    Multi-state (Image/state assignments problem)
    15 Posts 4 Posters 10.7k Views 1 Watching
    • H Offline
      huexit
      there are 3 bits (*) they change constantly, so they should be ignored. how does it work?
      as a data source I use the http-retriever with regex [(.{ 7})].
      • regex: (..)...(..) does not work
        I would use a meta point to remove the middle bits. The state list in the above image does not support wildcards.
        • H Offline
          huexit
          tell me more about meta points.
          where are the meta point settings?
          • J Offline
            Jokke
            The metapoints use other points as inputs. In your case you could use metapoint to take the value an modify it(filter the bits out). Then you could use the metapoint on the view.
            You need to add meta datasource and the metapoints into it.
            BR
            -Jokke
            • H Offline
              huexit
              there are a metapoint documentation? what's the script langurage?
              how i filter bits?
              • S Offline
                skiv71
                i used this to derive bit status from a word to drive a binary meta point...
                b="1";
                if (word.value & Math.pow(2,b)) value=true;
                else value=false;
                return value;
                b is the bit u want... 0-15
                word is the context variable (i chose to name is word)
                maybe it can point u in the right direction...
                the script language is described in the help.... its ECMAscript i think
                Neil
                • J Offline
                  Jokke
                  if you create the meta data source there is the symbol with (?).
                  Help tells the script is JavaScript / ECMAScript so basicly the same as every where else on mango.
                  you could add something like this to the meta point script to mask the bits 2, 3 and 4 out.
                  return (p100.value & 0xFFE3);
                  replace p100 with the script context var appropriate on your case.
                  if you data value is alphanumeric then it maybe a different solution. (and if you want to be able to set the value then there might be needed some point link)
                  BR
                  -Jokke
                    Note that all the usual bitwise operators work in ECMAScript (and apparently Javascript too). So, you can do stuff like:
                    if (word.value & 8) { ... stuff to do when the third bit is on }
                    ... or:
                    if ((word.value &gt&gt 3) & 1) { ... stuff to do when the third bit is on }
                    If you have a byte value b, and you want to remove bits 4, 5, and 6 (counting from LSB), i.e. xx***xxx, you could do this:
                    var b = source.value;
                    b = (b & 7) | ((b &gt&gt 3) & 24);
                    return b;
                    This will leave you with only the other 5 bits, a number from 0 to 31.
                      Jokke beat me to the response.
                      • J Offline
                        Jokke
                        You took an other cup of coffee while responding. :) Luckily the answers were not same but different aspect on same.
                        btw bit offtopic. It has been a while since doing any bit filtering. Happen to know is there any way to represent binary values on JS? (like hex is 0x prefix) atleast 0b is not working. With quick internet search I did not find anything.
                        BR
                        -Jokke
                          Mmmm, coffee. AFAIK, the '0b' prefix is not supported.
                          • H Offline
                            huexit
                            thx for much help
                            I have another solution, but I do not know if that's possible
                            part 1 : .(..) regex
                            part 2: .{5}(..) regex
                            it is possible to write a row? with script?
                            two points (or more) in metadatasource who multiplicated?
                              You can include as many points as you need in a meta point script.
                              • H Offline
                                huexit
                                and how does it work?
                                whats the script term?
                                may anyone help me pls :)
                                • it must be multistate
                                var b =  p46.value + p47.value;
                                return b;
                                does not work, because..
                                1000 = 10
                                0010 = 10
                                mango think the figueres are dezimal not bitwise
