    Not understand how to know the objectType value
    8 Posts 2 Posters 5.4k Views 1 Watching
    • V Offline
      Valter Henrique
      I have some objects that I must to know which is the exactly the value of this object, if it's analog OUTPUT or analog INPUT, got it ?
      For example:
      If you I did this :
                  System.out.println("oi.getObjectType().intValue(): " + oi.getObjectType().intValue());
                  System.out.println("ObjectType.analogOutput.intValue(): " + ObjectType.analogOutput.intValue());
                  System.out.println("ObjectType.analogInput.intValue(): " + ObjectType.analogInput.intValue());
                  System.out.println("ObjectType.analogValue.intValue(): " + ObjectType.analogValue.intValue());
      Which the answer gonna be:
      oi.getObjectType().intValue(): 2
      ObjectType.analogOutput.intValue(): 1
      ObjectType.analogInput.intValue(): 0
      ObjectType.analogValue.intValue(): 2
      But I need to know if is OUTPUT (1) or INPUT (0).
      How can I do that ?
        That object, "oi", is not an "output" or an "input"; it is a "value", which is a valid third type of bacnet input. "Value"s are basically both input and output.
        • V Offline
          Valter Henrique
          So, what should I do to get the exact type of the object ?
          I mean, how do I know if is a analog output or analog input ?
            Valter,
            You are incorrect in thinking that an analog can only be an input or an output. There are three possible analog types: input, output, and value. Your object is a value.
            • V Offline
              Valter Henrique
              @mlohbihler said:
              Valter,
              Ow, got it mlohbihler.
              There's some way to get the values from the input and output objects ?
              This is how I'm doing to get these values :
                  private List<ObjectIdentifier> getListObjectIdentifier(LocalDevice localDevice) throws Exception {
                      ReadPropertyRequest rpr = new ReadPropertyRequest(new ObjectIdentifier(ObjectType.device, deviceID), PropertyIdentifier.objectList);
                      ReadPropertyAck rpa = (ReadPropertyAck) localDevice.send(isa, null, 1476, Segmentation.segmentedBoth, rpr);
                      SequenceOf<ObjectIdentifier> sOis = (SequenceOf<ObjectIdentifier>) rpa.getValue();
                      List<ObjectIdentifier> ois = new ArrayList<ObjectIdentifier>();
                      for (ObjectIdentifier oi : sOis) {
                          ois.add(oi);
                      return ois;
                Use read property requests with the present value property identifier.
                • V Offline
                  Valter Henrique
                  I did as you said :
                      public String getPresentValue(LocalDevice localDevice, ObjectIdentifier oid) throws Exception {
                          ReadPropertyRequest rpr = new ReadPropertyRequest(oid, PropertyIdentifier.presentValue);
                          ReadPropertyAck rpa = (ReadPropertyAck) localDevice.send(isa, null, 1476, Segmentation.segmentedReceive, rpr);
                              System.out.println("--> " + oi.getObjectType().intValue());
                          return rpa.getValue().toString();
                  But it gives this follow error:
                  java.lang.ClassCastException: com.serotonin.bacnet4j.type.primitive.Real cannot be cast to com.serotonin.bacnet4j.type.constructed.SequenceOf
                  	at brainset.bacnet4j.Supervisory.getPresentValue(Supervisory.java:123)
                  What I'm trying to do is scan my device and know what kind of points I have, if is a analog output, analog input, etc.
                  And store these points values in my List<...>.
