    Publisher don't listen
    4 Posts 2 Posters 6.4k Views 2 Watching
    • J Offline
      Jérôme Girard
      Hello,
      I try to setup a Modbus publisher and I have some issues.
      There is no socket on 502 port after starting publisher
      ma.log
      INFO  2022-08-30T09:02:17,069 (com.serotonin.m2m2.rt.RuntimeManagerImpl.stopPublisher:606) - Publisher (name=Balances, id=2, type=ModbusIpPublisherRT) stopped in 17ms
      INFO  2022-08-30T09:02:22,962 (com.serotonin.m2m2.rt.PublishedPointGroupInitializer.initialize:24) - Initializing 12 published points in 2 threads
      INFO  2022-08-30T09:02:22,963 (com.serotonin.m2m2.rt.PublishedPointGroupInitializer.processItem:48) - Initializing group 0 of 12 published points
      INFO  2022-08-30T09:02:22,966 (com.serotonin.m2m2.rt.PublishedPointGroupInitializer.processItem:66) - Group 0 successfully initialized 12 of 12 published points in 3 ms
      INFO  2022-08-30T09:02:22,967 (com.serotonin.m2m2.rt.PublishedPointGroupInitializer.initialize:38) - Initialization of 12 published points in 2 threads took 5 ms
      INFO  2022-08-30T09:02:22,968 (com.serotonin.m2m2.rt.RuntimeManagerImpl.startPublisher:584) - Publisher (name=Balances, id=2, type=ModbusIpPublisherRT) took 25ms to start
      netstat -ln
      root@radix:~# netstat -ln
      Active Internet connections (only servers)
      Proto Recv-Q Send-Q Local Address           Foreign Address         State
      tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN
      tcp6       0      0 :::8080                 :::*                    LISTEN
      tcp6       0      0 :::22                   :::*                    LISTEN
      tcp6       0      0 :::8443                 :::*                    LISTEN
      udp        0      0 127.0.0.53:53           0.0.0.0:*
      udp        0      0 192.168.253.111:68      0.0.0.0:*
      raw6       0      0 :::58                   :::*                    7
        MattFox @Jérôme Girard
        @Jérôme-Girard if you're using a non root user you'll need to configure linux to allow non root users to use sub 1024 ports.
        namely
        sudo sysctl net.ipv4.ip_unprivileged_port_start=502
        and
        sudo nano /etc/sysctl.conf
        then set
        net.ipv4.ip_forward=1
        That should enable you to fire the publisher up on 502
        • J Offline
          Jérôme Girard
          Thanks a lot.
          As a workaround, I had changed the listen port to 30502.
          But your solution is more elegant.
          Jérôme
            @Jérôme-Girard pas de problème
