#0000aa'
          series-3-values="D3Static" series-3-point="Dpoint3" series-3-color='#00cc00'
          series-4-values="D4Static" series-4-point="Dpoint4" series-4-color='#ff66cc'
          series-5-values="D5Static" series-5-point="Dpoint5" series-5-color='#ff0000' series-5-axis="right"
          options="{legend: {}, chartCursor: {categoryBalloonDateFormat: 'YYYY-MM-DD HH:NN'}, titles:[{text: 'Dispatch', size: 15}], valueAxes:[{title:'kW/kVAR', position:'left'},{title:'SOC%', position:'right'}]}">
          </ma-serial-chart>
          ----------------------JS code that is executed inside maDashboards.run in maDashboards.js -------------
          $rootScope.$watch('from', function() {
          $rootScope.to = moment($rootScope.from).add(1, 'days').toDate();
            JHuckins
            The idea is that the chart always shows a 24-hour period. When the 'from' date is changed by the user via the date picker, then the watch sets the 'to' date to 24 hours later.
              I think the problem is that the way you are doing it the from and to change in successive digest cycles instead of both at once. Try setting the ng-model of your date picker to another variable name e.g. datePickerDate then do
              $rootScope.$watch('datePickerDate', function() {
                $rootScope.from = $rootScope.datePickerDate;
                $rootScope.to = moment($rootScope.datePickerDate).add(1, 'days').toDate();
                JHuckins
                Thanks. That sounded like a great idea. Unfortunately, it did not work. I double-checked, and my watch function is the only place the 'from' and 'to' dates are set. I'm using Mango 3.2.2.
                  Will Geller
                  I have a feeling you don't need to use JS to accomplish this. I just posted a similar solution using the <ma-calc> directive.
                  Try adding this in your HTML and comment out the watcher from the JS:
                  <ma-calc input="from | moment:'add':24:'hours'" output="to"></ma-calc>
                  This should take in your from value from the date picker and output a new to value that will be 24 hours advance of from.
                    Will Geller
                    Also you may need to set a size on your <ma-serial-chart> depending on what it is contained within. Try adding the style property
                    style="width:100%; height:500px"
                    and you may want to use <ma-now> to initialize the Day picker to yesterday or something.
                      JHuckins
                      I like that ma-calc. And I added that style to the chart. No change.
