    Build error:taskdef class org.apache.catalina.ant.ReloadTask can not be found
    7 Posts 4 Posters 18.0k Views 1 Watching
      m2mtime
      I am a wireless module software developer from China, and be interested in your Mango.
      When I try to build Mango sourcecode with the build instruction on https://mango.dev.java.net/#building,
      There is a build error:
      d:\mango\app\build.xml:121: taskdef class org.apache.catalina.ant.ReloadTask can not be found.
      Could you tell me what's the problem?
      Thank you in advance!
        The ReloadTask is defined near the bottom of the build.xml script (in a taskdef). The "location" attribute points to where the task definition can be found, and uses the macro ${tomcat.home}. This macro is defined in your build.properties file. Make sure you have it properly defined such that it points to the catalina-ant.jar file as it appears in the task definition.
          marybka
          I'm having the some kind of problem. I'm trying to make it work under Windows XP, I have installed Tomcat here: C:\Program Files\Apache Software Foundation\Tomcat 6.0
          So I changed the line in build.properties to: tomcat.home=C:\Program Files\Apache Software Foundation\Tomcat 6.0
          And it doesn't work, I still get this message: .
          Buildfile: build.xml
          BUILD FAILED
          C:\Documents and Settings\test1234\Pulpit\mango\app\build.xml:120: taskdef class
           org.apache.catalina.ant.ReloadTask cannot be found
          Total time: 0 seconds
          May someone help me with that?
            Some things to check:
            1. within that directory, is there a "lib" sub-dir containing "catalina-ant.jar"?
            2. have you tried changing "" characters to "/"?
            3. if all else fails, can you try a directory that does not have embedded spaces?
              marybka
              Thanks for the answer, of course changing "" characters to "/" works:)
              • H Offline
                hockeymansion01
