    Read more than a register in one request
    4 Posts 3 Posters 5.4k Views 1 Watching
    • B Offline
      bkhashfeh
      Hello guys,
      I'm newbie in industrial field, my background is an IT, I need to use Modbus4j; I have one problem, I think it is easy to solve for you guys,
      I need to read more than one register in one Modbus request as part of the modbus standard, can I do that without changing the code?
      for example:
      I need to send Modbus request to a slave id, with range (4001 Holding register), with offset 3* and length 6 (6 registers)*
        mahesh
        hi bkhashfeh
        yes its possible to read more than one register in one request. for detail please post your example code i will suggest u corrections in your code.
        regards
        mahesh
        • V Offline
          Vicarious
          Hi, I'm not bkhashfeh but I have the same problem and I'd apreciate the help :D . Here is my code where I'm reading three registers per second (or trying).
          package modbusmastertest;
          import com.serotonin.modbus4j.ModbusFactory;
          import com.serotonin.modbus4j.ModbusMaster;
          import com.serotonin.modbus4j.code.DataType;
          import com.serotonin.modbus4j.ip.IpParameters;
          import java.io.FileWriter;
          import java.io.PrintWriter;
          import java.util.Calendar;
          class MBMasterTest {
          // Modbus master settings
          ModbusFactory factory = new ModbusFactory();
          IpParameters params = new IpParameters();
          params.setHost("192.168.0.1");
          params.setPort(502);
          params.setEncapsulated(false);
          ModbusMaster master = factory.createTcpMaster(params, false);
          master.setTimeout(333);
          master.setRetries(1);
          // CSV writter settings
          FileWriter fwriter;
          fwriter = new FileWriter("C:/Users/NESTOR/Dropbox/Siemens_S7-1200.csv");
          PrintWriter outputFile = new PrintWriter(fwriter);
          outputFile.println("Date,Sensor_1,Sensor_2,Sensor_3"); // Primera línea
          Object []Register = new Object[3];
          // Date settings
          Calendar cal = Calendar.getInstance();
          long elapsedTime = 0;
          long time = 0;
          	    // Cuerpo del programa
          	long start = System.currentTimeMillis(); // Tiempo de inicio
          	try {
          		master.init();
          		while(System.currentTimeMillis()<(start+10000)) {
          			time = System.currentTimeMillis();
          			for(int i = 0; i<3; i++) {
          				Register* = master.getValue(1,40001+i,DataType.TWO_BYTE_INT_SIGNED);
          			System.out.println(Register[0]+","+Register[1]+","+Register[2]);
          			System.out.println(""
          			elapsedTime = System.currentTimeMillis()-time;
          			cal.setTimeInMillis(cal.getTime().getTime() + elapsedTime);
          			outputFile.println(cal.getTime().toString()+","+Register[0]+","+Register[1]+","+Register[2]); // Se escribe nueva linea en archivo
          		outputFile.close(); // Se cierra el archivo
          	finally {
          		master.destroy(); //Se destruye el objeto master
          	System.out.println("Tardo " + (System.currentTimeMillis()-start) + "ms");
