    IP Bacnet device - BACnet discovery
    How-To
    2
    2
    1.0k
    • N
      NinoK
      I have a network that spread over /21. There are few devices that I can access from YABE using " remote BACnet /Ip node. The Mango version is 3.7.7 the latest one.
      The Mango instance itself has 2 interfaces the public one, and the internal one which is pointing to these/21 subnets.
      The local BACnet device is created with local bind address 0.0.0. and subnet /21 I added Device ID #35000, the broadcast address is 255.255.255.255, the local network number is 0. There is not BBMD.
      When I scan for the devices using the BACnet device browser. WHO-IS is not returning any device. I understand that is because there is no BBMD.
      What I don't understand is why the scanner is not showing even a local device?
      Is there any way haw to solve such a situation?
      Thansk
      • R
        Ralf
        Hi NinoK,
        if you create a new BACnet-Data-Source your local device IP (old system settings / BACnet local devices: 192.168.100.105:47808) should be the same as the Mango-Server has:
        If you create a new BACnet data point it should look like:
        where the "Device instance number" is the given Device ID, here 5.
        If all BACnet-Devices are in the same IP-Range you don't need a BBMD.
        Be carful if you scan a large BACnet-Network with many devices and objects. It can take a long time and need server-resources. Better is to scan one ID.
