Navigation
    • Search
    How to send response to ReadPropertyRequest
    BACnet4J general discussion
    2
    7
    2415
    • D
      dinesh4761 last edited by
      First of all thanks for BACnet4J. Nice BACnet Stack.
      I am developing code which simulates some BACnet device and I need to
      send reply to "[size=18]ReadPropertyReqest[/size]".
      Wherein Present Value of BACnet object mentioned.
      Does anyone know about it? If yes please help me.
      Regards,
      Dinesh
      • D
        I think it should be "ReadPropertyAck". Because, from VTS I sent this request then I found following in Wireshark.
        No. Time Source Destination Protocol Length Info
        1435 498.012518 192.168.0.103 192.168.0.1 BACnet-APDU 67 Complex-ACK readProperty[ 1] analog-input,0 present-value
        Frame 1435: 67 bytes on wire (536 bits), 67 bytes captured (536 bits)
        Ethernet II, Src: CompalIn_b2:45:7e (00:26:22:b2:45:7e), Dst: Teracom_6b:4d:e0 (00:26:15:6b:4d:e0)
        Internet Protocol Version 4, Src: 192.168.0.103 (192.168.0.103), Dst: 192.168.0.1 (192.168.0.1)
        User Datagram Protocol, Src Port: bacnet (47808), Dst Port: bacnet (47808)
        BACnet Virtual Link Control
        Building Automation and Control Network NPDU
        Building Automation and Control Network APDU
        0011 .... = APDU Type: Complex-ACK (3)
        .... 0000 = PDU Flags: 0x00
        Invoke ID: 1
        Service Choice: readProperty (12)
        ObjectIdentifier: analog-input, 0
        Property Identifier: present-value (85)
        property Array Index (Unsigned) 1
        {[3]
        present-value: 23.000000 (Real)
        }[3]
        And it is quite similar as mentioned in one of the PDF of BACnet Standard which I found on Internet.
        But still I don't know how to send "ReadPropertyAck".
        If someone is knowing please help me.
        Thanks.
        • D
          I got following.
              ReadPropertyRequest rprr = new ReadPropertyRequest(localDevice.getNextInstanceObjectIdentifier(ObjectType.analogInput), PropertyIdentifier.presentValue, null);
              ReadPropertyAck unRS = new ReadPropertyAck(localDevice.getNextInstanceObjectIdentifier(ObjectType.analogInput), PropertyIdentifier.presentValue, null, rprr);
              InetSocketAddress addr = new InetSocketAddress(InetAddress.getByName("192.168.0.255"), 47808);
              ComplexACK ack = new ComplexACK(true, true, by, by, by, unRS);
          Is it correct?
          If yes then how to send this Complex Request Ack?
          Please reply,
          Thanks in advance.
          • D
            Greetings!
            I got the answer and I am too much happy about it.
            Because, I just run Slave device test program and then
            send the "ReadPropertyRequest" from the another PC using
            VTS. And then monitored acctivities going on in Wireshark.
            I found the reply as ComplexAck by Slave device test program.
            Thank you so much serotonin for developing such genius API.
            But, now I am moving ahead.
            That is I am implementing COV (Change of Value) functionality.
            So I want some help on the same.
            If anybody is knowing the same please let me know.
            Regards,
            Dinesh
            • T
              ThomasRobinson last edited by
              This is very important information Dinesh..Good one.
              • D
                Thanks Thomas for compliments.
