    Filtering the Menu list for the Angular JS, Graphs
    11 Posts 3 Posters 6.7k Views 3 Watching
      atkins.chrisw
      With this menu list provided by Mango. This grabs every point in the Mango DB. Is there a way I can filter this list to specific points, so I can make these lists for specific buildings or areas.
      <md-input-container class="md-block no-errors-spacer">
      <label>Choose a point</label>
      <ma-point-list ng-model="myPoint"></ma-point-list>
      </md-input-container>
        Yes, please see the "Point list" example under "Basics". I'd recommend setting the "Device name" for each point to your building name, or implementing a specific point naming strategy that incorporates the building/area name.
          atkins.chrisw
          <div layout="column">
          <ma-point-list ng-model="myPoint" query="deviceName(032 GAS East)"></ma-point-list>
          <p>You have chosen point "{{myPoint.name}}". It is {{myPoint.enabled ? 'enabled' : 'disabled'}} and belongs to device {{myPoint.deviceName}}</p>
            I'm going to take it that you are asking why that markup isn't working?
            Pay close attention to the syntax of the query attribute, it should be query="{deviceName:'032 GAS East'}"
              atkins.chrisw
              Thanks Jared. Worked like a charm
              I'm loving this btw!!!
                atkins.chrisw
                Jared,
                what if I wanted to make a variable reference to the query. That way, I could add in the top of my document a variable, that would then fill in the deviceName
                • Will GellerW Offline
                  Will Geller
                  It would be pretty similar to the example only set to query on deviceName:
                      <md-input-container>
                          <label>Set Variable for Device Name</label>
                          <input ng-model="deviceNameVariable" ng-model-options="{debounce:500}">
                          <label>Filtered point list</label>
                          <ma-point-list limit="200" ng-model="myPoint2" query="{deviceName:deviceNameVariable}"></ma-point-list>
                  In angular you can use ng-model or ng-init to declare scope variables without the var keyword.
                  With ng-init (you can move ng-init to a div at the top of the document)
                      <md-input-container ng-init="deviceNameVariable='meta'">
                    atkins.chrisw
                    Thanks Jared. What If i wanted to filter y the datasource name instead of deviceName?
                    would it be {datasource: "UofU Stadium East'}
                      Jared Wiltshire @atkins.chrisw
                      @atkins.chrisw said in Filtering the Menu list for the Angular JS, Graphs:
                      It will be {dataSourceName: 'UofU Stadium East'}
                        atkins.chrisw
                        Perfect. Worked great
                          atkins.chrisw
                          Also... What if I wanted to filter it between two different datasources with specific deviceNames?
