    Install problem
    6 Posts 2 Posters 6.8k Views 1 Watching
    • C Offline
      colarsson
      M2M2 will not start.
      Core 1.0.1 no modules added
      Ubuntu 10.04.1 LTS
      Bootstrap: 34 jar files loaded
      INFO 2011-03-27 10:34:52,391 (com.serotonin.util.ReloadingProperties.checkForReload:165) - (env) Found updated file(s). Reloading properties
      INFO 2011-03-27 10:34:52,447 (com.serotonin.m2m2.db.DerbyProxy.initializeImpl:55) - Initializing derby connection manager
      INFO 2011-03-27 10:34:56,016 (com.serotonin.m2m2.db.upgrade.DBUpgrade.checkUpgrade:36) - Starting instance with core version 1.0.1
      2011-03-27 10:34:57.054:INFO::Logging to STDERR via org.mortbay.log.StdErrLog
      2011-03-27 10:34:57.219:INFO::jetty-6.1.22
      2011-03-27 10:34:58.214:INFO:/:Initializing Spring root WebApplicationContext
      INFO 2011-03-27 10:34:58,762 (com.serotonin.m2m2.web.M2M2ContextListener.contextInitialized:30) - M2M2 context starting
      INFO 2011-03-27 10:34:58,764 (com.serotonin.m2m2.web.M2M2ContextListener.contextInitialized:38) - M2M2 context started
      2011-03-27 10:34:58.978:INFO:/:Initializing Spring FrameworkServlet 'springDispatcher'
      INFO 2011-03-27 10:35:00,105 (com.serotonin.m2m2.web.dwr.util.BlabberConverterManager.addConverter:61)
      • Probably not an issue: org.jdom.Document is not available so the jdom converter will not load. This is only an problem if you wanted to use it.
        INFO 2011-03-27 10:35:00,106 (com.serotonin.m2m2.web.dwr.util.BlabberConverterManager.addConverter:61)
      • Probably not an issue: org.jdom.Element is not available so the jdom converter will not load. This is only an problem if you wanted to use it.
        2011-03-27 10:35:00.344:INFO::Started SelectChannelConnector@0.0.0.0:8080
      No prompt after this messages.
      Br, Conny Larsson
        Hi Conny,
        Those are typical startup messages. Have you tried accessing M2M2 at localhost:8080? How do you know it's not starting?
        • C Offline
          colarsson
          Hi Matthew
          No access at 192.168.0.180:8080
          As long as I have the ssh-client(putty) running I can access m2m2.
            Hmm. Seems like M2M2 is starting ok. The problem may be that Ubuntu closes the application when you log out. Try starting it with "./m2m2-start/sh &". I.e. put a "&" at the end of the command so that a new process is spawned.
            • C Offline
              colarsson
              Hi, Matthew
              It's working now, the "&" solved it.
              Added modules and licenscefile and restarted.
              Now the fun starts :D
              Thank you
