    Angular JS, Area Charts
    8 Posts 3 Posters 5.3k Views 3 Watching
      atkins.chrisw
      Does the new AngularJS support "Area" AM Charts? I see line, column, but not area,
      • Will GellerW Offline
        Will Geller
        I believe what you want is the following:
        <ma-serial-chart default-balloon-text="[[title]]: [[value]]" style="width: 100%; height:100%;" points="points" values="chartValues" default-type="smoothedLine" stack-type="regular" legend="true" balloon="true" export="true">
        </ma-serial-chart>
        If you are trying to set this via a dropdown selector along with the other options you can do something like this (note usage of stack-type and default-type attributes within the template logic):
        <md-select ng-model="chartType" ng-init="chartType='smoothedLine'" aria-label="Chart Type">
                <md-option value="smoothedLine">
                    Smooth
                </md-option>
                <md-option value="line">
                    Line
                </md-option>
                <md-option value="step">
                    Step
                </md-option>
                <md-option value="column">
                    Bar
                </md-option>
                <md-option value="stacked">
                    Stacked
                </md-option>
                <md-option value="area">
                    Area
                </md-option>
        </md-select>
        <ma-serial-chart ng-if="chartType!='stacked' && chartType!='area'" default-balloon-text="[[title]]: [[value]]" style="width: 100%; height:100%;" points="points" values="chartValues" default-type="{{chartType}}" stack-type="none" legend="true" balloon="true" export="true">
        </ma-serial-chart>
         <ma-serial-chart ng-if="chartType=='stacked'" default-balloon-text="[[title]]: [[value]]" style="width: 100%; height:100%;" points="points" values="chartValues" default-type="column" stack-type="regular" legend="true" balloon="true" export="true">
         </ma-serial-chart>
         <ma-serial-chart ng-if="chartType=='area'" default-balloon-text="[[title]]: [[value]]" style="width: 100%; height:100%;" points="points" values="chartValues" default-type="smoothedLine" stack-type="regular" legend="true" balloon="true" export="true">
        </ma-serial-chart>
          atkins.chrisw
          What if I don't want it to be a stacked area?
            Will Geller
            It's not currently possible to do it as such via attributes on the directive, we may make the serial chart directive capable of handling this type of customization in the future.
            If you are feeling adventurous you can look into editing web/js/mango-3.3/directives/serialChart.js to customize the chart component to your liking.
              atkins.chrisw
              OK. Here is another code snippet of a serial chart. the export button isn't showing up.
                          <div ng-show="graphselector == 'kWh'">
                              <ma-serial-chart style="height: 500px; width: 100%" series-1-point="energy" series-1-values="energyValues" series-1-color="blue" series-1-type= "column" series-4-point="myVars.temp" series-4-values="myVars.tempValues"  series-4-color="red" series-4-type= "line" series-4-axis="right" default-type="smoothedLine" stack-type="regular" options="{chartScrollbar:{'enabled': true}}" export="true" legend="true" balloon="true"></ma-serial-chart>
              Is there a special width I need to keep the div's at?
                atkins.chrisw
                I just copied the following code. I pasted it into the play area and it is working fine. I paste it into my pages, the export button isnt' showing. Is there a new js or css that needs to be added to my pages.
                <ma-point-values point="point1" values="point1Values" from="from" to="to" rollup="AVERAGE" rollup-interval="1 hours">
                </ma-point-values>
                <ma-serial-chart default-balloon-text="[[title]]: [[value]]" style="height: 300px; width: 100%" default-type="smoothedLine" stack-type="regular" legend="true" balloon="true" export="true" series-1-values="point1Values" series-1-point="point1" default-type="column">
                </ma-serial-chart>
                My pages are referencing...
                <link rel="stylesheet" href="/resources/angular-csp.css"></link>
                <link rel="stylesheet" href="../../../../vendor/angular-material/angular-material.css">
                <link rel="stylesheet" href="../../../../vendor/material-design-icons/iconfont/material-icons.css">
                <link rel="stylesheet" href="../../../../vendor/mdPickers/mdPickers.css">
                <link rel ="stylesheet" ng-href="/modules/dashboards/web/clayground/styles/vitality.css">
                  Jared Wiltshire @atkins.chrisw
                  @atkins.chrisw said in Angular JS, Area Charts:
                  You need to be using v3.2 of the dashboards module and make sure the adminTemplate you are using is based on the version included in v.3.2. I'd copy index.html and the directives folder over from the adminTemplate folder. Then review the differences between app.js and your version of the file. The main thing is that the two references at the start of the file refer to 'mango-3.2/maMaterialDashboards' and 'mango-3.2/maAppComponents'.
                  No thats totally up to you.
                    I've also posted a topic here with more detail on upgrading your dashboard.
