    Mango M2M don´t let me loggin, prints exception
    15 Posts 2 Posters 9.0k Views 2 Watching
      Something is wrong with your database connection. It either isn't starting or isn't connected. Check you Mango/overrides/properties/env.properties file or Mango/classes/env.properties
      Ensure that there is still space left on the disk.
      You appear to be using a very old version of Mango.
        Alejandro Abril
        When I turn off and turn on the server again this allows me to login but in 30 minutes I again limited access , and will increase the memory space but apparently does not give effect because I still have the same problem.
          Alejandro Abril
          I can delete the database from the Linux server , but only the files not the platform that I do not have backups of the platform.
            I am wondering if the hard disk is what is full (but Mango probably wouldn't boot). But, this version of Mango is very old, and derby isn't even officially supported anymore (we bundle H2 as the embedded database). I'm afraid I can't offer much help.
              Alejandro Abril
              This Disco completely full search results perform un had to erase maintenance every 3 months but were neglected and left him there. So the server fell and 5 months.
              a week that turned a reboot and worked well for 3 days, but from there we had the login problem.
                It is possible the database was corrupted when the disk filled up. If you have a backup of your configuration, you can start a new database and import it. You may be able to convert the data out to MySQL, as well, using the convert.db.properties in env.properties.
                  Alejandro Abril
                  Mango m2m I am using data acquisition for some variables , you can stop the process of data acquisition, to delete files from the database , with this would prevent re- collapse the system.
                    I don't understand. How can you be collecting data if you can't connect to your database?
                      Alejandro Abril
                      When I reboot the server allows me to login for 30 minutes at that time I want to stop the acquisition to not re- collapse the system and to delete files from databases
                        I would export all data sources (or the whole configuration) and start it with the file SAFE in the Mango/ directory (if that feature exists in such an old Mango...) to start with all data sources disabled. Either import your configuration or manually enabled data sources to begin acquisition again
                          Alejandro Abril
                          Exactly the same thing had in mind momentarily disable scripts acquisition.
                            Alejandro Abril
                            tomorrow I try and tell you, thanks!!
