    How communicate to a remote device ?
    10 Posts 3 Posters 6.8k Views 1 Watching
    • V Offline
      Valter Henrique
      I made a local device communicate with my application.
      But how do I make to communicate to a remote device ?
      Is possible to do this using ip or dns ? (because the ip changes sometimes).
        Hi Valter,
        What do you mean by remote? I suspect you mean a device with which you cannot exchange a WhoIs/IAm, but please confirm.
        If this is the case, you will need to manually instantiate a RemoteDevice by explicitly providing the IP, port, and instance id. Then, you will be able to send messages to it.
        Regarding using a domain name, BACnet only deals with IP addresses, so you will need to handle domain name resolution yourself.
        • V Offline
          Valter Henrique
          @mlohbihler said:
          Hi Valter,
          I mean, a device that is not in my network.
          There's some example in the test folder that could use for that ?
            I don't think so, but it's not hard. The only trick is that you need to know the instance id of the device.
            RemoteDevice rd = new RemoteDevice(...);
            localDevice.addRemoteDevice(rd); // This may not actually be necessary
            localDevice.send(rd, myRequest);
            Where "myRequest" is, say, a read property with pid of objectList. If your setting are correct, you should get the object list of the remote device.
            • V Offline
              Valter Henrique
              I found the id of my device, it's 101, but I have some doubts about it :
                      // How to initialize the LocalDevice ?
                      LocalDevice ld = new LocalDevice (???);
                      // let's say my ip is : 1.2.3.4, is this correct ?
                  	RemoteDevice rd = new RemoteDevice(101, new Address(new byte[] { (byte) 1, (byte) 2, 3, (byte) 4 }, 47808), null);
                      ld.addRemoteDevice(rd);
                      // now I have the remote device, in the localDevice, now I should be able to use the method 'getObjectList()' ?
                      // how to use this 'myRequest' (I don't understand what you said about it ) ?
                Anyway, a request is a key component of BACnet. It's how all communication is done with BACnet peers (aka RemoteDevices). Have a look at LocalDevice.findRemoteDevice (and ignore the code that i provided previously). You should be able to see what is going on.
                • R Offline
                  R-GiGgS84
                  Hi mlohbihler ,
                  Can u give an example of how u instantiate myRequest?
                  Regards,
                  WenJun
                    • V Offline
                      Valter Henrique
                      In the end I created a server (which runs in the computer that's locally placed in my network) and then communicate via socket.
                      Until I found out how implement a RemoteDevice that you said, thanks mlohbihler.
